Northwest AK, ID, OR, WA
Old 09-01-2015, 01:22 PM   #113
VitViper
Drives: '15 FRS
Originally Posted by stockysnail View Post
@johan @VitViper Looks like there's a larger throttle body available:
http://www.bulletproofautomotive.com...g-throttle-kit
Not sure how good it is or how well it would work however.
Way way too much money. I can source an 80mm Honda TB for $160 and machine my own adapter plate. It's not that hard to move two pins for the throttle plate full bridge control.
VitViper is offline   Reply With Quote
The Following 4 Users Say Thank You to VitViper For This Useful Post:
Decay107 (09-01-2015), sachu (09-01-2015), snidd111 (09-01-2015), stockysnail (09-01-2015)
Old 09-01-2015, 04:49 PM   #114
Before folks get all carried away on the TB, remember it only needs to be as big as the cross-sectional area of the compressor intake. Anything bigger would be a waste. Do we know that value?
Old 09-01-2015, 05:27 PM   #115
johan
Drives: '14 981CS, '99 NB1
Depends on the supercharger being used, depends on if said supercharger is -stock- as well. You're not really living until you've "modified" your mods.
johan is offline   Reply With Quote
Old 09-01-2015, 05:28 PM   #116
johan
Yeah the OEM Honda TB's would be a shoe in if we had an actual adapter plate that kept us from needing to rotate the TB. As it is, that rotation will likely cause some issues.
Old 09-01-2015, 07:12 PM   #117
I'm having a deja vu. Did we already have this conversation at a barbecue? My apologies for beating the horse.
Bottom line, for best performance, as long as the ECU is capable of keeping track of things at WOT, we want the compressor to see as close to ambient pressure as possible.
If the TB is oversize all that command and feedback resolution approaching WOT is wasted.
Old 09-02-2015, 12:18 AM   #118
johan
Yes, we did, at length - hence why this thread turned into ... this thread
I can't fathom the cross section of the supercharger body inlet being lesser than the stock TB, or any of the Honda TB's, by a long shot. Looking at this image - there's no chance in hell.
What I _am_ concerned about is the quality (as it relates to flow) of the throttle body inlet, which I believe you echo'd in our conversation. I've seen this time and time again on many different kits. Those inlets aren't designed with power growth in mind... they're designed to bolt up to OEM components... boo. Custom inlets are made all the time, if there is demand. If someone made a custom inlet that provided a much larger flange that could attach to larger throttle bodies, the flow through the supercharger would increase dramatically.
And as I was trying to elaborate on as well, resolution isn't an issue anymore with electronic throttle bodies. You can tune whatever resolution you want into the pedal. I did it on both of my old supercharger setups, and Vit does it all the time for high boost SC Hondas.
The only real thing to be concerned with is that the TB isn't so large that even at it's most closed position it doesn't let so much air into the engine that the car can't idle correctly.
Old 09-02-2015, 01:53 AM   #119
Ah, yes. It all comes back now. Perhaps naively, I was considering this inlet area.
It would be helpful to have actual performance data but I can't seem to find any.
Old 09-02-2015, 01:58 AM   #120
stockysnail
Just the tip
stockysnail's Avatar
If you guys tell me my Sprintex 210 blower sucks and I should get X supercharger, and you can all agree with technical reasons, I'll sell it (would need help taking it off), and get agreed upon supercharger.
Mike at Moto-East has been testing the 335 Sprintex on his car and he's saying it's gets really hot and that e85 or meth is ideal. I was considering the 335 kit since it would be an upgrade to my existing 210 kit, but I'm also open to selling the 210 kit and getting something with better engineering/potential.
Old 09-02-2015, 03:33 AM   #121
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
If thats your approach sell it now and get the Harrop much better design and a better supercharger
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 09-02-2015, 10:44 AM   #122
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
You should buy the cosworth, and just because I'd like to see one in person
Decay107 is offline   Reply With Quote
Old 09-02-2015, 12:02 PM   #123
johan
whoa....
I think I stand corrected. That's just... wow.
Josh - abandon ship.
The Following User Says Thank You to johan For This Useful Post:
stockysnail (09-02-2015)
Old 09-02-2015, 12:25 PM   #124
whoa....
To be fair, appearances can be deceiving. Given the shape, it can be pretty easy to figure out the area. I'm just not sure how that translates into throughput because of the relationship between the holes in that end plate and the screws themselves. It seems to be a standard solution. I've seen a few pictures of other blowers since getting involved in this. I am NOT a subject matter expert here.
Tell you what. I'll measure the compressor I have (not mine ) and figure out the inlet area just for those of us reading this. No conclusions. Just a dumb number.
Jonesy86 (09-02-2015)
Old 09-02-2015, 12:30 PM   #125
I don't think there's ANYTHING wrong with the Sprintex, per se. Yours especially is in great shape. Leave it alone. Enjoy it! Improvements are incremental. You would quickly get accustomed to the extra 15%-or-whatever and be searching for the next better thing.
The more I mess with it, the more I like the Sprintex. It's a sexy beast.
Decay107 (09-02-2015), Jonesy86 (09-02-2015), thehapaone (09-02-2015)
Old 09-04-2015, 01:51 PM   #126
j123ic
Drives: Evo 9
The intake cross sectional area of the E-Force 1320 is about 6,540mm^2
Measurement is taken from the exposed area of the TVS rotors only. Some parts of the rotors are obstructed with bearing and shaft supports. But it's significantly more open than the sprintex intake.
There's also plenty of meat on the TB flange for those of you interested in doing this. What is called the "Nose Drive" can easily be removed or separated from the supercharger to perform machining to properly port/enlarge the flange. The flange is ported to accept the OE throttle body ID of 66mm.
j123ic is offline   Reply With Quote
The Following 3 Users Say Thank You to j123ic For This Useful Post:
johan (09-04-2015), NotSoJDM (09-09-2015), Ultramaroon (09-04-2015)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
Tour of Edelbrock and their new Supercharger! August 28th The Racers Line Northern California 62 09-04-2015 02:59 PM
Edelbrock's Custom BRZ with SC Lonewolf Southern California 9 08-02-2015 05:17 PM
Thoughts on Kraftwerks C-Type Rotrex Supercharger Piper606 Scion FR-S / Toyota 86 GT86 General Forum 5 07-31-2015 09:59 AM
