Old 04-22-2015, 02:53 PM   #1
joneze93tsi
Drives: 14 BRZED
OFT Dead Spot 1000-1700
This is something I've only just recently noticed, and as a result, was able to duplicate. I flashed back to E85 for the spring on V2.063 EL (stock header).
Between 1000rpm to roughly 1500-1700 their appears to be a black hole when you get into OL fueling.
If I short shift into 2nd and the rpm's drop into that threshold and I squeeze the throttle into OL the car just sort of stops accelerating and just sort of hesitates and literally decelerates despite being at 100% WOT. If I back the throttle back into CL range it starts accelerating again.
Almost feels like a black whole..sort of funny actually. I'm almost never usually in that range but was turning around in a parking lot the other day in 2nd gear and the car almost just stopped. I can reproduce it in any gear, as long as I'm in that RPM range and get out of CL into OL fueling.
Anybod else ever seen this?
joneze93tsi is offline   Reply With Quote
Old 04-22-2015, 03:09 PM   #2
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
I'm also on the OFT e85 EL tune, however I haven't noticed this. Post a datalog so we can see whats happening. If you're feeling it fall on its face then something is definitely wrong.
I don't remember this happening to me doing 2nd gear pulls from 1.5k RPM.
BRZoomTX is offline   Reply With Quote
Old 04-22-2015, 03:54 PM   #3
joneze93tsi
Drives: 14 BRZED
http://www.datazap.me/u/joneze93tsi/...7-8-9-10-12-13
I don't see anything out of the ordinary other than lack of ignition advance.
It just flops
Old 04-22-2015, 04:14 PM   #4
carlitosway6891
Drives: white out project fr-s
interesting mine does the same exact thing.....i cant WOT until the rpm is past 2k....if i do, the car struggles to accelerate...other than that, pulls really strong. im on the stage one 93 UEL map
carlitosway6891 is offline   Reply With Quote
Old 04-22-2015, 04:18 PM   #5
joneze93tsi
Drives: 14 BRZED
Maybe I just need to spend more time in OL in that rpm range and let it adapt further. Truth be told, it's so rare that I'm even in that range that it's probably spent almost no time there.
Old 04-22-2015, 04:23 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
I don't see how that would help, there's no "adapting" going on. To me the fact that the ignition timing drops to 0 degrees and then stays there is more than likely the cause. However, I have no idea why without seeing the tune.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-22-2015, 04:27 PM   #7
joneze93tsi
Drives: 14 BRZED
http://columbusht.com/Stg%202%20EL%2...01C_V2.063.bin
That's the file I current have loaded. Been at least 1500 miles since I've flashed it runs exceptionally well outside of this small issue, which really may not rear itself again for a 3 months lol.
Old 04-22-2015, 04:36 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
Nothing in the tune shows any reason why that should be happening. It's quite odd. It clearly stays at 0 degrees advance though.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-22-2015, 04:36 PM   #9
joneze93tsi
Drives: 14 BRZED
¯\_(ツ)_/¯
Old 04-22-2015, 08:11 PM   #10
steve99
Suspect it load limit.
op dude can you log engine load instead of vvt cam angles.
Old 04-22-2015, 08:13 PM   #11
steve99
@joneze93tsi can yoy log engine load instead of vvt cam angles, you might be hitting a load limit from memory think it something like 1.35. at lower rpm
do you have stock intake ?
Old 04-22-2015, 08:24 PM   #12
joneze93tsi
Drives: 14 BRZED
I can do another one shortly.
I have the "shiv" modified snorkel and a drop-in filter, that's in intake wise.
Old 04-22-2015, 08:54 PM   #13
joneze93tsi
Drives: 14 BRZED
http://www.datazap.me/u/joneze93tsi/...1-2-3-6-8-9-10
I went in and out of this condition several times, with load logged as well.
Old 04-22-2015, 09:03 PM   #14
joneze93tsi
Drives: 14 BRZED
Ignition advance seems to disappear beyond 1.3 load, I think you are onto something..
Throttle Dead Spot? jm1681 Issues | Warranty | Recalls / TSB 25 03-10-2014 10:37 PM
Dead spot when changing from 1st to 2nd? Mike Hoxbig AFRICA 13 02-25-2013 11:58 AM
Installed exhaust and Intake, pedal dead spot. How long does it last jflogerzi Engine, Exhaust, Transmission 24 02-23-2013 06:11 PM
