Old 07-22-2015, 09:17 PM   #1
ANTLAY
Drives: 2013 FR-S in Whiteout
Just installed full exhaust,have a question or two..
Over the weekend I installed full exhaust, header back, tomei uel,motive op and fp and n1 catback,all catless. I love the sound of it but I have a "metal" "tinny" sound somewhere that I thought was an exhaust leak so I had my wife cover the tips while I listened around cant hear anyy "pft pft" sound like leaks I've had in other vehicles in the past. The noise isn't there all the time only really when it's under a load, i also am using a oft with stg2 uel93 tuneand tried watching real time display but I'm a huge noob to stuff like that so not exactly sure what I'm looking at,only kinda seen a few things here to say watch the trim(forgot what it's called exactly ) but my numbers seem fine while on the gas. Only go kinda weird or "up" when it's at idle or off the gas. Won't be able to get back on stands till the weekend to double check all my joints but I only found one leak at the op/fp junction after the install,swapped the gasket and it was gone. That's the only one I found for sure. Sorry to carry on,just trying to get it all out while it's fresh on the mind. Just looking for help or advice to figure out if it's normal with catless setup or if there's something I need to fix, Thanks I'm advance.
ANTLAY is offline   Reply With Quote
Old 07-22-2015, 09:52 PM   #2
KenTK808
Drives: White 2014 Scion FRS
I believe the sound you are hearing is rasp, from having no catalytic converter or any sound dampening parts of the exhaust.
KenTK808 is offline   Reply With Quote
The Following 3 Users Say Thank You to KenTK808 For This Useful Post:
ANTLAY (07-23-2015), ATL BRZ (07-23-2015), chas3wba0 (07-23-2015)
Old 07-22-2015, 09:55 PM   #3
Griever423
Drives: 2020 BRZ PP
The tinny sound you hear is the AVCS compesating for the torque dip. I have OFH and OFT stage 2 tune. Mine does the exact same thing. It's right around 3500-3700 rpm. Especially noticeable when you're in gear and decelerating.
Griever423 is offline   Reply With Quote
The Following User Says Thank You to Griever423 For This Useful Post:
ANTLAY (07-23-2015)
Old 07-23-2015, 06:45 AM   #4
ANTLAY
I hope that's all it is because trying to find a leak was driving me nuts. Question for either of yall, is there a specific location that sounds most noticeable? Because I still can't pinpoint exactly where it's at. To me it literally sounds like it's air flowing through the fp, which is where I've checked at least 5x now.
Old 07-23-2015, 07:41 AM   #5
steve99
Drives: FT86
If your running the oft UEL tune you should not get the raspy sound arround 4000 as the vvt cam timings for uel header is much less agressive than for el header.
most aftermarket headers are made of thinner lighter material than stock header and do not have the heat shields resulting in more noise than stock header comming from front of car. They will sound diffrent. whoosing noises or some tinny resonance especially if you have removed cats and resonators is common
The Following 3 Users Say Thank You to steve99 For This Useful Post:
ANTLAY (07-23-2015), kch (07-23-2015), number1Tango (01-25-2016)
Old 07-23-2015, 09:15 AM   #6
ANTLAY
If your running the oft UEL tune you should not get the raspy sount arround 4000 as the vvt cam timings for uel header is much less agressive than for el header.
Thanks,sounds like what it is then,im still gonna throw back in the air this weekend and double check everything just in case,but that pretty much sounds right. Thanks again guys!
Old 07-23-2015, 12:47 PM   #7
kch
Senior Misanthrope
kch's Avatar
Also check to see if the OP is potentially hitting anything. It's possible that under load it's moving around enough to tap the subframe.
The Following User Says Thank You to kch For This Useful Post:
ANTLAY (07-23-2015)
Old 07-23-2015, 01:07 PM   #8
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
I think I remember reading about someone having that problem with the rattle against the frame with the op. IIRC, they heat wrapped it or something so it wasn't metal on metal (but I could be way wrong)
cdq85 is offline   Reply With Quote
The Following User Says Thank You to cdq85 For This Useful Post:
ANTLAY (07-23-2015)
Old 07-23-2015, 02:04 PM   #9
ANTLAY
Yea that's one thing I saw too,and something I plan on checking when I get it back in the air. Thanks
Old 07-23-2015, 02:11 PM   #10
ANTLAY
One thing I will say though,is it doesn't sound like it would be a rattle,more of a .. Air swooshing through a metal pipe,is the best description I can come with. Maybe if it's a really light rattle but I don't know,so plan on checking anyway, I've also heard of some people having a rattle against the skip plate? That sound like a possibility?
Old 07-23-2015, 03:51 PM   #11
cdq85
cdq85's Avatar
if it sounds like a whoosh then it is definitely just because of the new headers. I specifically remember driving for the first time after my install and pulling over and jumping on the forums to see if that was normal lol. sounds like you are just fine.
The Following 2 Users Say Thank You to cdq85 For This Useful Post:
ANTLAY (07-23-2015), scioneric (07-23-2015)
Old 07-23-2015, 04:25 PM   #12
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
how did you have your wife cover the exhaust tips? lol
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
Old 07-23-2015, 06:05 PM   #13
ANTLAY
Lol, two older (clean) car wash sponges stuffed in the tips.
Old 07-23-2015, 06:07 PM   #14
ANTLAY
Thanks,i did the same thing "oh shit,that sounds weird/different... I should check for leaks,well can't find any,better check the forums!!
Has anyone installed the full HID conversion kit from Diode Dynamics? (DRL/Lowbeams) Cliu91 Cosmetic Modification (Interior/Exterior/Lighting) 0 05-26-2014 01:15 PM
Results after full blown kit installed frs87 Forced Induction 86 04-10-2014 04:37 PM
Question about full perrin exhaust, with headers Jimmylightning Engine, Exhaust, Transmission 4 03-22-2014 10:29 PM
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
APR Full Body Kit Installed msile Cosmetic Modification (Interior/Exterior/Lighting) 28 02-20-2013 01:21 PM
