Old 01-03-2015, 07:06 PM   #1
rever5e
OpenFlash Tablet will not connect to OpenFlash Manager
I have an OFT Tablet that i cannot get to work on 3 seperate computers (using different USB cables). Every time i get the exact same error. Using the latest OpenFlash Manager v 1.06.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException: Method not found: 'Int32 PWGGlobals.StaticGlobals.DownloadTestProtocols(Sys tem.String)'.
at PWGPro.MainForm.mySearchUpdates(BackgroundWorker backgroundWorker)
at PWGPro.MainForm.DownloadUpdates_DoWork(Object sender, DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.OnDoWork(Do WorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThrea dStart(Object argument)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PWGPro
Assembly Version: 1.6.0.0
Win32 Version: 1.6.0.0
CodeBase: file:///C:/OpenFlash/OpenFlash%20Manager.exe
System.Windows.Forms
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CommonResources
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/OpenFlash/CommonResources.DLL
PWGResources
CodeBase: file:///C:/OpenFlash/PWGResources.DLL
PWGCommand
CodeBase: file:///C:/OpenFlash/PWGCommand.DLL
PWGService
CodeBase: file:///C:/OpenFlash/PWGService.DLL
System.Web.Services
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
PWGService.XmlSerializers
CodeBase: file:///C:/OpenFlash/PWGService.XmlSerializers.DLL
h72sevzl
HidLibrary
CodeBase: file:///C:/OpenFlash/HidLibrary.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms.Ribbon35
Assembly Version: 3.5.7.0
Win32 Version: 3.5.7.0
CodeBase: file:///C:/OpenFlash/System.Windows.Forms.Ribbon35.DLL
PWGPro.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGPro.resources.DLL
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
PWGResources.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGResources.resources.DLL
PWGCommand.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGCommand.resources.DLL
PWGService.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGService.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
rever5e is offline   Reply With Quote
Old 01-03-2015, 07:34 PM   #2
steve99
That version of OFM is way out of date you need to download and inatall the latest version
1.15.1
from here
http://openflashtablet.com/Automotiv...%20Manager.zip
you will also need to download and install template file
http://openflashtablet.com/Automotiv...omized%204.SLT
web page is here make sure you either clear cache of hit controlf5 or click refresh while holding down control key.
http://openflashtablet.com/Automotiv...ads/index.html
Old 01-03-2015, 10:32 PM   #3
slofrs
slofrs's Avatar
Drives: Hot Lava FR-S
i got one better for you, mine will connect but will not erase data from it not even off the shelf maps that i load to it.
slofrs is offline   Reply With Quote
Old 01-03-2015, 10:49 PM   #4
steve99
Assume you have latest open flash manager. 1.15.1
If you want to erase tunes go the the "Upload Data" tab. then click the red X next to the tune file you want to delete, then you can upload a new tune to that slot. There are 5 tune slots
you want be able to erase your stock tune (in the protected slot) unless you do the unmarry procedure.
The Erase tab is only used when you want to "unmarry" the OFT from your car. The Erase function only works if you have written your stock tune back to car. You dont need to "ERASE" unless you want to unmarry tablet.
If it has got itself into some sort of knot then you could try writing back your stock tune to car.
then use ERASE to delete everything
Then READ your stock tune again
see the OFT TIPS link below for more info
Old 01-03-2015, 11:44 PM   #5
slofrs
slofrs's Avatar
Thanks for the quick reply Steve, i had it erased on Thursday and was making a video to show that it was "unmarried" and that it worked for a guy wanting to buy it. guess i will have to give them a call on Monday.
Old 01-04-2015, 11:29 AM   #6
rever5e
1.15.1
from here
Thank you that fixed it!
Old 05-01-2015, 08:08 PM   #7
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
I had this exact problem too - but 1.06 is what is listed on the website under downloads. If it's a broken version, they shouldn't still link to it and not have a link to 1.15. I hate to revive an old thread but it was kind of hard to find this info and it should probably be fixed.
fatalelement is offline   Reply With Quote
Old 05-01-2015, 08:12 PM   #8
steve99
use link i posted above for ofm ver is now 1.19.0, update template as well.
you must be getting cached versions of web pages.
Old 05-01-2015, 08:25 PM   #9
fatalelement
Yeah I fixed it too. If you Google OpenFlash Manager, their page w/ 1.06 is the first result. They should probably remove this page from their sitemap. Thanks though!
Old 03-10-2022, 03:28 PM   #10
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
Well, it's been a few years and I'm now getting the error message, but it's slightly different. it says "Sequence Contains no matching elements". I've removed, downloaded and installed a new version, but same issue. What is really weird is that I just used it last week to upload a tune file and I don't think I updated anything on the PC or the software since. Just tried to upload a new tune file with some adjustments.
G_Rossney is offline   Reply With Quote
Old 03-12-2022, 10:17 AM   #11
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Shot in the dark, but are you using a USB 3 connection? I had all sorts of errors until I started using USB 2.
PetrolioBenzina is offline   Reply With Quote
OpenFlash Manager 1.14 Problem Apoc Software Tuning 30 12-10-2014 12:14 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 06:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 10:02 PM
