Old 06-30-2015, 01:43 PM   #323
D_Thissen
D_Thissen's Avatar
Originally Posted by Tectoniic View Post
Not sure if this is the best spot to ask but how many tanks of e85 do you think it is safe to put through the car before switching to an e85 compatible oil? I'm on my second tank after just using oft to try it out and now i dont want to go back to pump gas, i love the corn too much. Should i be looking to oil change soon? I still have 3 free full synth changes at the dealership and i will be going back to a 93 tune for the winter
I would probably change the oil twice as often as you would on 93.
"If you are going to run E85 long term you should make sure your oil is E85 compatible (SN or GF-5 rated oils are generally Bio-fuel E85 compatible), and change your oil twice as often if your paranoid. If you get oil analysis done and your not showing fuel dilution you may be able to run standard oil change intervals, im just being safe here.
see here http://www.pqiamerica.com/apiserviceclass.htm
You may consider running something similar to Lucas Ethanol Treatment."
http://www.ft86club.com/forums/showp...81&postcount=1
Old 06-30-2015, 01:47 PM   #324
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Thanks for the API oil link. I had read whole thread on e85 on a stock car and the more frequent oil changes with a compatible oil. I just didn't know if anyone had an offhand "you can get away with approx 5 tanks with no harmful effects". Worst comes to worst ill just change for the summer and use my dealership oil change right before winter.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 07-07-2015, 08:57 AM   #325
mikalow86
Drives: Toyota 86
Hi guys, I was going to upload a rom onto the OFT tonight and it came up with an error. The error appeared when I select upload only. I can browse other part of the OFM but just not the upload section. This happened once few days ago when I was doing the same thing however the OFM restarted on it own and then all my original rom's got deleted off the OFT. I was able to upload the original rom I had backed up and other rom's and flashed the tune without a problem.
I have tried reinstalling the OFM to the latest 1.21 and my current firmware ver is 1.33. I also tried different USB cable and on different computers, still the same error. Does anyone know what else I can do?
mikalow86 is offline   Reply With Quote
Old 07-07-2015, 09:25 AM   #326
steve99
Drives: FT86
see the oft tips link below download the refsen.zip file unzip it
try installing the refsan.ttf to C:\windows\fonts directory
grab the latest template file as well 7.2 i think.
make sure you install ofm as administrator, maybe delete old version the reinstall from scratch if still issues.
Old 07-07-2015, 09:58 AM   #327
mikalow86
Drives: Toyota 86
Hey Steve I have installed the latest template file 7.2 and also download your zip file and installed the fonts. Reinstalled OMF from scratch, still having the same issue.
Old 07-07-2015, 10:07 AM   #328
steve99
Drives: FT86
hmmm that weird.
the roms your uploading correspond to your original calid like A01G or whatever your original rom was.
If still no luck try deleting all the tuned rom files from oft .
Then try again.
If still no go then try writing back your original rom to car then "erase oft completly" then reload original rom and start from scratch
after that im pretty mich out of ideas you will have to contact OFT guys.
Old 07-07-2015, 05:45 PM   #329
elBarto
elBarto's Avatar
Drives: Toyota GT86
This is most likely a (dot).net error code. Try to (re)install the OFM win8 patch and the necessary dotnet packages (3.0, 3.5, 4.0, etc).
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 07-07-2015, 10:05 PM   #330
mikalow86
Drives: Toyota 86
hmmm that weird.
Then try again.
Hey Steve, yeah the rom is the right one, I will try see if I can flash it back to original rom and then erase OFT and start again.
I am using Win 7, by installing the Win 8 patch would that help? Thanks
Old 07-07-2015, 11:08 PM   #331
steve99
Drives: FT86
I dont think the win8 patch will help.
if you have another computer try that , but the oft\ofm software does not like usb 3 ports.
Old 07-14-2015, 08:10 PM   #332
BBYZILA
BBYZILA's Avatar
Drives: 2013 Firestorm FR-S
could someone please help me?
I heard that you can modify a STG2 UEL 93 OCT tune to reduce the warmup period that is so loud. Could someone edit a file for me and send it to me? I'm not sure how to do it and I'm afraid I will mess up my tune and my ECU.
Thank you!
BBYZILA is offline   Reply With Quote
Old 07-14-2015, 11:12 PM   #333
JB86'd
JB86'd's Avatar
Drives: JAWS
Yes I'll just need...
JB86'd is offline   Reply With Quote
Old 07-14-2015, 11:30 PM   #334
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Thank you!
Never trust someone else to send you a tune unless it's an official vendor like OFT or a tuner.
http://www.ft86club.com/forums/showt...=55676&page=11
That's the link to do it yourself
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 3 Users Say Thank You to Aztec For This Useful Post:
BBYZILA (07-15-2015), JB86'd (07-14-2015), swarb (07-14-2015)
Old 07-15-2015, 12:27 AM   #335
BBYZILA
BBYZILA's Avatar
probably for the best, thanks!
Old 07-15-2015, 12:43 AM   #336
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
el-92 is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
