Old 04-06-2014, 02:25 PM   #1
frs87
Drives: red/black
Results after full blown kit installed
after 3 weeks of waiting for my turbo kit to be installed it was finally finally time to see the results! the car omg is so freakin fast, spools quick hardly any lag, kit looks good, installation wasnt perfect but it got done, went and got my car washed 30 mins later, after babying it for a hr , i go in to wot in 4th getting on the high way, pulls hard, BUT then i hear this noise, this tapping noise, and it slows down as i slow down the speed, i immediately pulled over, popped the engine after cutting off the car, no leaks, no oil spill, nothing different, cut the car back on and i hear this constant knock and its loud as hell, instally thought it was a rod knock and it was exactly what i thought, my mechanic is taking the engine apart tommorow , idk what could have caused this to happen, the car was tuned from the base map sent from LJ, i even had the car tested for any leaks , that was good. A/F ratio was at 14.29 -14.59 idling, the high was 19 i think, i have a log on my computer of everything before it died, im really dissapointed right now, any suggestions? im already looking into buying Brian Crower rods for about 650.00 just to be on the safe side, not putting stock rods back in there,
frs87 is offline   Reply With Quote
Old 04-06-2014, 02:33 PM   #2
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
Sounds like it died from detonation, different rods will not take care of that issue.
You will need to lower the compression or run E85 / higher octane fuel to avoid the detonation with your current setup.
Crawford Performance is offline   Reply With Quote
Old 04-06-2014, 02:55 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
what boost?
Old 04-06-2014, 04:14 PM   #4
BRZnut
Drives: BRZ DGM Limited
Correct me if I an wrong, but I've always thought that if going Turbo you had to beef up the internals of the engine before going live. Seems all I see is people getting only a tune.
Old 04-06-2014, 04:43 PM   #5
jflogerzi
jflogerzi's Avatar
At higher boost yes, but lower boost the stock block seems up to the task short term. Long term is unknown.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 04-06-2014, 06:37 PM   #6
Crazy Drew
Drives: Smells like tires when I drive
Fix whatever burnt up and get a real tune. If I even saw anything near 14.59 afr on a turbo car I'd flip a shit, much less 19 under load, and wouldn't get back into boost until I got it tuned. I'm surprised it didn't pop sooner.
Crazy Drew is offline   Reply With Quote
Old 04-06-2014, 06:56 PM   #7
Basket Case
Drives: 2013 Raven fr-s
That really sucks man. It sounds like your tune was not good...14.5 afr at idle is normal for n/a cars, but under boost to be safe I would expect AFR's around 11.5-12.5 to be safe.
Basket Case is offline   Reply With Quote
Old 04-06-2014, 07:11 PM   #8
mmsracing
Drives: 2013 FRS
I have never seen a motor blow at idle, regardless of afr. In fact, I used to show students how to create detonation at idle on a motec so they know what it sounds like and feels like on a dyno, then have them richen the mixture and adjust timing, and I have never blown a motor like that in 10 years. I am a certified EFI tuner.
So afr of 14.59 or even 19 at idle will not blow up you motor. under load, it will not last long and that sounds more likely.
and to be honest, most tuners I have met usually do a poor job of tuning a car anyways. A real full tune on a car can take days to complete the correct way. all throttle position, all rpms, all loads. Most tuners don't do that because customers will get sticker shock.
when it comes to tuning, you get what you pay for.
mmsracing is offline   Reply With Quote
Old 04-06-2014, 07:20 PM   #9
Tromatic
Originally Posted by Reaper View Post
what boost?
What fuel as well.
Tromatic is offline   Reply With Quote
Old 04-06-2014, 07:22 PM   #10
Crazy Drew
I was not referring specifically to it at idle more so just the numbers period, yes I'm fully aware that pretty much whatever air fuel it'll run with at idle is "safe". I was really speaking in reference to his ~19:1 under load.
I have tuned several cars in the past with excellent luck, and you're fully right, the tune I was most proud of took me probably 40 hours of street driving to get 100% right. I don't know of any other J swapped integras that got 45 mpg and ran 12's with an unopened motor straight from a junkyard.
I fully agree with tuning you get what you pay for, I personally would never trust a "off the shelf" tune for anything other than an otherwise stock car, or just to get one started on some big injectors, from there it's time to get into the maps and compensation tables. I think spending 4 figures on tuning is realistic, hence why I personally won't rush out there to throw on a turbo kit with an off the shelf tune. I don't even trust myself to tune my own cars.
Old 04-06-2014, 07:24 PM   #11
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
well... this was pretty much ur fault.
a baseman is to drive to car to a tuner or send some logs to @FullBlown to have it tweaked.
i have a full blown kit with 10k miles and no issues whatsoever but i had the base tune for 3 hrs till i got a much better tune.
Old 04-06-2014, 07:27 PM   #12
Reaper
Reaper's Avatar
Drives: violent
This^ I trailered mine to the dyno and made 450+whp on the stock engine with a fullblown base kit.
The tune is everything. Took ALLLL DAY too.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-06-2014, 07:29 PM   #13
Dipstik-sportech
Dipstik-sportech's Avatar
Was the fuel pump correctly installed? What boost? What fuel? Are these AFR's under load or idling? People are so quick to blame the tune but there are other reasons that engines blow. Hell who knows if he even had the correct about of oil in the car
The Frozen North
Old 04-06-2014, 07:29 PM   #14
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
yep
I'm here making 450 whp on a Full Blown Kit with a GT28 and no issues
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results. Infamous Performance Forced Induction 10 07-03-2013 08:52 PM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-27-2013 11:41 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
