Old 03-07-2015, 04:15 PM   #1
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
P219A ENGINE CODE
I had a accident and had it covered by insurance wasn't to bad but they did mess around with the with the front end of the car and I got it back and now the engine light came on took it back seems like they just erased it becuase now it came back on took about maybe 10 miles to turn back on now my feeling is that maybe the messed up the air flow senser or maybe when in paint or around dust the sensor got clogged or messed up becuase everything looks normal the work got done at toyota so I'm guessing that what it is now I'm taking it back becuase they have to change the wheel bearing and I'll let them know to also fix this becuase it wasn't on even after the accident but any word from you guys would help
Albaro08 is offline   Reply With Quote
Old 03-07-2015, 05:31 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Wat
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-09-2015, 08:25 AM   #3
steve99
That code is air fuel ratio imbalance
likely causes
intake or exhaust leak crack damage
crook or damaged maf or oxygen sensors.
Old 03-26-2015, 09:22 AM   #4
Albaro08
Albaro08's Avatar
Thanks at Steve99
Old 03-26-2015, 09:24 AM   #5
Albaro08
Albaro08's Avatar
The intake has no leaks but maybe maybe they damage the oxygen sensor when taking off the front end
Old 03-26-2015, 09:50 AM   #6
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
Longest run-on sentence in FT86Club history?
ImBatman is offline   Reply With Quote
Old 12-29-2015, 05:15 PM   #7
MelloFlow
Drives: 2013 Raven FR-S
Did you ever find out what was causing this code?
MelloFlow is offline   Reply With Quote
unichip p0172 engine code bvelna Software Tuning 16 08-13-2016 08:45 AM
P0328 Engine Code Lil Abner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-23-2014 12:10 PM
O2 censor engine code then no cruise control! DrewIsAmus BRZ First-Gen (2012+) — General Topics 7 01-27-2014 09:06 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 04:23 PM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 10:37 PM
