Drives: Toyota 86 High 6MT
Dead spot when changing from 1st to 2nd?
Hey guys, has anyone experienced a dead spot when snap-changing from 1st to 2nd? I've noticed this happen even in Sport mode, so traction control would have been off. It's happened to me twice so far - changing up from 1st at about 7,000, it moves to about 5,000 in second which should be in the optimal power band, but went dead before coming alive again.
Official anti-BS squad
Nope, snap changing from 1st to 2nd results in the rear wheels spinning up, no flat spots...
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#3 | |
Drives: Skoda Yeti DSG diesel 4x4
Mine had a throttle delay that gradually improved and was good by about 1,000km. Could it be that, with the ECU learning? |
About 2,500 km, engine has already been run in
doesn't happen all the time, but I've noticed it twice so far.
Thanks I'll try that, although its not really suitable for everyday driving. The bit I'm confused about is that when you put in in sports mode, the indicator light on the dash shows traction control being off, with only stability control being in sports mode.
#7 | |
In sports mode the stability control might still cut the power if the back wheels were losing it big time? |
Drives: Toyota 86, Pearl White, Manual
Manual says in sports mode SC is still on but less sensitive...?
Drives: Argento FR-S 86
How do you turn the feature on properly? Is it just a matter for pressing the button?
Argento ate6 |
#10 |
Hold Traction Control (left button) in for 3 seconds and all are completely off. Press same button once when stationary and TC is off untill you get to 50kmph (for mud and snow). Press Sport button (right) once and Sport mode is on...
Sent from my GT-I9100 using Tapatalk 2 |
#11 | |
Got sidetracked halfway through and missed you had already answered.[good colour choice] |
#12 |
Vcs/sport button? Hold it down or the trac button?
Argento ate6 |
#13 |
Drives: Toyota 86 - Silver High Spec
Hi Mike
I haven't noticed any issues on mine either. Like Sav, I happily spin from 1st to 2nd and even 2nd to 3rd without dead spots and with nanny aids on. Sounds like it might be a fuel injection issue which i've heard is also responsible for the Check Engine Light (CEL) issue that a lot of other members are experiencing. What might be useful is, if you have a smart phone, to get yourself an OBD ii device and see if the car is reporting any error codes?I think that if it were the nanny controls causing this then they'd be flashing whenever this issue occurred. Good luck. |
#14 |
The voice of reason...
Drives: 2012 Toyota 86 6MT Standard
Is this a flat spot? I have found giving it a blip between changes my compensate. My first test drive was met with the dealer power-shifting aggressively. the car had less than 100km!
| The Walking Dead | DIM | Off-Topic Lounge [WARNING: NO POLITICS] | 286 | 11-02-2014 11:19 PM |
| Installed exhaust and Intake, pedal dead spot. How long does it last | jflogerzi | Engine, Exhaust, Transmission | 24 | 02-23-2013 05:11 PM |
| New Parking Spot | raul | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2012 12:42 AM |
| spot cleaning | jarviz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 07-26-2012 06:12 PM |
| g35 brought from the dead | bryansbestwax | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 06-25-2012 11:22 PM |
