Old 07-26-2015, 10:41 AM   #15
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
upgrading!!
Old 07-26-2015, 03:50 PM   #16
phrosty
Originally Posted by mid_life_crisis View Post
you really should feel justified in charging a small upgrade fee for it. You're in business, not running a charity.
One might call it a value add.
phrosty is offline   Reply With Quote
Old 07-26-2015, 06:20 PM   #17
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
Originally Posted by efactor84 View Post
Shiv, so far the MAF Voltage and the IAM still have no reading with the newer update for CAL ID ZA1JD00D. Is there gonna be another update for this fix?
Same here, running the new template with the new lateral g/wheel spin logging but Adv.Multiplier is flatlined at 0 for the D00D Cal ID.
@Shiv@Openflash
Shinobu's Smile is offline   Reply With Quote
Old 07-26-2015, 08:10 PM   #18
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You can use MAF instead of MAFV and KC learned instead of adv mult and look up both the values in the rom.
Old 07-27-2015, 12:22 AM   #19
DAEMANO
Time Traveller
Because, why not.
Old 07-27-2015, 09:37 AM   #20
Semprini
Spline Reticulator
Semprini's Avatar
Drives: 2013 FR-S Whiteout
After I updated to this new template, the OFT works correctly when plugged into USB but when I plug it into my OBD, it turns on, displays the small tablet icon, then fades to white. @Shiv@Openflash or anyone else - any ideas?
Johnny was a chemist's son, but Johnny is no more.
What he thought was H2O was H2SO4.
Semprini is offline   Reply With Quote
Old 07-27-2015, 10:24 AM   #21
steve99
Drives: FT86
happens if power goes on/off/on to tablet quickly.
unplug it for about 20 sec then plug it back in should be fine.
Old 07-27-2015, 10:48 AM   #22
Semprini
Spline Reticulator
Semprini's Avatar
I'll have to give that another try - maybe I did not leave it unplugged long enough. I also updated from the initial 8.0 to the 8.1 template, just in case 8.0 had any glitches.
Old 07-27-2015, 01:43 PM   #23
OkieSnuffBox
Drives: '23 BRZ Limited
@Shiv@Openflash
Interesting.
I noticed when I upgraded templates, when I first started the car IAM was at 0.85 (on 91 and E85, running E85 now, it's always been 1.00), but quickly came back up to 1 with a bit of driving.
Old 07-27-2015, 02:07 PM   #24
Semprini
Spline Reticulator
Semprini's Avatar
After updating to the 8.1 template and having to wait until lunch to test, OFT came up perfectly to test out the new logging. @steve99 thank you for the tip - my brain is much less patient than an actual clock
Old 07-27-2015, 04:11 PM   #25
Semprini
Spline Reticulator
Semprini's Avatar
@Shiv@Openflash Slight typo in the data logging: "lateral" is shown as "laterial"
Old 07-28-2015, 03:31 PM   #26
toast
Drives: 14 BSP Edelbrock BRZ
The update lets you corner so hard they needed a new word
toast is offline   Reply With Quote
Old 07-28-2015, 03:49 PM   #27
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Same thing happened to me. I pulled tune off of OFT and renamed it and put it back on and now all is well.
apparently it will work with "new" files but not old ones.
MGPAX is offline   Reply With Quote
Old 07-28-2015, 04:21 PM   #28
elBarto
elBarto's Avatar
Drives: Toyota GT86
Is there anyway to create presets for the logging channels?
So people can switch between car logging and trackday logging.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
NEW: OpenFlash Tablet G-Meter and Performance Driving Pack Shiv@Openflash Software Tuning 87 03-13-2016 01:59 AM
OpenFlash Tablet G-Meter and Performance Driving Pack Shiv@Openflash Tracking / Autocross / HPDE / Drifting 13 07-07-2015 11:59 AM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Expert Review: Plug-and-Play performance for the FRS/BRZ with Vishnu Openflash Tablet ModBargains.com Software Tuning 82 07-25-2014 07:06 AM
