Old 08-18-2015, 04:50 PM   #15
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by WhiteFRS69 View Post
do you have access to it when in storange???
my old car i would store it in my garage, didnt really do anything special to it, started it twice a week, rolled it outside, rolled it back in... called it a day
if you dont have access to it
http://www.edmunds.com/car-care/how-...m-storage.html
this is what i did for winter lol
when there is no salt on road, i just take her out for local road for 10-20min and come back
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
dnieves (08-18-2015)
Old 08-23-2015, 10:42 PM   #16
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
'I had a few questions about winter storage, I will be storing the car in my garage for winter and was wondering what steps I should take before storing.'
Turn the ignition key to the off position. If you really care about the car, remove the key, lock the doors, return in spring with the key.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Tcoat (08-24-2015)
Old 08-25-2015, 03:48 PM   #17
tinma
Drives: '13 BRZ
So what are peoples opinions on heater vs cold storage? I have the choice of renting out either of the two...but obviously cold storage is a lot cheaper.
tinma is offline   Reply With Quote
Old 08-25-2015, 03:52 PM   #18
There is no advantage over storing these cars in heated storage. Many of us use them and leave them out all winter with zero issues. The only benefit you would get from heated is you could comfortably work on the car (if that was even permitted and you had something you wanted to do to it).
Old 08-25-2015, 03:54 PM   #19
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Seeing as people park their cars outside in the snow all the time, I see no reason why cold storage isn't sufficient.
EDIT: Beat to the punch!
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
Tcoat (08-25-2015)
Old 08-25-2015, 04:05 PM   #20
kbye
kbye's Avatar
Drives: 2014 FR-S
Just don't leave your battery in cold storage... remove and keep it on a battery tender.
kbye is offline   Reply With Quote
Old 08-25-2015, 08:51 PM   #21
ls1ac
ls1ac's Avatar
I am a snow bird, I leave Wi. in the fall and go to Fl. for the winter.
When I leave I leave my cars in an unheated garage for six months each year. I leave a battery tender on each, not only to keep the battery charged but also to keep the computer memory in tacked. I make sure the antifreeze is good and I plug the chargers into a battery backup for computers. I learned this after a storm killed one of the chargers and the battery in the Lexus drained completely trying to keep the computer up. When I charged the battery and tried to run the car it "forgot" all kinds of things like how to put the windows up or down how to show the info on the screen and even how to shift gears. It was an expensive trip to the dealer.
One year I had to park one of the cars outside but ran a extension cord for the charger.
I have been doing this for several years with no problem(except as mentioned). [By keeping the charge up on the battery the acid will keep it from freezing.]
I do the same with the cars in Fl. but there humidity is also a problem.
Old 08-25-2015, 09:02 PM   #22
ls1ac
ls1ac's Avatar
Oh, I do put the new stable (blue) in the tank and filling it all the way up. The blue is meant for fuel with alcohol in it. And I put cars with soft performance tires on the curved roll around movers from Harbor freight, it seems to help with flat spoting.
Old 08-26-2015, 12:07 PM   #23
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Originally Posted by Newtothegrounds View Post
Hey all, I'm new to the 86 world just bought a 2016 last week and waiting for it to arrive. I had a few questions about winter storage, I will be storing the car in my garage for winter and was wondering what steps I should take before storing. Also is it worth getting an undercoating if it won't be driven in the winter? Thanks for any help
Last winter I put Stabilizer in a full tank, put the car up on the curved roller stands, and put the battery on charge. If you're worried about pests (mice) i put steel wool in the tail pipes and dryer sheets around the tires, intake, and interior to prevent them from getting in. She sat for 4 months and fired up and drove great with no problems.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 08-26-2015, 12:14 PM   #24
jvincent
jvincent's Avatar
Drive it!
This.
The Following User Says Thank You to jvincent For This Useful Post:
Tcoat (08-26-2015)
Old 08-26-2015, 12:14 PM   #25
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
I've been parking my cars over winter for the last 5 years and it will typically be:
- Fill gas up
- Clean it nicely so nothing is sitting on the surface of the paint for months
- Vacuum interior - again so nothing is sitting there causing weird smells
- Hook a trickle charger up to the battery
- Put a bowl of baking soda inside on the center console/seat to keep the interior smelling fresh
- Either put it on jacks with e-brake down or put blocks of wood behind the tires if it's not on jacks and put e-brake down.
- Cover it up.
Voila. This is Canadian winter too - so it's typically in storage (for me) from October to April.
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
Old 08-26-2015, 12:41 PM   #26
fridayfrs
Drives: Frs
This is pretty much what I do as well but since I'm in a wooded area and critters are a constant battle I also have glue traps in a complete square around the car. It's a bit anal but dead mice smell in the car is horrible.
I also stick in a couple refrigerator packs of baking soda. They don't spill if you're absent minded.
fridayfrs is offline   Reply With Quote
Winter Storage xia Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 10-06-2013 10:04 PM
Winter Storage Luke.Cariveau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 11-18-2012 06:15 PM
Change oil before or after winter storage... or both? switchlanez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-07-2012 04:30 PM
Winter storage procedure wbradley DIY (Do-It-Yourself) Guides 20 10-31-2012 12:49 AM
Winter storage Skye BRZ First-Gen (2012+) — General Topics 7 10-03-2012 09:02 PM
