Old 05-30-2013, 04:33 PM   #43
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
damm glad it worked out easy.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
davtbaum (05-31-2013)
Old 05-31-2013, 01:01 AM   #44
Frozen_skidmark
Frozen_skidmark's Avatar
Drives: Whiteout FRS
Yeah stay away from the orange can of doom... there have been known issues of filter material breaking down and plugging off oil galleries. A lot of Ford f150 owners found this out the hard way, and suprise no warranty!
http://www.ford-trucks.com/forums/97...tting-oil.html
Always go OEM filters!
2014 Whiteout FRS
Frozen_skidmark is offline   Reply With Quote
Old 05-31-2013, 09:16 AM   #45
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Nice E30 bro. Could definitely be treated to a new roundel though.
Haha it's actually a friend's. And I know I've been telling him the same thing! Awesome car though
davtbaum is offline   Reply With Quote
Old 08-17-2015, 07:01 AM   #46
Philly758
Drives: GMC
Originally Posted by davtbaum View Post
A comparison with the old bolt
Getting the new union on was trivial, torquing to 33.2 ft lbs. Installing the filter afterwards was as simple as a normal oil change
Got my car running again - thanks guys!
Old post, but quick question... Does it matter which end of the OEM filter connector you install? Is one side longer than the other?
I removed a Forester XT oil cooler to return it to stock and am getting some strange oil pressre issues. Thinking I may have installed it upside down and restricting the flow? But it does look like both sides are the same...
Philly758 is offline   Reply With Quote
Old 08-17-2015, 09:52 PM   #47
pantdino
Drives: Firestorm 2013 FR-S
The union looks just like the one that simply unscrews in my Fiat. Why would it have that hex shape if it were a part of the filter base casting and didn't unscrew?
Hard to tell if the threads on the union are OK or just have bits of metal from the filter in them. I would probably replace it unless you can't find a part. The Subie or Toyota dealer probably have them in stock in case one of their techs ruins one.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 08-17-2015, 11:04 PM   #48
pantdino
The threads look similar but are not the same. So it is not possible to install it upside down.
Old 08-17-2015, 11:14 PM   #49
pantdino
Nice work on the part numbers and PDF Opie. Don't He-Man your new oil filter on next time OP. General rule is turn till seated and then a 1/4 turn. You should be able to get the filter back off without the use of a tool if torqued properly.
Every filter I have seen says 2/3 to 3/4 turn after seated. But of course "seated" is a relative term. If you use the point at which there is the slightest contact of rubber to metal I've found the 2/3 to 3/4 turn rule to be true.
I always try to back it off by hand immediately after installing it to judge how tight it is. If you have to try your hardest to get it to move its too tight to leave it that way, but if it takes hardly any effort its too loose.
You CAN lose an engine if the filter unscrews and pops off at high revs.
Old 08-18-2015, 02:08 AM   #50
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by pantdino View Post
Every filter I have seen says 2/3 to 3/4 turn after seated. If you use the point at which there is the slightest contact of rubber to metal I've found the 2/3 to 3/4 turn rule to be true.
Depends on car. Mini Cooper (2006) I changed oil on barely tightens and it's good to go, my old AE86 I had to tighten that S0B for days. What I do is tighten 1/3(?), drive it bit, check when cool and tighten rest (2/3-3/4). Haven't had problems.
With Fram, that pos filters always melt in my hands. I use more pricy ones.
Old 08-18-2015, 10:13 AM   #51
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You might be right about 3/4 of a turn. I know some S2000 guys have had filters come off while on track. Just don't He-Man it on and you should be fine.
Old 08-18-2015, 10:42 AM   #52
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Best advise on the whole forum!!! haha!!
Old 08-19-2015, 08:36 AM   #53
BRZnut
Drives: BRZ DGM Limited
since Corp office always seems to find a reason to deny warranty claims, and the OEM filters are not expensive, always use a OEM oil filter!
Old 06-03-2017, 01:10 PM   #54
The2nd_Noel
Drives: Scion FR-S Whiteout
Here are the pics - the first image you'll see the stripped threads and the second is the surface chips.
Are these surface chips anything to worry about? I noticed it on my FRS when I got back from deployment. Is it a warranty item or typical wear and tear?
The2nd_Noel is offline   Reply With Quote
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Looking for 2 - 12mm jam nuts with fine threading.... MidLife&luvIt Northern California 18 06-17-2013 12:27 PM
Fr-s shift knob threading iam_abner Cosmetic Modification (Interior/Exterior/Lighting) 3 08-06-2012 08:05 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
