Northwest AK, ID, OR, WA
Old 08-22-2015, 06:58 PM   #57
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 4 Users Say Thank You to Aztec For This Useful Post:
CSG Mike (08-24-2015), Decay107 (08-22-2015), Porcupint (08-23-2015), Toyota86.ir (02-17-2016)
Old 08-22-2015, 07:03 PM   #58
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by Aztec View Post
If you'd come to Pat's Acres, you would know this conversation is 100% on topic right now
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
johan (08-22-2015), Ultramaroon (08-22-2015)
Old 08-22-2015, 07:10 PM   #59
johan
Drives: '14 981CS, '99 NB1
Alright, I did this - no dice. Possible we missed something?
(sharpie on 1W so I don't get them mixed up)
johan is offline   Reply With Quote
Old 08-22-2015, 07:11 PM   #60
Aztec
Aztec's Avatar
Haha I WOULD have but I was out of town :p
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
Old 08-22-2015, 07:15 PM   #61
johan
Maybe Honda's pin 1 = Subaru's pin 6 on the connector? So we have it exactly backwards?
Old 08-22-2015, 07:18 PM   #62
johan
Which ironically would have meant all I had to do was swap 1/2
Old 08-22-2015, 07:20 PM   #63
Decay107
Decay107's Avatar
Perhaps they operate on different DC voltages? Check the voltage of Black/Blue, confirm that is what the Honda TB expects to see. After that we may have either the TPS (white and white/red) or the throttle plate (white/sharpie and red) swapped
Possible, maybe compare to a picture of a Honda wiring harness to confirm layout?
Old 08-22-2015, 07:30 PM   #64
johan
Well, one thing that tipped me off ... there's actually a correlation between the pins on the TB side and the pins in the harness - like they're different color metals. 2 / 4 - i.e. 2 for tb, 4 for tps - and this color differential is existent on both TBs and the wire harness - I am struggling to see that as coincidental.
Old 08-22-2015, 07:32 PM   #65
Decay107
Decay107's Avatar
or maybe 2 power and 4 signal...
Old 08-22-2015, 07:39 PM   #66
johan
Well....
[ame="https://www.youtube.com/watch?v=Uqs3suHl2Po"]OEM K20Z3 Throttlebody working on Scion FR-S - YouTube[/ame]
The Following 2 Users Say Thank You to johan For This Useful Post:
Decay107 (08-22-2015), sachu (08-22-2015)
Old 08-22-2015, 07:41 PM   #67
johan
Now I need a damned ECUTek cable so I can make sure the ECU is getting a good TPS signal.
Old 08-22-2015, 07:57 PM   #68
Decay107 (08-22-2015), raven1231 (08-23-2015)
Old 08-22-2015, 08:25 PM   #69
johan
I found my OBDII Diag cable and connected it. ECU is getting TPS, not throwing any codes.... now. Do have 4 lovely fuck-your-couch permanent codes from earlier when the wiring harness was inverted and the TPS was 100% ass backwards. ECUTek will probably wipe those with an ECU flash, but yeah - that's fun.
I did some datalogs of the TPS with both the K20 and FA20 - going to analyze them and see if there's any weirdness.
....and yes, after all this - car still runs fine.
8686 (08-23-2015), Decay107 (08-22-2015)
Old 08-22-2015, 08:38 PM   #70
johan
Screenshots from Excel. I don't see anything concerning here... almost identical readings - well within margin of error.
OEM TB:
K20 TB:
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
Tour of Edelbrock and their new Supercharger! August 28th The Racers Line Northern California 62 09-04-2015 02:59 PM
Edelbrock's Custom BRZ with SC Lonewolf Southern California 9 08-02-2015 05:17 PM
Thoughts on Kraftwerks C-Type Rotrex Supercharger Piper606 Scion FR-S / Toyota 86 GT86 General Forum 5 07-31-2015 09:59 AM
