Old 08-10-2015, 01:52 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Chad_W View Post
At the same time you replaced the OEM sway bars with ones 2-3mm less in diameter... Would you retain some ride comfort here, while shifting some of the anti roll responsibility to your now stiffer strut/spring combo?
I'm really only thinking about this for a street application. The desired result would be to not sacrifice too much compliance, while going to a slightly more aggressive spring/strut combo
Why are you ignoring damper quality from your scenario?
cdrazic93 (08-10-2015)
Old 08-10-2015, 02:30 AM   #16
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The FR-S will understeer until you apply power or jerk it into a corner. Then it will happily oversteer. Damnit.
Old 08-10-2015, 03:51 AM   #17
Not my experience. I apply power and it just plows more.
strat61caster (08-12-2015), wparsons (08-10-2015)
Old 08-10-2015, 11:41 AM   #18
Chad_W
Drives: 2013 BRZ DGM
Awesome data! Thanks for all the input.
Is it fair to say that not all roll is bad? Going completely flat around corners my be a desirable trait, but does that mean it offers the ultimate amount of grip? Can a suspension with a little bit of roll be grippier (like the new Miata for example)?
Chad_W is offline   Reply With Quote
Old 08-10-2015, 11:42 AM   #19
Chad_W
In this case I'm saying the OEM dampers are getting switched with Bilsteins.
Old 08-10-2015, 11:47 AM   #20
wparsons
wparsons's Avatar
You can coax it into oversteering, but you can do that with almost any car with the right (or wrong) inputs. I find it easier to get lift oversteer than power on oversteer from mine.
flickr
Ultramaroon (08-10-2015)
Old 08-10-2015, 12:08 PM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Yes, lifting mid corner will take the weight off the back tires and induce oversteer. That makes the car rotate too. There is so much to EASILY play with on the frs's stock suspension and tires, it's kind of amazing. I love it. My one spin yesterday was power oversteer.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 08-10-2015, 12:53 PM   #22
Gunman
Drives: 2019 Mazda Miata RF
Yes.
During a Claude Rouelle seminar, he talked about roll, and weight transfer, and that due to the weight transfer in roll, the outside tires can gain more grip than the inside tires lose. So, up to a point, weight transfer via roll is a good thing, to gain grip.
The Following User Says Thank You to Gunman For This Useful Post:
GSpeed (08-10-2015)
Old 08-10-2015, 02:07 PM   #23
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Originally Posted by Gunman View Post
Yes.
I would LOVE to take one of his seminars again. It's so much more expensive when you're not an FSAE student!
Jake
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
Old 08-10-2015, 02:44 PM   #24
Racecomp Engineering
Any of you guys going to PRI this year?
Oh and on topic...the stock front swaybar contributes quite a bit more to roll-resistance than the rear bar. Removing the front bar would have much more of an impact than removing the rear bar (and IMO it wouldn't be an improvement for MOST set-ups).
- Andrew
CSG Mike (08-10-2015), wparsons (08-10-2015)
Old 08-10-2015, 03:52 PM   #25
Jake
Yay FSAE. Go Lobos!
Old 08-10-2015, 04:03 PM   #26
fika84
fika84's Avatar
I used to work for Claude Rouelle. For 2 years. The only people that look up to him, are FSAE students. He is despised by the professional world.
It all depends on the tires and what they want.
fika84 is offline   Reply With Quote
Old 08-10-2015, 04:44 PM   #27
Care to elaborate?
Old 08-10-2015, 04:56 PM   #28
Interesting.
- Andrew
Reducing Drone Suggestions? JohnAyySays Engine, Exhaust, Transmission 7 04-08-2014 01:20 AM
Reducing squeel after HPDE transition Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 03-16-2014 02:20 PM
Reducing Rasp Admired Engine, Exhaust, Transmission 28 01-25-2014 02:40 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 03:57 AM
Reducing Insurance for hardly used car? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 6 08-31-2013 07:35 AM
