Old 06-17-2015, 10:22 AM   #323
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Officially joined the waiting list!
Now the agonizing wait begins
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
raven1231 (06-17-2015)
Old 06-17-2015, 12:30 PM   #324
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Target70 View Post
are you still running the original starter battery with the 1.5 setup? I can't remember if it will fit, but you could try out the new starter batt. I managed to get 2.0 to fit with the 1.5 kit with some washers and longer screws between the top block and one of the side braces, plus cutting off the inside lip of the battery tray. If interested I'll post some pics.
Yeah, still running the original starter battery with the 1.5 dump pack. Some pics would be great.
TM is offline   Reply With Quote
Old 06-17-2015, 01:05 PM   #325
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
I get it all the time with the OFT tune, but I noticed recently since it has started to heat up outside I don't get it as bad. Winter it smelled pig rich. Also when I ran my E-85 tune last year I almost couldn't smell it at all, and when I did, it smelled pleasant
Thanks for the info! I'm running 91 and only get the occasional smell from time to time at WOT. If I turn the ESC off and just run with ESC tune, no smell.
I haven't been curious enough to drive out of my way and try e85. I'll just get a beer and fries
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 06-18-2015, 12:22 AM   #326
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
My layout is pretty much the same, the dual dumps are just about 1/2'' wider than the battery tray and brace.
I forgot the nuts, I just used whatever I had around that would work as a spacer, and used some longer screws.
It's dark and really hard to see, so I highlighted the end of the tray. I just ran it through a table saw and cut the lip off the side so the battery could overhang.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
TM (06-20-2015)
Old 06-21-2015, 06:19 AM   #327
TM
TM's Avatar
Drives: DGM BRZ 6MT
Anyone here running something other than the OTS tune? Wondering how much extra horsepower can be squeezed out from a custom tune...
Old 07-03-2015, 04:17 PM   #328
fenton
Did you ever get this resolved?
Yes @dtek did get this resolved. Dtek is actually in Australia so he took his US based kit and converted it to RHD. This meant extending a bunch of wires. Long story short there was one extension that was not up to snuff for the amount of watts that ESC was pulling.
Once he fixed that issue he is back to where he should be.
fenton is offline   Reply With Quote
The Following 4 Users Say Thank You to fenton For This Useful Post:
DAEMANO (07-04-2015), dtek (07-03-2015), Fareast auto part (07-03-2015), Gums (07-07-2015)
Old 07-03-2015, 04:21 PM   #329
fenton
I was running a custom tune of Shiv's but it was on a different controller and charger....i was making ~230 whp on 93 octane.
Shiv's standard tune is VERY good....a custom tune will only maybe get another 5 or so HP out of it(on standard fuel) but it will be more aggressively tuned to the knock threshold.
I also had a "custom" tune(from different tuner) before going to shiv's OTS map and i was only making 197hp whereas shiv's was making 208....he has the most experience and seat time with the ESC.
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (07-04-2015), Fareast auto part (07-03-2015), Shiv@Openflash (07-03-2015)
Old 07-22-2015, 11:17 PM   #330
keen as
keen as's Avatar
Drives: 86 GT MT
I installed a second hand USA kit from Gary in NJ, and made longer cables to fit RHD in Australia. Thanks Gums for giving me the dump cable and to dtek for converting the USA tune for my A01G ROM.
I converted the throttle switch by reversing the folds of the bracket. I plan to get the Procede soon.
The cables are in a temporary position until I decide the final length and location, probable under the manifold.
keen as is offline   Reply With Quote
The Following 3 Users Say Thank You to keen as For This Useful Post:
Gums (07-23-2015), raven1231 (07-23-2015), Sojhinn (07-22-2015)
Old 07-22-2015, 11:19 PM   #331
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Nice job sir. Didn't know Gary left us.
Installed Mods:
Old 07-22-2015, 11:22 PM   #332
DAEMANO
Time Traveller
See what happens when you take some time off? The whole place goes to pot! Hahaha!
DON'T DO IT AGAIN.
Old 07-22-2015, 11:23 PM   #333
Sojhinn
Sojhinn's Avatar
Phantom FTS Electric Supercharger Owners Thread
LOL
Installed Mods:
Old 07-23-2015, 07:48 PM   #334
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Looks great Lawrence. Enjoy it. I sure did.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
keen as (07-23-2015)
Old 07-26-2015, 04:10 AM   #335
Gums
Drives: SWP BRZ
Smile
Inspired by @fenton
I like it!
Gums is offline   Reply With Quote
The Following 5 Users Say Thank You to Gums For This Useful Post:
DAEMANO (07-26-2015), keen as (07-26-2015), raven1231 (07-26-2015), Sojhinn (07-26-2015), stevo585 (07-26-2015)
Old 07-26-2015, 09:38 AM   #336
Sojhinn
Sojhinn's Avatar
Originally Posted by Gums View Post
Inspired by @fenton
I like it!
High temperature paint?
Installed Mods:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
