Old 06-30-2015, 10:02 AM   #1
dejxx
dejxx's Avatar
Drives: FT-86
Need advice on suspension set up
Quick background... i live in Argentina, and roads here SUCK, really really SUCK. So my suspension set up cant be very low or rough. My car is the FT86 (base version sold outside USA). Its a turbo, running around 290whp. Also running AP Racing Sprint kit with Ferodo DS2500, and stock brakes on the rear.
This question refers to suspension set up for TRACK DAYs. Right now the only mods i have suspension wise are Eibach Pro Kits and Whiteline front camber bolts, nothing else. Track rims are Enkei RPF1 17x7.5 with full R compound slick tires. At low speed corners the car behaves well enough, it turns and rotates with throttle (i would say it looses the rear quite easy for a car with slick tires and only 290whp). BUT at high speed turns things get a little crazy, and the car seems to loose the rear quite easy... which isn't good at +100mph. If i remember correctly camber is around -1.25 front and -1.5 rear.
So... what do you guys recommend for a cheap and fast fix for this...? rear sway bar? LCA? wider wheels? tires are kinda the best you can go for track use...
Appreciate it!!!
dejxx is offline   Reply With Quote
Old 06-30-2015, 10:17 AM   #2
Racecomp Engineering
How is your toe set?
More rear camber (and front while you're at it) would improve the car.
A mildly larger front swaybar may make an improvement, but start with alignment.
- Andrew
Old 06-30-2015, 10:41 PM   #3
dejxx
dejxx's Avatar
Drives: FT-86
if i remeber correctly toe was at 0 at front and a little bit of toe out at the rear...
I will go with a full alignment before the next track day and test it out.
Old 06-30-2015, 11:00 PM   #4
swarb
Toe out in the rear is the problem.
The Following 2 Users Say Thank You to swarb For This Useful Post:
fika84 (07-01-2015), Racecomp Engineering (07-01-2015)
Old 07-01-2015, 12:35 AM   #5
Yup.
A tiny bit of toe-in would be a good idea for you. That would help keep the car rear end stable. Start there.
- Andy
Old 07-01-2015, 11:07 PM   #6
dejxx
dejxx's Avatar
Drives: FT-86
thanks for the input guys! ill try that before doing some major mods.
suspension advice NoobTron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-03-2014 12:15 AM
suspension setup advice edsbreezy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-03-2014 11:14 PM
Need some Suspension advice! LazerBrZ Mid-Atlantic 6 10-09-2013 09:36 AM
Suspension advice? GTBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 11:38 AM
Some advice on suspension from serious drivers NON-VTEC Tracking / Autocross / HPDE / Drifting 15 02-01-2013 01:12 PM
