Old 07-22-2015, 04:31 PM   #71
nunonuna
nunonuna's Avatar
Originally Posted by ryoma View Post
do these headers come with that reflective heat wrap that I have seen on others? I believe they put it over the oil pan to avoid the heat soaking into it. and is it an actual problem with too much heat coming out from the actual headers to affect the engine bay/oil temps?
It does not come with it, but it is not expensive or hard to get one.
nunonuna is offline   Reply With Quote
Old 07-22-2015, 05:36 PM   #72
ryoma
ryoma's Avatar
is there a specific brand or type that people use with good results?
Old 07-22-2015, 06:07 PM   #73
Gruppe-s
Drives: Time-attack Scion Race car
I am working with a big company to try and offer a solution. The reflective gold tape that you can apply easily doesn't reflect enough heat. I will have a cost effective solution for your pan that is easy to install. It is going to take approx 30 days to get the kit ready.
Gruppe-s is offline   Reply With Quote
The Following 4 Users Say Thank You to Gruppe-s For This Useful Post:
DAEMANO (07-28-2015), Donbrz (07-29-2015), ryoma (07-22-2015), WhiteFRS69 (07-22-2015)
Old 07-22-2015, 09:31 PM   #74
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Ceramic is the only way to go.
It turns out PSR were the ones who requested that the slip retainer be moved above so that the headers don't require bash plate modification.
The Following User Says Thank You to Wayno For This Useful Post:
Gruppe-s (07-23-2015)
Old 07-23-2015, 03:17 AM   #75
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Ref : http://www.ft86club.com/forums/showt...09#post2331709
92 Octane results posted in 6AT and 6MT flavors...
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 12 Users Say Thank You to Drift-Office For This Useful Post:
Andrew025 (07-23-2015), continuecrushing (07-23-2015), DAEMANO (07-23-2015), drew_kar (07-23-2015), eggncheese (07-23-2015), Gruppe-s (07-23-2015), ichitaka05 (07-29-2015), mikool (07-23-2015), RobertPaulson (08-14-2015), scioneric (07-23-2015), Strife26 (11-05-2015), WhiteFRS69 (07-23-2015)
Old 07-28-2015, 08:08 PM   #76
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
@icybrzzz check out the video in first post!
Old 07-28-2015, 08:24 PM   #77
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Will a flex joint be needed to reach the some of the bolts on the flange? I'll be installing mine Thursday.
Sent from my XT1058 using Tapatalk
drew_kar is offline   Reply With Quote
Old 07-28-2015, 08:49 PM   #78
Wayno
Wayno's Avatar
Yes, and not a wide one, a narrow one.
Old 07-28-2015, 10:28 PM   #79
nunonuna
nunonuna's Avatar
Does anybody have some kind of hissing or wooshing kind of noise on throttle after this header installed??
Old 07-29-2015, 04:32 PM   #80
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
I do, found no leak. Getting use to the sound. Anyone without that noise?
scioneric is offline   Reply With Quote
The Following User Says Thank You to scioneric For This Useful Post:
nunonuna (07-29-2015)
Old 07-29-2015, 04:44 PM   #81
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I'm installing mine tonight -- But i've heard that UEL headers just tend to produce this whooshing sound. Probably normal.
ajcarson11 is offline   Reply With Quote
Old 07-29-2015, 04:52 PM   #82
cjm86
cjm86's Avatar
Drives:
I have that same noise but no issues. Im also getting use to it
cjm86 is offline   Reply With Quote
The Following User Says Thank You to cjm86 For This Useful Post:
Old 07-29-2015, 05:13 PM   #83
nunonuna
nunonuna's Avatar
Yeah, I also checked for leaks on the day I installed & found no leak, but I was just curious if I'm the only one or not. Lol
Old 07-29-2015, 06:40 PM   #84
JEDI
JEDI's Avatar
Drives: 2015 FR-S RS 1.0 #0993
Originally Posted by Bergen23 View Post
Generally, any metal exposed to the elements will rust without adequate protection. Ie: a coating and/or cathodic protection.
^Correct
This is my uneducated understanding, rust is a product of the steel/material returning to it's natural state. Depending on the type of material, conditions, humidity etc. will determine how fast and when the process begins to take effect. Protective coatings, paint, and such just prolong the inevitable. Besides poor corrosion prevention practices this is why you see rust under paint.
2015 Subaru WRX - SOLD!
2013 Scion FR-S - Traded In!
2015 Scion FR-S RS 1.0 - My DD , GF, and BFF!
JEDI is offline   Reply With Quote
The Following 2 Users Say Thank You to JEDI For This Useful Post:
Bergen23 (07-29-2015), Strife26 (11-05-2015)
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 10:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 01:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 08:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
