Northwest AK, ID, OR, WA
Old 07-06-2015, 03:40 AM   #43
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by Decay107 View Post
Heli coil time! I know exactly which bolts you are speaking of too, it scared me how tight the factory torque was on Matt's car.
No idea what Heli coil is. Whatever it is, if it helps me I'll take one. Yes they were on so tight I thought I'd burst a vain.
Old 07-06-2015, 03:46 AM   #44
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
A Heli coil is a thread insert
It's the proper way to repair exactly what's happened here, as a bonus it'll be stronger than the non Heli coiled threads.
Decay107 is offline   Reply With Quote
Old 07-06-2015, 03:56 AM   #45
stockysnail
Just the tip
Looks cool. Where do I get one or can you get one for me?
Old 07-06-2015, 04:07 AM   #46
Decay107
Decay107's Avatar
Amazon, can't remember if they were 8's or 10's, find out and order the proper size and thread pitch. The following is an example (and my best blind guess as to the right thread)
[ame="http://www.amazon.com/Helicoil-5546-8-Metric-Coarse-Thread/dp/B0002SREP4"]Amazon.com: Helicoil 5546-8 M8 x 1.25 Metric Coarse Thread Repair Kit: Automotive[/ame]
Old 07-06-2015, 12:00 PM   #47
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Man it's good that you want to fix your own car but for the love of God stop driving it until you figure it out. When you said it was running normal again and "maybe it just needed a full tank of gas" I just about spit my milk all over my monitor. That many engine codes = problem that doesn't just fix itself.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
Tcoat (07-06-2015)
Old 07-06-2015, 12:03 PM   #48
Decay107
Decay107's Avatar
I'd recommend taking it in to a shop, installing heli coils will involve drilling into your block and re tapping the fuel rail hole. It's not that difficult, but not something I'd suggest doing unless you have 100% confidence.
Old 07-06-2015, 01:16 PM   #49
stockysnail
Just the tip
Called the Subaru dealer this morning. They said they had the part (o-ring washer for the port injector). Rode my bike there, the guy at the counter said they didn't. Best he could do is order it and have it tomorrow and give it to me 40% off so $4 ish instead of 8. Rode my bike to Toyota on the way home and they didn't have it either. Even if I do get the injector back on with the new o-ring seal, my bolt hole in the supercharger manifold is also stripped so I may be screwed as I'm not sure it will hold down tight. I also don't know if the injector seal was the issue or not.
After I get the injector in and either with the helicoil or without if it will hold enough, which shop should I take it to? I've only been to PRE and they aren't my favorite, plus on the opposite side of town.
Old 07-06-2015, 01:40 PM   #50
Don't try to run it until the rail mount is repaired. Unless you saw a greasy mess where you pulled the injector, I'm pretty sure the o-ring was damaged during disassembly.
No offense, but I don't think you're ready to do a helicoil job yourself. Also, this is a lesson in following factory torque values. Unfortunately, both you and Matt are victims of ham-fisted mechanics that installed your blowers.
Maybe Doug knows someone he trusts? I don't. I have the correct helicoils but I'm across town, at work, and still have my wife's car on jackstands....
Old 07-06-2015, 02:05 PM   #51
Decay107
Decay107's Avatar
So does this mean you have two stripped bolt holes now? The fuel rail bolts do not thread into the manifold, they thread into the engine block.
Don't drive until fixed unless you're willing to risk a fire. I'd trust AR Auto to do the heli-coil, they are a full service shop and will have experience with them. I believe @Jonsey86 has 4 spare injector o-rings right now, you might be able to work something out with him.
Old 07-06-2015, 02:15 PM   #52
stockysnail
Just the tip
I have impeccable timing then don't I.
Especially since the big meet is Sunday. Running out of time!
Old 07-06-2015, 02:19 PM   #53
stockysnail
Just the tip
Just one bolt hole still. The fuel rail mounts to the supercharger manifold, not the engine block. Driver's side.
I'll call AR auto service to see what they say.
Old 07-06-2015, 02:25 PM   #54
Decay107
Decay107's Avatar
Ah so it does, I was mistaken.
Old 07-06-2015, 02:41 PM   #55
stockysnail
Just the tip
AR auto said they are booked all week and would be able to look at it until next week. That means I'd miss the big event Sunday. Anyone else I could take it to? I may need to use @Ultramaroon or try the Helicoil myself along with the new o-ring I'm getting from the dealer tomorrow, then see if it will give me engine codes again or if it's good. I don't want to miss the event but also don't want to f-up my car more.
Old 07-06-2015, 04:11 PM   #56
Decay107
Decay107's Avatar
To be fair, any shop should be able to do heli-coils pretty easily they're a standard tool in the mechanic's bag-o-tricks. I've never heard a dissatisfied customer from VIP performance, I know quite a few people who have them work on their (non-twin) cars and this job does not require model specific knowledge.
unichip p0172 engine code bvelna Software Tuning 16 08-13-2016 08:45 AM
P219A ENGINE CODE Albaro08 Issues | Warranty | Recalls / TSB 6 12-29-2015 05:15 PM
P0328 Engine Code Lil Abner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-23-2014 12:10 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 04:23 PM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 10:37 PM
