Old 07-20-2015, 03:14 AM   #1
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
KONI yellow install issue HELP PLEASE
For those of you that installed your KONIs, what size drill bit did you use on the rear top hats? The instructions say to use a 12 mm drill bit but they don't sell metric drill bits anywhere near me. Would a 15/32 be too small. Or maybe use a 1/2 bit
Devil 86 is offline   Reply With Quote
Old 07-20-2015, 12:53 PM   #2
wparsons
wparsons's Avatar
15/32 is about 0.1mm too small, but I'm not sure how tight the fit is.
flickr
Old 07-20-2015, 04:44 PM   #3
fika84
fika84's Avatar
12 mm = 0.476 inches
15/32 inches = 0.46875 inches
31/64 inches would be the closest that isn't too small.
fika84 is offline   Reply With Quote
Old 07-20-2015, 07:13 PM   #4
vroom4
doeant have to be perfect.
vroom4 is offline   Reply With Quote
Old 07-20-2015, 07:23 PM   #5
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
I used a 1/2 drill on mine... no issues so far and I track my car hard.
Cartman is offline   Reply With Quote
Old 07-21-2015, 05:26 AM   #6
Devil 86
Devil 86's Avatar
@Cartman, how did u tighten the top nut? I can't torque it down without the shaft spinning.
Old 07-21-2015, 05:36 AM   #7
swarb
Vice grips and a rag. Doesn't matter if the shaft at the end gets scratched a little, with the bump stops they never go into the body anyways.
Old 07-21-2015, 02:12 PM   #8
Devil 86
Devil 86's Avatar
How'd u get vice grips on the shaft when the dust boot is in the way?
Old 07-21-2015, 02:32 PM   #9
swarb
I ran with no boots on the koni setup on a previous car.
http://www.ft86club.com/forums/showthread.php?t=39028
there is that option also. No real torque rating unless you find a pass through torque wrench.
Old 07-21-2015, 10:21 PM   #10
Devil 86
Devil 86's Avatar
@swarb how long did u have your konis with no dust boots. I may have to go that route but I don't know if running no dust boots will affect the lifespan of my konis
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks Kyogre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-12-2015 05:59 PM
Stuck - Koni Shocks & TRD Spring install issue ButteR Scion FR-S / Toyota 86 GT86 General Forum 9 05-05-2015 01:09 AM
Koni Rear Ride Height Too High; Install Issue rene0023 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-06-2014 06:01 PM
Koni Install Issue WolfSongX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-22-2013 10:17 PM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 01:10 PM
