Old 03-14-2012, 03:04 PM   #1
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
TPMS Sensors
Since all cars are now required to have tire pressure monitoring systems (right?), if you swap rims, what does the system do?
The sensors are in the rims, right?
If your new rims don't have the sensors, does your car think you have 4 flats?
If the new rims do have sensors, how do you sync them with your car?
If you rotate your tires, is the car smart enough to know which tire is where?
Man, things WERE easier before computers! :p
ashtray is offline   Reply With Quote
Old 03-14-2012, 03:13 PM   #2
dsgerbc
Drives: BRZ(sold), STI
No idea how it's set-up in a brz. In my legacy particular corner doesn't matter, so rotation is not an issue. Swapping rims requires new sensors to be registered in TPMS brain. Delaer can do it, or you can buy a tool. If there are no sensors - a dash light comes on, some just apply electric tape over it.
I'm kinda hoping that my current tool would work....
dsgerbc is offline   Reply With Quote
Old 03-14-2012, 03:17 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-14-2012, 05:17 PM   #4
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Some cars have a way to program the new sensors without the dealer. I have the ATEQ quickset tool which I've heard a lot of complaints about but I've never had any problems.
Plug it into your PC
Launch the program
Input your sensor IDs
Plug in to OBDII port
Press the button
Drive to trigger the sensors
Done.
The Quickset tool is also nice because it will hold two sets of sensor IDs. One button loads "Winter" wheels the other loads "Summer"
Old 03-14-2012, 07:11 PM   #5
dsgerbc
^You're missing a step.
Where you disable your internet to prevent the tool from upgrading away from the version that works
Old 03-14-2012, 08:40 PM   #6
neutron256
neutron256's Avatar
I had to fiddle with it to get the software to work with windows 7 but I haven't had any troubles since.
Old 03-15-2012, 04:20 AM   #7
WhiteGDB
WhiteGDB's Avatar
Drives: Civic Si sedan
Since I won't need to have a set of dedicated winter wheels, I'm just gonna swap the stock sensors over to my new wheels.
WhiteGDB is offline   Reply With Quote
Old 03-15-2012, 04:54 AM   #8
Dark
Elite Padawan
Dark's Avatar
I will pretend that the light is not there.
Dark
Dark is offline   Reply With Quote
Old 03-15-2012, 06:05 AM   #9
neutron256
neutron256's Avatar
Some newer cars it's not as simple as ignoring the light. My CR-Z won't let you disable traction control if there if the TPMS system is triggered. It's really annoying.
Old 03-15-2012, 06:41 AM   #10
serialk11r
Drives: '06 AM V8V Coupe
Really? Grrr...want 16" factory wheels!
Old 03-15-2012, 08:31 AM   #11
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
I'm kinda annoyed with manufacturers that implement in-wheel TPMS but then don't actually display the pressures on the IP. They should've gone the cheap route and simply used a rotational-delta calculation off the ABS sensors and saved everyone some money and headaches.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 03-15-2012, 09:24 AM   #12
neutron256
neutron256's Avatar
Agreed! I hate that my car knows the tire pressure, and tempeature of each wheel, but doesn't see fit to share that info with me. I do have a TPMS tool that reads the sensor ID's, Temp, and pressure which is really nice.
Old 04-06-2012, 04:07 PM   #13
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I hate TPMS. I'll just use a piece of electrical tape to cover the light.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 04-06-2012, 08:16 PM   #14
AX_FRS
Drives: 05 Ford Focus ZX4
I think that tire shops, or any shop that replaces tires really, has to put TPMS sensors in whatever wheels they sell you for your car if it is equipped with TPMS. There may be places that will go around it if you're just buying a set a wheels... but I'm not sure.
AX_FRS is offline   Reply With Quote
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
Auto Parking Sensors? Swancoat Scion FR-S / Toyota 86 GT86 General Forum 84 02-18-2012 02:01 AM
