Old 03-24-2014, 09:13 PM   #1
wparsons
wparsons's Avatar
RomRaider XML definitions.
Just a question about which definitions to use with OFT OTS tune files... do you use the definition that matches whichever OEM ROM you have, or the one that matches the OEM ROM the new tune is based off?
ie 700C to match my factory ROM, or A10C to match the base ROM used for the OTS 1.5x tunes?
flickr
Old 03-24-2014, 09:15 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
There are XML's on the OFT site for download, if you are editing an OTS tune you can do so with TD-D's A01C XML but you won't see launch control or FFS as that is only included in the definitions provided on the OFT site.
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-24-2014, 10:48 PM   #3
shif7i7down
Erected Member
Drives: frs
I'm assuming you mean A01C which should match your particular car,
in which case you would use the xml file that reads RR_ZA1JA01C.xml
shif7i7down is offline   Reply With Quote
Old 03-25-2014, 08:23 AM   #4
wparsons
wparsons's Avatar
Sorry, yeah.. meant A01C.
So just to confirm, even though I'm using the 700C bin file (which is based on the A01C ROM) from Shiv, I should use the A01C XML definitions?
flickr
Old 03-25-2014, 08:51 AM   #5
shif7i7down
Erected Member
Drives: frs
You'll know if you used the right xml or not, if it doesn't load the ots map then you've used the wrong xml. that's what happened to me...btw if you don't mind me asking, what are you planning to change? I don't know much but Maybe i could point you in the right direction
Old 03-25-2014, 10:23 AM   #6
wparsons
wparsons's Avatar
I used the 700C XML file and I can see all the tables (plus the FFS and LC extra stuff), looks like I'm good to go with it.
I'm not changing anything just yet, but will be redoing the MAF scaling once I get a couple more logs, then after that is cleaned up I'm going to look into patching up the ignition tables so I'm not dropping IAM in stop and go traffic.
flickr
Old 03-25-2014, 10:43 AM   #7
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Got a link to the procedure you are using to scale the MAF? Are you going to scale DI and PI separately ("he who must not be named" evidently had a procedure for doing this...)?
My LTFTs suck (> 5%) and I would like to do something about this.
Ralph Spoilsport is offline   Reply With Quote
Old 03-25-2014, 11:05 AM   #8
shif7i7down
Erected Member
Drives: frs
I see. Post back when you figure out the IAM issue, I'm assuming you're having engine knock and I'm interested in what you plan to do correct it besides better fuel.
Old 03-25-2014, 11:15 AM   #9
wparsons
wparsons's Avatar
MAF scaling is 100% separate from injector scaling.
MAF scaling is basically a correction table that just gives engine load values for a given MAF voltage. It's a one dimensional table, and doesn't touch injectors or anything else at all.
I don't have a how to yet, gotta work that out with someone that used to be a member. Once I get more details I'll share them for sure.
flickr
Old 03-25-2014, 11:24 AM   #10
Vmax911
Drives: WRB BRZ
My car was originally 700C. I'm changing the ignition advance table to correct the "traffic knock" and am using the files downloaded from the OFT website. Working well so far...
Vmax911 is offline   Reply With Quote
DIY Rom tuning for exhaust pops and backfires W/ romraider andrew5826 Software Tuning 703 11-14-2022 04:44 AM
OpenFlash Tablet: RomRaider parameters for Launch Control and Flat-foot Shift Shiv@Openflash Software Tuning 118 06-04-2017 04:26 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
