Old 11-17-2012, 02:19 PM   #1
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
Post Winter Storage
Just wondering if my winter storage will be sufficient.
I will be putting the car away for about 4 months. In a storage unit (Not heated)
I've bought a batter tender (Trickle charge) and will be pulling the battery.
Other than that I've made sure the tires are properly inflated and will be running
some fuel stabilizer through the engine with a full tank of gas.
Just wondering.
1.) With pulling the battery for that long will the ECU be changed at all when I pull it back out?
2.) Is there any other precautions I'm missing?
3.) Recommend that I change any fluids when I take it back out?
Thanks for any input!
Luke.Cariveau is offline   Reply With Quote
Old 11-17-2012, 02:38 PM   #2
BRZranger
4 months?! You have a lot of restraint! The only time I plan on storing away is when the snow sticks more than 2”, but there is always that increased risk.
What are you going to drive instead?
BRZranger is offline   Reply With Quote
Old 11-17-2012, 02:59 PM   #3
Luke.Cariveau
Drives: 13' BRZ
Well, With 2 cars I would much rather keep the BRZ like new =)
Old 11-17-2012, 03:09 PM   #4
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Be sure to change your engine oil and flush your coolant system when you decide to drive it after those 4 months.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-17-2012, 03:46 PM   #5
ScionRacer
ScionRacer's Avatar
Drives: 2013 Scion FR-S Ultramarine
I usually run my tank almost empty and air the tires up to max tire pressure.I tried the stabilizer years ago and the gas still loses enough that it caused driveability issues. Now I drive em till empty,then throw in 5 gallons of super in the spring. It takes too long to burn through those bad tanks.
I like to disconnect the battery and throw an area rug or carpet remnant under car.Keeps the moisture down from the floor.Plastic sheeting works too.
ScionRacer is offline   Reply With Quote
Old 11-17-2012, 04:12 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
DO NOT leave the gas tank empty (or even close to empty for that matter) as moisture will build up in there! Moisture = Rust...
Fill it all the way up, add fuel stabilizers, and when it's time to bring it back on the road...
Just power the fuel pump and pump out all the gas into a container (via disconnecting the fuel line) instead of burning it in your engine.
2000 MR-S 5MT
2010-2012
Old 11-17-2012, 04:22 PM   #7
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I store 3-4 cars every winter (including the BRZ now) for 4-5 months. I do occasionally drive them if the roads are completely clear of salt, slush, snow, ice, etc, and the temps are above 35°F. Usually the cars don't get a full tank of gas run through them in that time, and if the weather is bad enough for long enough, they won't get driven or started for 2+ months at a time.
I always fill them up with gas before storing them, slightly overinflate the tires, and that is usually it. If I have a smaller than stock battery in them, I may put on a Battery Tender occasionally, but that's it. Never had a problem with any of my cars this way, and I've been doing it this way for years.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 11-18-2012, 02:07 PM   #8
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Pretty much same here except I added a step. Had a set of BFG KDW-II's that didn't like being parked more than just a week.
Stabil in the fuel, tender on the battery, over inflate tires a bit and roll the car 4-6 inches forward or back every few weeks or so. Never a problem.
Never had a problem with Stabil either..
CircuitJerk is offline   Reply With Quote
Old 11-18-2012, 02:10 PM   #9
DaJo
FT86Club Vancouver
DaJo's Avatar
If it's that bad, just lift it on jack-stands lol
2000 MR-S 5MT
2010-2012
Old 11-18-2012, 02:36 PM   #10
CircuitJerk
Pull my finger...
Maybe I will, maybe I won't..
LOL
Old 11-18-2012, 04:54 PM   #11
Miniata
Yeah, I forgot to mention, I do on occasion roll the cars forward/back a half rotation of the tires if they're going to be sitting for more than 2-3 weeks at a time. Pretty much all of my tires get temporary flat spots after sitting for more than a week, but they always go away in the first 5-10 miles of driving.
Old 11-18-2012, 06:15 PM   #12
Luke.Cariveau
Drives: 13' BRZ
Thanks for the input guys. Seem's like I just missed a few things.
Change oil before or after winter storage... or both? switchlanez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-07-2012 04:30 PM
Last shot before storage Xangvang BRZ Photos, Videos, Wallpapers, Gallery Forum 1 11-07-2012 01:29 AM
Winter storage procedure wbradley DIY (Do-It-Yourself) Guides 20 10-31-2012 12:49 AM
Winter storage Skye BRZ First-Gen (2012+) — General Topics 7 10-03-2012 09:02 PM
storage? subaruferrucci Scion FR-S / Toyota 86 GT86 General Forum 3 06-11-2012 03:50 PM
