| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
Drives: Hydra EMS Powered FRS Raven Black
BC Racing Time Attack FRS at Ultimate Track Car Challenge Video
Ultimate Track Car Challenge 2015
![]() From Le Mans spec prototypes to classic vintage racers the Ultimate Track Car challenge lets you compete head to head with some of the fastest cars in the USA. This year the Ultimate Track Car Challenge takes place at Virginia International Raceway where BC Racing NA sponsored driver Phil Grabow competes with some of the best in his Scion FRS. Great video by BC Racing and I wish I could have embedded it but the link is worth a watch! https://www.facebook.com/BCRacingNA/...01089733256551 ![]() ![]()
| The Following 8 Users Say Thank You to Element Tuning For This Useful Post: | DarkSunrise (08-13-2015), DustinS (08-13-2015), fstlane (08-14-2015), hmong337 (08-14-2015), Jonsey (08-14-2015), M1K3 (08-14-2015), Nigelr32 (08-16-2015), SnapOv3st3r (10-14-2015) |
#2 |
Tim,
Here are the basics: Element Tuning Pro Comp Motor (Forged internals, internal oiling mods, big valve heads, secure rockers, and ET Lil accumulator kit, 9k rpm) Hydra EMS, WB kit, and ET boost control ET Custom valved BC Racing ZR 3 way coilovers and Swift Springs Perrin Performance Oil Cooler, strut bar, PSR kit, Steering rack lock down, strut bar, motor mounts, shift knob, 3" exhaust, and over pipe Whiteline sway bar, diff bushings, rear control arm bushings, toe rods, and front bump steer kit Ma-Motorsports Roll Cage RR Racing Brake Kit Garrett 60 trim turbocharger Element Tuning custom radiator Element Tuning custom transmission cooler ....and a whole lot more custom and I'm sure I forgot a thing or two Speedesign custom graphics The car is in TT2 trim currently. Last edited by Element Tuning; 08-14-2015 at 09:25 AM. |
| The Following 2 Users Say Thank You to Element Tuning For This Useful Post: | DustinS (08-17-2015) |
#3 |
Great job Phil. Do you think think there's a sub-2:00 time in the car if you resolve your oiling issue? Seems like you'd be really competitive in the TT2 class if I'm not mistaken.
BTW love watching you drive. Any more in-car video?
2022 BRZ Build 2013 FR-S Build |
#4 | |
I actually have the NASA TT2 lap record at VIR with a 1:58 in this FRS. We had the car way detuned to get through the event in one piece. Transmission and oil pressure are still a problem at higher power levels under racing conditions. Last edited by Element Tuning; 08-14-2015 at 10:54 AM. |
| The Following 2 Users Say Thank You to Element Tuning For This Useful Post: | DarkSunrise (08-14-2015), Ultramaroon (08-16-2015) |
#5 | |
A dry sump will be fitted to this car before it returns to the track so we had the car very detuned for this event (maybe 340 whp in gears 1-4 and a little more in 5th and 6th). The current wing angle delivers about 600 lbs of DF at 100 mph but can exceed 1200 lbs at higher speeds. |
#6 |
Tim, the actual split is not likely something we'll publish but I was critical in getting the oem ABS system to be raceable on a car like this. Depending on the kit you buy the split varies but the full front and rear racing kit has the biggest bias change so it's really needed for track setup suspension on slicks and with downforce.
We haven't finished the dry sump yet since most have enough oil pressure with our motor build as is since many of the high power guys don't road race. We've pushed 500 whp at only 19 psi on the dyno to 9k rpm and still had 80 psi of oil pressure. |
#7 |
Drives: '14 GT86 project, '13 GT86 DD
May I ask, why are you determined to keep the ABS? See my posts on here in the chassis/ braking section regarding ABS modification vs removal. Perhaps you could have some valid input??
I could well be in the market for a dry sump kit for my project. Are the oiling issues here just surge or are they pump related?
#8 |
in orbe terrum non visi
Drives: violent
Want to sell a wing?
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#9 | |
Sorry for the late replies as I was out of the country getting a little R&R. Grass Roots Motorsports Magazine released the full lap video of the BC Racing Element Tuning FRS at UTCC VIR.
https://www.facebook.com/grassrootsm...type=2&theater No but it's all custom. A heads up however is that whole wing assembly and mounts would approach $4k. It's a rea1 motorsports dry carbon wing so it's pricey. I'm sure you could make something for about $1k less. Quote:
If I'm going to forgo ABS I'll do it with a pedal box and two brake master cylinders. I'm starting to feel the ABS problem isn't completely brake related and more the entire "Stability Control" system freaking out and turning off the ABS. The system will fault on my car even when no excessive brake force is used but I'm jumping curbs aggressively. I have a OBD module one of the racers from FT86 Factory gave to force "Pedal Dance" and it does that where I could never get pedal dance to work but I'm still able to drive in a way to defeat the pedal dance. The main oiling issue is just pressure/volume related and not oil starvation. Thanks, Phil Grabow Last edited by Element Tuning; 08-21-2015 at 07:22 PM. Reason: my phone spells worse than I do |
#10 |
Thanks for your great reply there Phil.
I have bought a Tilton bias pedal box with reverse mount under foot master cylinders. Tilton 72-616 is the p/n. I still don't know if I'll keep the ABS, especially after reading what you have written above about it bombing out on track!!
#11 | |
Ultimately I would like to understand more about the "ABS/Stability" fault. The brakes feel really balanced now so I just don't think that is the number one reason for the fault anymore. I might step down a friction just so I have more pedal control. With a pedal box I would definitely use a smaller front master than OEM! I don't think the stability control system (even though it's off) likes the wheel speed data I'm giving it by jumping all the curbs. In the end having consistent brake feel is more important than the ABS. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | Nigelr32 (08-22-2015) |
#12 |
Looks like GRM put up a Youtube version also:
I give up...don't why it won't show the video here. |
#13 |
Just for everyones info.. the stock master is two 1 inch pistons in series, diagonally split. The clutch master is 11/16 inch.
I will be starting with 0.7 inch bore on all three as a start.
#14 |
crew chief
Drives: Race car FR-S
@Nigelr32 i don't want to highjack the thread but Nigel you might want to put a bigger cylinder for the rear as for equal pressure on the pedal the rear will get less pressure, considering the pistons on the rear are moving less fluid, you could have a more balanced setup without having to go to the extreme with the balance bar and not having any play left to adjust.
do some search on the web on this subject, i have 0,7 rear and 0,625 front. |
| World Time Attack Challenge 2014 | Sideways&Smiling | Other Vehicles & General Automotive Discussions | 5 | 10-21-2014 01:28 AM |
| FT-86 SpeedFactory at Ultimate Track Car Challenge 2014 | Lonewolf | Tracking / Autocross / HPDE / Drifting | 3 | 07-29-2014 03:06 AM |
| AJ BRZ Global Time Attack 1:58.82 Video ! | AJ PwR | BRZ Photos, Videos, Wallpapers, Gallery Forum | 6 | 12-13-2013 01:56 PM |
| 2012 Ultimate Track Car Challenge meets BRZ/FRS | Element Tuning | Tracking / Autocross / HPDE / Drifting | 9 | 07-20-2013 09:24 AM |
| GReddy Racing Team - Time Attack tC chases Drift FRS at Scion Racing Track Day | ShoGun | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 01-06-2013 11:13 PM |
