Old 08-28-2015, 05:08 PM   #99
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by Shady195 View Post
Indeed it does, so long as it is installed by an ASE certified tech, or a dealer they will cover it for 3years/36000 miles IIRC from the purchase date.
Wow, I just read the full warranty and it is quite impressive. The mileage starts at 0 so, my car has 20K on it so would be covered for the next 16K; still not bad.
However, their exclusions appear to disallow most other mod:
ABUSE RELATED TO OVERLOADING, PCM RECALIBRATION, MISUSE, NEGLIGENCE, ROAD CONDITIONS, UNAPPROVED TIRE SIZE AND/OR TIRE COMPOUND, AND OTHER NON-EDELBROCK APPROVED MODIFICATIONS. EDELBROCK APPROVED MODIFICATIONS ARE LIMITED TO THE FOLLOWING: EXHAUST MODIFICATIONS BEYOND THE CATALYTIC CONVERTER (REFERRED TO AS CAT-BACK OR POST CAT); WHEEL AND TIRE MODIFICATIONS THAT ARE WITHIN FIFTEEN PERCENT (15%) OF OEM OR FACTORY EQUIPPED SIZE (MODIFIED TIRES ARE ONLY ALLOWABLE IF THEY ARE ONE HUNDRED PERCENT (100%) STREET COMPOUND).
So, gotta be careful on tire widths. I'm already screwed though given my suspension mod and I run r-comps at the track...
But, this tells me the stock drive train is quite robust! As others have already shown with the other kits out there.
Sleepless is offline   Reply With Quote
Old 08-28-2015, 05:31 PM   #100
ajc209
Drives: GT86 Cosworth
Originally Posted by dwx View Post
Harrop uses twin intercoolers, one on each side of the S/C. I think it's a better setup since with the IC sideways you can fit a relatively thick core in there.
...and the two in the harrop appear to be significantly smaller than the cossie sc setup.
ajc209 is offline   Reply With Quote
Old 08-28-2015, 05:57 PM   #101
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Any idea if they include a way to monitor post blower temps like edelbrock does?
Decay107 is offline   Reply With Quote
Old 08-28-2015, 06:05 PM   #102
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Much smaller.
Does anyone know why the flow rate of their water pump for the intercooler(s) is? I thought I read that in here somewhere but I can't find it now.... Damn mobile version.
Freeman is offline   Reply With Quote
Old 08-30-2015, 12:09 PM   #103
xwd
Yeah the Cosworth uses larger cores and also a quad-pass heat exchanger, the only one I know of. I keep trying to see if someone will sell me one without the kit but apparently not.
AWIC cores can vary wildly as well in terms of efficiency so bigger may not always be better.
The twin cores in my TRD supercharger are definitely not as thick as the Cosworth ones, but they are wider and taller which equals a bit more surface area.
The Following 2 Users Say Thank You to xwd For This Useful Post:
CSG Mike (08-31-2015), CxG (04-25-2016)
Old 08-30-2015, 04:43 PM   #104
350matt
Drives: toyota mr2/ Toyota GT86
why do you want the heat exhanger? Have you already got some kind of blower on there?
350matt is offline   Reply With Quote
Old 08-30-2015, 04:45 PM   #105
Freeman
Freeman's Avatar
he's the guy who bought the TRD supercharger. Also he mentions it in the text that you quoted.
The Following User Says Thank You to Freeman For This Useful Post:
Old 08-30-2015, 05:17 PM   #106
350matt
aaah
all ist Klaar
The Following User Says Thank You to 350matt For This Useful Post:
Freeman (08-30-2015)
Old 08-31-2015, 08:17 AM   #107
retrofit
Drives: Toyota 86
First time poster here
I've contacted Harrop and ordered a supercharger kit.
The kit will be installed and custom tuned at the Harrop performance centre. ETA late September or early October.
My car has been completely stock for more than 2 years. The original plan was to only install a supercharger kit as my first bang for buck mod, but since the Harrop kit is going to be custom tuned it makes more sense to add new exhaust as well.
What I'm looking for in the headers / exhaust, from most important to least:
  • Enough headroom for more boost in the future (after doing an engine build)
  • Quiet enough for a daily drive
  • Nice loud exhaust note when I need it (i.e. when revving the engine)
Any advice is much appreciated.
I'll be starting my own build thread soon
retrofit is offline   Reply With Quote
The Following 4 Users Say Thank You to retrofit For This Useful Post:
CSG Mike (08-31-2015), LucidMomentum (08-31-2015), nelsmar (08-31-2015), Panman (09-02-2015)
Old 08-31-2015, 01:24 PM   #108
jiaim
Drives: Enthusiast
Quiet exhaust : Scorpion of Milltek
jiaim is offline   Reply With Quote
Old 08-31-2015, 01:27 PM   #109
nelsmar
I just emailed Harrop asking if they will be distributing this in the US
My flickr - Canibeat
Local magazine scout
The Following 4 Users Say Thank You to nelsmar For This Useful Post:
ATL BRZ (09-04-2015), CSG Mike (08-31-2015), Freeman (08-31-2015), Toyota86.ir (02-23-2016)
Old 08-31-2015, 11:52 PM   #110
retrofit
Drives: Toyota 86
Wow, the Milltek primary catback sells for over AUD $3200.
I wasn't quite prepared to spend that much.
The following two which are sold locally in Australia seem to review ok for noise:
Perrin Cat Back Exhaust 2.5" for AUD $1150 ~USD $820
Invidia Q300 catback exhaust for AUD $1190 ~USD $850 or for AUD $1520 ~USD $1080 with high flow front pipe (catted).
Is the Invidia high flow front pipe worth the extra expense?
Will these two exhaust options above achieve my goals and is there anything else I should be checking out?
At this stage I'm too sure about which headers but will keep looking to see what's available locally.
Any suggestions are welcome.
Thanks in advance
Old 09-01-2015, 12:22 AM   #111
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Don't buy Miltek the weld crack one after the other I have had pretty all weld re done in the last year. I man at each connection of tube to silence so two weld per silencer and my millet have 3 of them but only one weld cracked on the back box so that's 5 time to the Welder.
just type milltek weld crack on google
Mars2 is offline   Reply With Quote
Old 09-01-2015, 12:34 AM   #112
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Corsa....
Color difference between Satin White Pearl (Pre-2015) and Halo White (Post-2015)? LucidMomentum Scion FR-S / Toyota 86 GT86 General Forum 3 10-15-2014 11:29 AM
To build something better in our own self image Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 29 07-07-2014 04:56 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
looking for silhouette frs image subaruferrucci FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 01-29-2013 06:00 PM
Image resizing blalor Site Announcements / Questions / Issues 28 11-03-2012 08:46 PM
