Old 07-06-2015, 02:04 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tablet G-Meter and Performance Driving Pack
Hi guys,
We have a big update we will be releasing to all OFT users later this month. It is something that we have been working on for a little while now. Something squarely aimed at those who are focused on performance driving/racing/drifting. It's something that I (personally) have always wanted. And like all other OFT updates, it will be FREE
With the next update, you will be able to monitor/data log everything you need to quantify driving dynamics. This includes:
- Lateral G
- Acceleration G
- Deceleration G
- Yaw (drifting!)
- Brake pressure
- Steering wheel angle
- Individual tire air temperatures
- Individual wheel speeds
- Individual wheel spin
Now there is no need to spend anther $500-1000 on an add-on race data acquisition system. And even better is that all these new channels can be monitored/log along with the usual engine related data (boost, AFR, timing, knock, etc,.) This makes for a VERY powerful tool for those who want to quantify their driving. With these new features you will be able to compare lap times and be able to definitively determine where the difference is as well as how to improve your performance. Monitoring tire temps will also give you insight into things like alignment, tire size, pressures, etc. One thing we can't quite log (yet) is tire pressure. But we are working on it
Cheers,
shiv
The Following 12 Users Say Thank You to Shiv@Openflash For This Useful Post:
200hp/tonne (07-19-2015), cjd (07-06-2015), Cop (07-07-2015), DAEMANO (07-06-2015), D_Thissen (07-06-2015), fstlane (07-07-2015), hmong337 (07-07-2015), Sleepless (07-06-2015), waterbison777 (07-07-2015), Wepeel (07-09-2015), WillRacer1jz (07-06-2015), WRB5titch (07-06-2015)
Old 07-06-2015, 02:14 PM   #2
Racecomp Engineering
What kind of sensors are you using for tire temps? One per corner or are you able to measure temps across the tire?
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (07-07-2015)
Old 07-06-2015, 02:31 PM   #3
Shiv@Openflash
Drives: 2013 FRS
- Andrew
We are doing it rather simplistically and reading air temp from the TPMS. So its an tire air temp reading, not a tire surface temp reading.
Old 07-06-2015, 02:45 PM   #4
Ah okay. Cool.
- Andrew
Old 07-06-2015, 02:48 PM   #5
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following 5 Users Say Thank You to Takumi788 For This Useful Post:
DAEMANO (07-06-2015), fstlane (07-07-2015), Racecomp Engineering (07-06-2015), waterbison777 (07-07-2015), WillRacer1jz (07-06-2015)
Old 07-06-2015, 02:56 PM   #6
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Cool, but still need GPS location to tie it all together.
You need to add a Bluetooth interface so apps like CMS Lap Timer can integrate the data from the OFT and GPS and video...
Sleepless is offline   Reply With Quote
Old 07-06-2015, 03:31 PM   #7
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Wow, quite an update once again! Got a track day planned on August 9th, guess if this is released I'll have the opportunity to test this
Mad1723 is offline   Reply With Quote
Old 07-06-2015, 03:49 PM   #8
redlined600
redlined600's Avatar
Drives: Fr-s
If you want this to be successful with the track guys, make sure it can output in a format that can be analyzed by an ?existing? and powerful analysis software package.
Data is useless without a good way to digest and understand it.
The Following User Says Thank You to redlined600 For This Useful Post:
Old 07-06-2015, 04:06 PM   #9
D_Thissen
D_Thissen's Avatar
This is a neat little update. It awesome to see how versatile this tablet has become! Keep up the great work
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 07-06-2015, 04:34 PM   #10
DAEMANO
Time Traveller
@Shiv@Openflash Damn its unbelievable how much value you pack into the OFT. As an ESC + e85 user with nearly full exhaust, I'm getting tons of value. This is why I'm 100% on board with your move into Fiat Abarth. The S.O.'s lil Scorpion is going to push my car after it gets its' OFT.
Old 07-07-2015, 06:35 AM   #11
troek
troek's Avatar
Drives: 2012 Toyota 86
the frs has onboard g sesnor your gona tap into?
Old 07-07-2015, 11:08 AM   #12
wparsons
wparsons's Avatar
^^ Yep, it has accelerometers and a yaw angle sensor. The VSC system needs them to work.
If there is any possibility of hooking in an external GPS (and finishing up tire pressures!), this would be a huge win!
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Takumi788 (07-07-2015), troek (07-07-2015)
Old 07-07-2015, 11:39 AM   #13
D_Thissen
D_Thissen's Avatar
I wonder if OFT would only be able to access tire pressures if the car has TPMS installed. I am not sure, but I don't think BRZ's in Canada came from the factory with the sensors installed. Well, at least the ones I saw in Tbay didn't.
Old 07-07-2015, 11:59 AM   #14
wparsons
wparsons's Avatar
It would need TPMS to get pressure data...
flickr
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
NEW: OpenFlash Tablet G-Meter and Performance Driving Pack Shiv@Openflash Software Tuning 87 03-13-2016 01:59 AM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
Expert Review: Plug-and-Play performance for the FRS/BRZ with Vishnu Openflash Tablet ModBargains.com Software Tuning 82 07-25-2014 07:06 AM
