View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 08-27-2015, 03:43 PM   #477
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
Their warranty says that they can't be run in colder temps yes.
oh NO!!!!
Anybody else have any suggestions for an Alaskan BRZ hoping to supercharge or turbo?
I don't plan on driving in the winter, but as far as cold temperatures - Alaskan has plenty of that. Well Juneau where i am from is mostly a rainforest, but nonetheless cold
mixedjuice is offline   Reply With Quote
Old 08-27-2015, 04:38 PM   #478
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
Originally Posted by mixedjuice View Post
oh NO!!!!
Jackson Racing and Kraftwerks are supposed to be fine.
Sent from my LG-H812 using Tapatalk
iJeff is offline   Reply With Quote
The Following 2 Users Say Thank You to iJeff For This Useful Post:
Astroboy (09-07-2015), mixedjuice (09-01-2015)
Old 08-27-2015, 05:37 PM   #479
350matt
Drives: toyota mr2/ Toyota GT86
so out of a sample of 190 ( 24+166 I'm not couting the 344 that aren't boosted)
24 went boom so 8% failure?
thats a pretty high failure rate
what would be useful to tally up is how much power / boost the 24 cases were running and with what hardware
350matt is offline   Reply With Quote
Old 08-27-2015, 05:49 PM   #480
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
A much higher percentage of the blown engines were right away when everyone was still figuring out the engines limits. I think it was as high as 1 out of 6 or 7 boosted engines was blown according to the poll. It seems to have gotten a lot better since then.
I think the first page of the thread has a decent amount of info on most of the blown cases.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 08-28-2015, 07:57 AM   #481
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Originally Posted by Astroboy View Post
That sprintex charger is holding up pretty good. I hope my avo holds up that well. How many miles in total on the car?
Sent from my LG-D850 using Tapatalk
I have about 55k miles and installed my supercharger at 30k
Books is offline   Reply With Quote
The Following User Says Thank You to Books For This Useful Post:
Astroboy (08-28-2015)
Old 08-28-2015, 10:07 AM   #482
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
that's assuming that (mostly) everyone with a boosted twin or blown engine posts on this forum and answers the poll. i wonder what the percentage of total twin members (total twin cars sold worldwide) are members of this particular forum. granted, those that boost are probably more likely to search forums for information than the 'regular' twin owners.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
CxG (10-25-2015)
Old 08-28-2015, 10:08 AM   #483
iJeff
iJeff's Avatar
There are quite a few blown motors that aren't listed here.
Old 08-28-2015, 10:14 AM   #484
shiumai
shiumai's Avatar
oh, most definitely. i'm just saying that it's sometimes hard to get accurate statistics or the big picture from forum polls. i wouldn't use this particular poll to estimate the chances of my motor blowing should i get boosted, but more for information on what the problem areas might be and what to look out for.
JS + BRZ (08-28-2015)
Old 08-28-2015, 10:15 AM   #485
iJeff
iJeff's Avatar
Yep I was in agreement with you.
The Following User Says Thank You to iJeff For This Useful Post:
shiumai (08-28-2015)
Old 08-28-2015, 10:16 AM   #486
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
With the high compression, I'd call e85 and an amazing tune requirements for boost if you want reliability. Don't cheap out on the tune and don't push the motor too hard on pump gas. Always get a local dyno tune when possible.
E-tuning, have them triple check data logs before any WOT runs. I've seen a lot of blown motors where they get their first e-tune, flash it, go out immediately beating on the car, then act surprised when it blows up. Never, ever, put 100% trust in to the first tune from an e-tuner regardless of their reputation. Every car is different and the safety from triple checking your tune is worth the time.
Reputable tuning companies such as Delicious offer free reviews with your tune. Use the reviews.
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Old 08-28-2015, 03:53 PM   #487
Astroboy
Astroboy's Avatar
Drives: None
So what if I'm on a conservative tune for 93oct and only pushing 250whp/200lbs, Is that on the safer side or should I switch to e85?
Astroboy is offline   Reply With Quote
Old 08-29-2015, 03:56 PM   #488
nelsmar
Meh unless you are on the track doing hot laps endlessly running on the street with pump gas on a conservative tune is going to be just fine. If the car was tuned to peak power and then a few degree's pulled in the end so that way there is plenty of room for poor quality gas and higher temperature conditions its just fine. E85 has better thermal properties as well as being more stable from the octane rating so you can be more lazy on the timing and not worry when you are being "conservative". Also doing lots of hot sessions ill be better on a race fuel or something with better thermal properties such as E85. If your happy with your power and it is conservative (IAM stays at 0 and knock feedback is minimal after getting the car nice and warm) then you are fine. Pushing more power out of the car with E85 is adding extra stress on the internal components.
When it comes to reliability for long term wear having a clean tune and lower power output is easier on the internals. When it comes to random catastrophic failure having a better quality fuel is a big player. So if you are trying to push the car to 300WHP on 91 octane which is pushing the envelope of the fuel... its pushing you in that catastrophic zone more so than doing a super light tune on E85 for the same horsepower (or pump 100 octane).
I would daily a car on 91 octane @ 250WHP all day every day. I have seen many cars locally run 20k+ miles without any issues at that power level even with iffy tunes showing minor knock feed back.
My flickr - Canibeat
Local magazine scout
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Astroboy (08-30-2015), GhostOp86 (08-31-2015)
Old 08-29-2015, 04:52 PM   #489
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
I'll +1 in the reply above and say you're fine. Anything more than moderate street driving at 300whp+, your motor will thank you for running e85.
Astroboy (08-29-2015)
Old 08-29-2015, 04:55 PM   #490
nelsmar
I try to tell people this all the time... But people get tunnel vision from what they read on the internet because people are pushing the absolute max and posting dynos. *sigh*.
The Following User Says Thank You to nelsmar For This Useful Post:
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
