Old 07-23-2015, 08:44 PM   #15
KenTK808
Drives: White 2014 Scion FRS
Originally Posted by shu5892001 View Post
how did you have your wife cover the exhaust tips? lol
Just the tip
KenTK808 is offline   Reply With Quote
Old 07-23-2015, 09:19 PM   #16
ANTLAY
Drives: 2013 FR-S in Whiteout
Originally Posted by KenTK808 View Post
Just the tip
Yessir, Just the tip,lol
ANTLAY is offline   Reply With Quote
Old 07-30-2015, 11:47 PM   #17
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
OP I have the same sound. Just installed Gruppe-s UEL header yesterday, and I would describe the sound less wooshy, and a bit more rough. Almost like a rasp, but almost like sand flying around in the pipe. Kind of a gritty sound. It only happens on acceleration, and it just sounds out of place. It has a 'ticking' sound, but difficult to describe further. I've done some forum research, and I would say that this is normal. It looks like plugging the sound tube or adding header wrap may deaden the sound, but header wrap can subject the header to more heat over time, taking away from useful life. Just FWIW
ajcarson11 is offline   Reply With Quote
Old 07-31-2015, 11:05 AM   #18
ANTLAY
That sounds about right,especially the sand through pipe,that's pretty much exactly it, i put mine back on stands and double checked everything and couldn't find any leaks so im pretty sure its rasp, i may order a resonated fp just to see which sound i like better.
Has anyone installed the full HID conversion kit from Diode Dynamics? (DRL/Lowbeams) Cliu91 Cosmetic Modification (Interior/Exterior/Lighting) 0 05-26-2014 01:15 PM
Results after full blown kit installed frs87 Forced Induction 86 04-10-2014 04:37 PM
Question about full perrin exhaust, with headers Jimmylightning Engine, Exhaust, Transmission 4 03-22-2014 10:29 PM
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
APR Full Body Kit Installed msile Cosmetic Modification (Interior/Exterior/Lighting) 28 02-20-2013 01:21 PM
