Old 07-29-2015, 06:18 AM   #71
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
No not EL. UEL.
Old 07-29-2015, 04:08 PM   #72
steve99
Drives: FT86
Originally Posted by Wayno View Post
No not EL. UEL.
yeah i dont think that tuner was much good, guy said it was their first brz.
Old 08-07-2015, 11:41 AM   #73
mid_life_crisis
Drives: FR-S 10 #103 AT
I've increased the timing a bit to get back some from Wayno's conservative timing tables for the craptastic Aussie fuel. I'm seeing some correction in the logs but the multiplier is rock solid at "1". Does this mean I don't need to worry about the corrections?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-07-2015, 05:45 PM   #74
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ideally you want no corrections under WOT at least, not so much of an issue elsewhere if you're happy to leave it. Consistent FLKC will mean the IAM will drop bit if its only minor corrections it will likely stay around 1.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-16-2015, 12:40 PM   #75
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
So i've read that thread for DBW editing in BRZ edit, but has anyone succesfully done it with Rom Raider?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 08-16-2015, 05:10 PM   #76
Kodename47
Kodename47's Avatar
Drives: UK GT86
In what way? It's exactly the same.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-16-2015, 05:11 PM   #77
itsjustdavep
The tables look different. .. maybe I'm looking at the wrong ones
Old 08-16-2015, 05:14 PM   #78
Kodename47
Kodename47's Avatar
Drives: UK GT86
The values may be different but the theory will be the same.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-26-2015, 01:14 AM   #79
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Hey guys, have the timing numbers for the ace header on the 1st page been tested?
Theres no link to go along with the timing numbers.
I'll be installing mine tomorrow and will be flashing with the stage 2 el 93 oct OFT tune.
Any info i can get is greatly appreciated. Thanks for putting so much time into educating us noobs.
Kotu100 is offline   Reply With Quote
Old 08-26-2015, 04:59 AM   #80
steve99
Drives: FT86
Those numbers came from a tuner in sweeden who did an ace header tune for a guy, they are almost identical to the oft tune ,so i make no guarantees as to they will get max power ect, its not going to blow up but unlikey to be optimal. You could also try the nameless tables as they are also a long tube header.
Kotu100 (08-27-2015)
Old 08-30-2015, 10:30 PM   #81
HachiEnam
UCSB!!!
HachiEnam's Avatar
Drives: 2017 GTI sport
Does anyone know if the OTS tunes for stage 1 and stage 2 are 91 or 93? All it says is Stg1 B01C.bin and Stg2 UEL B01C.bin?
HachiEnam is offline   Reply With Quote
Old 08-30-2015, 11:33 PM   #82
Wayno
Wayno's Avatar
If your off the shelf C tunes don't have folders for 91 and 93 you need to download the latest 2.0x package from openflash.
The Following User Says Thank You to Wayno For This Useful Post:
HachiEnam (08-31-2015)
Old 08-31-2015, 11:28 AM   #83
HachiEnam
UCSB!!!
HachiEnam's Avatar
Thanks. I downloaded the lastest 2.0x package from the website as recommended and installed their 91 stage 1 tune. I believe it is the same because when I was "writing" it, it had a asterik next to the tune files name.
I sort of wish each tune file was titled with the appropriate Octane, for example, 91 Stage 1.bin.
Nonetheless thank you for assisting me
Old 08-31-2015, 12:36 PM   #84
steve99
Drives: FT86
just be carefull with using the "*" to flag which tune is in ecu.
If you upload a new tune to the slot with the "*" on it its no longer the tune in ecu. the "*" just flags the last slot written to ecu OFT does not actually check or compare :-)
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
Information I did not want to know. K2 Great Lakes 19 07-23-2012 08:18 AM
