Old 08-23-2015, 10:46 PM   #2829
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I could use some help deciding on some new tires. I've decided to upgrade my Michelin PSS to Bridgestone RE71R's soon for AutoX. My PSS are 225's stretched onto a 9" rim which is far from ideal. For the RE71R's I'm stuck trying to decide between 245/40 R17 and 255/40 R17. I'm running Enkei RPF1's 17x9 +35 on RCE Yellow springs on the stock shocks. My front camber is currently at -2 using camber bolts. Would 255's actually fit without rubbing anywhere or should I go with the 245's?
smg1138 is offline   Reply With Quote
Old 08-28-2015, 08:33 AM   #2830
Bamsterman
Drives: 13' Scion FRS
Hi everyone!
I've done some research on a wheel setup and it looks like it'll "fit". I would just like to confirm and possibly get any pics of the setup, if available.
17x9 +30 245/40
Stock suspension for now, but will be lowering it soon. I know it'll poke at stock, so I might just wait till I lower it to put them on.
Thanks in advance!
Bamsterman is offline   Reply With Quote
Old 08-28-2015, 03:09 PM   #2831
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Bamsterman View Post
Hi everyone!
17x9 +30 245/40
Thanks in advance!
http://www.ft86club.com/forums/showthread.php?t=7533
These wheels are the same spec. The tires are 215's.
Old 08-28-2015, 07:19 PM   #2832
driftagoon
Drives: 13 FRS MT,11 wrx STi, 01Forester MT
I couldn't find a topic discussing what would be the maximum safe width of tire to go on stock wheels and an absolutely stock suspension.
Does anyone here happen to know or have seen anybody go with a wider tire on stock wheels and suspension without any rubbing on the fenders?
driftagoon is offline   Reply With Quote
Old 08-29-2015, 07:53 PM   #2833
ShaneLindley
Drives: 2015 Blue Pearl
Hi Guys,
Just bought a new '15 BRZ. Love this car! I'm sure it's been covered somewhere, but had a quick question that I was hoping to get help with since I am hoping to do this tomorrow....
I'm looking at picking up a set of 18x9 STR 522's with a 35mm offset wrapped with 245/40's. Does anybody see any fitment issues with this set-up on stock suspension??
Thanks for the help!!
Shane
ShaneLindley is offline   Reply With Quote
Old 08-29-2015, 09:00 PM   #2834
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by ShaneLindley View Post
Hi Guys,
Shane
The fronts might poke unless you add some camber to tuck them in
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 08-30-2015, 12:55 AM   #2835
ShaneLindley
Thanks. A little bit of poke is fine. I'm just worried about any kind of rubbing or caliper clearance. Anything functional that would interfere with this set-up. Thanks again.
Old 08-30-2015, 09:43 AM   #2836
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Hi I'm getting closer to order a set of Work Meisters S1 3P and think I will go get 18x9 instead of 18x8 that I was going too.
So will 18x9 43offset in front and 18x9 30offset in the rear, wraped in 245/35R18 all around, fit without rubbing? I'm lowered on TRD adjustable set with 1" drop atm.
Also I have checked with the calculator thing, and it looks it would be ok, but just want to be sure
Wheels in O-disk, link to work sizeing:
http://www.work-wheels.co.jp/catalog/pdf/52.pdf
Also I'm on stock camber settings after I still got the oem LCA, so no idea how much camber that got..
Teclis is offline   Reply With Quote
Old 08-30-2015, 07:53 PM   #2837
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Some report rubbing at full lock, but also is tire dependent. Look up the Enkei RPF1 17X9 thread for some info that might help you fitment
Old 08-31-2015, 12:33 AM   #2838
BCTV93
Drives: 13' FR-Slow.
I know someone posted about XXRs with a +20,
But I'm wondering if I get 18x9 +20 wheels on an Eibach Pro Kit drop, will there be any rub?
I don't know what tires to get yet, but I won't have LCAs or anything, not for awhile. There would be natural camber right?
BCTV93 is offline   Reply With Quote
Old 09-01-2015, 12:12 AM   #2839
impossible
Hi there,
Looking forward to buy some wheels and tires and want to know will there any effect if i upgrade coilover in the future and whats the pro and con on the offset.
1. 17x8 et35 225/45/17
2. 17x8 et45 225/45/17
in this setup is it just representing 1. is more flush and 2 is more tuck in? why do people prefer 35 over 45.
impossible is offline   Reply With Quote
Old 09-03-2015, 12:45 AM   #2840
infinity38
Drives: 2013 Toyota 86 GTS
Looking to find out if these will fit -
18x9.5 +39, Advan AD08R 265/35/18 with coilovers
infinity38 is offline   Reply With Quote
Old 09-03-2015, 02:35 PM   #2841
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=41083
The first page in this thread will describe exactly what is needed. For comparison , +39 is the same as +40. Though the advan tire runs wide, if i remember right.
Old 09-03-2015, 06:37 PM   #2842
BCTV93
Anyone?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
