Old 01-31-2015, 04:05 PM   #1
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
RomRaider
Ok Ok
I've searched for the last hour. Can SOMEONE help me get my Romraider setup properly? I got it installed, but I can't get it to open anything. WHAT in THE blue hell am I not doing right?
itsjustdavep is offline   Reply With Quote
Old 01-31-2015, 05:33 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably not added a definition file. First important question, tactrix or Oft?
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-31-2015, 05:51 PM   #3
itsjustdavep
OFT @Kodename47
Old 01-31-2015, 11:54 PM   #4
steve99
Drives: FT86
Originally Posted by itsjustdavep View Post
use romraider defs that come from OFT site for your tune make sure you use oft definition for v1 or v2 tunes depending on which tune you are running , use the def that matches your rom type
DO NOT USE DEFS FROM ROMRAIDER GITHUB SITE WITH OFT TUNES
read tune tweaks post below
Old 02-01-2015, 12:55 AM   #5
itsjustdavep
So do I load the defs, then open a map?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
Old 02-01-2015, 01:00 AM   #6
steve99
Drives: FT86
yes, you only need to load the one def corresponding to your oft rom calid
the definition tells romraider where the tune tables are located in the rom hex code, the locations are different for each rom type.
Old 02-01-2015, 01:02 AM   #7
itsjustdavep
Standby. I'm new to this. I will say ty in advance because this is the first forum that's been nothing but helpful to me. When I was on ls1 tech they were mostly a-holes
Old 02-01-2015, 01:10 AM   #8
steve99
Drives: FT86
no problem mate
just take it slow and get used to romraider and what tables look like before you start changing anything, if the tables look weird or corrupted something is incorrect dont flash the rom.
read here as well
http://www.ft86club.com/forums/showthread.php?t=79152
then probably read the rest of the links relitive to oft below
Old 02-03-2015, 04:22 PM   #9
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
You have to link the definitions file through romraider. I think it is in setup top somewhere.
Toyota John is offline   Reply With Quote
Old 02-03-2015, 04:24 PM   #10
itsjustdavep
I finally got it that night.
Old 02-10-2015, 11:30 PM   #11
itsjustdavep
update. so i used this Virtual Dyno thing. got it set up somewhat proper... on E85 stg2 EL tune with fresh oil and air filter... Do those estimated numbers look right? lol curve looks proper, rpm doesnt...
http://datazap.me/u/itsjustdavep/roa...ata=0-1-2-4-13
The Following User Says Thank You to itsjustdavep For This Useful Post:
aagun (07-17-2015)
Old 07-15-2015, 09:41 AM   #12
poolboy54
Drives: Scion FRS. Silver with black badges
Have the software but I can't load defs. Am I missing a step?
poolboy54 is offline   Reply With Quote
Old 07-15-2015, 02:41 PM   #13
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
You upload the defs (XML files) from OpenFlash supplied in the folder, not the one that's in RomRaider's folder. Make sure the cal matches or it won't open when you use your original stock file. Load the XML def based on your CAL and then open it with your stock tune that OpenFlash Tablet has stored and it should open. Do you know your CAL ID number?
efactor84 is offline   Reply With Quote
Old 07-15-2015, 04:24 PM   #14
stevo585
Drives: White 2014 BRZ
Do you go to the Orlando 86 weekly meets? (on facebook). I'm sure someone there could help you.
stevo585 is offline   Reply With Quote
Using RomRaider to edit tunes ( ROM) files OFT and non- OFT steve99 Software Tuning 56 11-18-2020 08:41 PM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
need some help with romraider logger toyotaAlex Software Tuning 2 07-06-2014 07:07 PM
romraider/OFTquestion/problem? bkblitzed Software Tuning 10 06-08-2014 02:30 AM
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 11:24 AM
