Drives: Whiteout FRS
Cold start
Anyone else get a delayed start up primarily in the morning? It started happening after i switched to E85. I'm on the open flash tablet E85 UEL header tune if that matters. I've never had a failed start up and it works perfectly after the first one of the day.
#2 |
Drives: 2013 Ultramarine FR-S
Seems to be a common issue with E85. Wouldn't sweat it
https://www.google.com/search?q=e85+...UTF-8&hl=en-US |
| The Following User Says Thank You to Freeman For This Useful Post: | JG (08-25-2015) |
#3 |
If you search this you will find multiple threads talking about the effects of the cold with e85. LMGTFY
| The Following 2 Users Say Thank You to fika84 For This Useful Post: | JG (08-25-2015), shifter907 (08-25-2015) |
#4 | |
Senior Misanthrope
Still not a real fix, though. |
| The Following User Says Thank You to kch For This Useful Post: | JG (08-25-2015) |
#5 |
Gotcha. As long as it is not a huge problem i'm fine with it. Just had to check.
#6 |
Killed Scion
Drives: 2013 FR-S Whiteout
I had this same problem with my 03 wrx. I let my mom drive it for the first time and she did not click the ignition to let the fuel pump prime before turning on and it was the worst turnover i've ever heard. We drove down the street and i saw there was a check engine light on. It was 2 missfire codes for cylinders 1 and 3. I wiped it and never had that problem again. Then 3 weeks later I blew a head gasket >.< I don't think theyre related at all though.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#7 | |
Drives: FT86
copy them out of one of wayno's tunes see his thread here they are A01G/I tunes just copy the cranking ipw tables from tunes into yours C or D series E85 rom. will start first crank see thread here (use his definitions as well OFT Tunes for Automatic Transmission, E85 fuel economy and Stg1, Stg2 and BPB maps for 98RON .. Last edited by steve99; 08-25-2015 at 08:32 PM. |
#8 |
Drives: Toyota 86 GTS
The post start timing and maf adjustments help immensely also, to the point where it starts first crank at about 5C on most cars. After all that if it still takes 2 cranks, do the first with your foot flat on the throttle.
Also, this topic is in the wrong forum in addition to being redundant.
#9 | |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold start question | ggiddix | Engine, Exhaust, Transmission | 8 | 02-06-2015 10:27 PM |
| Cold weather start | oppiee | CANADA | 57 | 01-16-2015 03:20 PM |
| E85 cold start | Turdinator | Software Tuning | 8 | 08-29-2014 11:12 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
