| Software Tuning Discuss all software tuning topics. |
#29 | |
Se๑or Member
1974 TA22 Celica
2013 86 GT |
#30 | |
Drives: FT86
they did not max out the load limits on the g roms so you should be fine anyway. if you use wayno tune and good maf scaling you will be even better |
#31 |
Drives: Toyota 86 GTS
In my thread
#32 | |
Drives: UK GT86
.: Stealth 86 :.
#33 | |
Se๑or Member
I don't suffer from the dead spot mentioned in this thread but after flashing back to the stock ROM recently I noticed taking off from a stop was much easier and I was looking into why when I noticed my definitions were missing the above.
1974 TA22 Celica
2013 86 GT |
#34 |
[||]=(86)=[||]
Drives: 2017 Toyota 86
Hi guys! Got the same problem...
2015 Scion FR-S - Stock tune with EcuTek P0420 removal. Injen intake (got it for really cheap for testing, no hate here please) OEM headers with gutted cat Nameless FP/OP combo If I WOT in between 1200-1800 rpm the engine really want to die out. Because of the de-cat and the intake, not-that-nice noise are going out from the exhaust and intake. For the one who have the problem, check your MAF g/s or voltage data. Just a quick look at mine: I'm not saying it's the problem but it could be intake resonance that make the MAF freak out from the modified snorkel/aftermarket intake. My logs must be worst because of the "great design" of the Injen intake. EDIT: Just for fun, before I'll do the logging for the intake rescalling I've try the @Shiv@Openflash fuel map and It really soften the problem! Thanks
#35 | |
Drives: UK GT86
Seeing those MAF readings I do wonder if load limits are an issue as well as the intake. Moral for the story, don't go WOT at low RPM
.: Stealth 86 :.
#36 | |
[||]=(86)=[||]
You know the kind of "oh ok got just the time to pass" you floor it in low RPM range and the car just die -_-
#37 |
Drives: 2014 GT86
Never had problem of 'car just die' with WOT@low rpms (on still stock car). Slow acceleration - yes, but 'die'? Of course i judge only by by hearing, that engine sounds normally from 1600 and up, but never saw any problems using low rpms (starting these rpms) at least while steady cruising at whichever the gear in. 1500 has noticeably different sound in upper gears, hence i always downshift, if required to go lower, but above - seems just fine to me.
#38 | |
Drives: FT86
log the fuel trims and AFR when you go wot at low rpm its likely going rearly rich once you fix the maf scaling the problem will likely go away |
#39 | |
[||]=(86)=[||]
But well I could be wrong I'm begening to play with my ECU
#40 | |
Drives: FT86
#41 | |
[||]=(86)=[||]
![]() With the Fuel map modification @Shiv@Openflash proposed it's really near perfect. In 1st gear WOT at 1500-1800 it's near perfect, in 2nd it only feel like a normal engine in 2nd gear in low rpm, 3rd and 4th same thing.
#42 |
Drives: 2013 Scion FR-S 6M Argento
@Shiv@Openflash what if you experience this flat spot on the 93 stage 2 tune?
| Throttle Dead Spot? | jm1681 | Issues | Warranty | Recalls / TSB | 25 | 03-10-2014 09:37 PM |
| Dead spot when changing from 1st to 2nd? | Mike Hoxbig | AFRICA | 13 | 02-25-2013 10:58 AM |
| Installed exhaust and Intake, pedal dead spot. How long does it last | jflogerzi | Engine, Exhaust, Transmission | 24 | 02-23-2013 05:11 PM |
