Old 02-03-2014, 08:31 PM   #1
edsbreezy
edsbreezy's Avatar
Drives: 2014 Subaru BRZ Premium - Red
suspension setup advice
hi guys, just looking for advice for my suspension setup, just purchased these items:
1) RPF1 18x9.5 +38 square
2) 245/35/18 tires
3) BC BR coils
4) cusco front and rear strut bars
im not looking to go really low, just wanted the adjustability of coils instead of springs. anyways, should i throw in some sway bars as well? i don't track, just weekend spirited driving so I'm still a little hesitant on pulling the trigger on a set. any suggestions?
edsbreezy is offline   Reply With Quote
Old 02-03-2014, 09:08 PM   #2
JS86JS
JS86JS's Avatar
Drives: 2013 Toyota 86 GTS, Marine Blue
I'm currently putting together my suspension setup.
From what I have been told; 18x9.5 won't fit with stock suspension as it will hit/rub them.
From what I was told and what I have researched, I am getting 18x8.75 with tein coil overs. I'm taking my wheels to the place I'm getting my coilovers installed so they can install the wheels, adjust height and camber in regards to what space is available etc..
Also I'm a DD, haven't tracked and probably won't this 86
Injen Catback, Injen CAI, Borla UEL headers, ecutek tune w/ racerom, alloy pulley kit, Yokohama Neova AD08; 189hp at the wheels best dyno
check out my on-going build here: My blue 86
JS86JS is offline   Reply With Quote
Old 02-03-2014, 09:27 PM   #3
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
2) 245/35/18 tires
3) BC BR coils
I'd just install what you've already purchased and see how you like it. Sway bars can easily be added later if you want. Although I don't think you'll need them as your BC coilovers and stock sway bars will do a sufficient job of controlling body roll by themselves.
jprice130 is offline   Reply With Quote
Old 02-03-2014, 10:14 PM   #4
fatoni
i find it odd that people buy parts in bulk like that on a platform this new. waiting for the sway bars isnt going to cost you anything. put all the stuff you bought on the car and then decide if it needs sway bars or not. i can almost guarantee that you wont need sway bars though.
Different Suspension setup on BRZ? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-13-2013 08:36 PM
Thoughts/advice on on wheel setup jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-23-2013 01:26 AM
Building audio setup. Need amplifier advice from the experts Kayzer Soze Electronics | Audio | NAV | Infotainment 69 06-04-2013 09:50 PM
setup of suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-21-2012 03:03 PM
In need of advice (full setup) computertech01 Electronics | Audio | NAV | Infotainment 8 08-02-2012 06:23 PM
