Old 06-06-2015, 02:37 PM   #1
TooFRSh
Drives: Argento FRS MT
Help with lug nuts for aftermarket wheels
Hey everyone I just recently got some XXR wheels and I wanted to use the stock lug nuts but was told they were too wide. I want to know if there is a specific type made for XXR wheels or just any aftermarket brand of lug nuts is fine. Any input would be greatly appreciated. Thank you!
TooFRSh is offline   Reply With Quote
Old 06-06-2015, 03:12 PM   #2
ryoma
ryoma's Avatar
any conical lug nut will be fine. don't use the stock lug nuts on aftermarket wheels and don't use aftermarket lug nuts on stock wheels
Old 06-06-2015, 03:55 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The first statement is true as long as the wheel accepts those lug nuts.
The rest of your statement is completely false. As long as the lug fits and you have a proper seat, you can use any lug with any wheel.
-alex
Sportsguy83 (06-10-2015)
Old 06-06-2015, 04:14 PM   #4
Baldoak
BRZ N02
Baldoak's Avatar
Drives: 2013 A/T Subaru BRZ Limited, SWP
You should be able to tell which type you will need by looking at the mounting holes on the wheel.
Baldoak is offline   Reply With Quote
Old 06-06-2015, 04:52 PM   #5
ryoma
ryoma's Avatar
-alex
most aftermarket lugs are conical and most stock wheel mounting points are flat. you definitely don't want to use a conical lug on a flat mounting point where it's supposed to be a bolt with washer. obviously there's exceptions though.
Old 06-06-2015, 05:07 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Like the Twins which use conical seating for the stock wheel... and I've used the stock lug nuts for every set of wheels I've had on the car... except one which the holes were too small like for the OP.
If the problem is cone diameter of the nut and tool fitment, look into the Gorilla small diameter splined lug nuts (in 12mm x 1.25mm fitment for Subaru), can get them locally at any Discount Tire store. I have a set of old Enkei RS-5 wheels that have to use them and they just barely fit when nothing else easily available does.
http://www.gorilla-auto.com/small-diameter-lug-nuts
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 06-06-2015, 08:40 PM   #7
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Play it safe and get some XXR lug nuts
Lunatic is offline   Reply With Quote
Old 06-06-2015, 08:42 PM   #8
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
kyokugen.
ebay search
Sammakko is offline   Reply With Quote
Old 06-07-2015, 02:41 PM   #9
TooFRSh
Thanks for the help guys. So I needed these by Monday so I checked out some auto zones but I've only been able to see acorn nuts instead of conical. Will these be ok or do they only fit conical?
Old 06-07-2015, 02:47 PM   #10
Vroomin86
Drives: 2015 Fire
Acorn and Conical are one in the same. You are fine using "acorn"/conical lug nuts. I use my stock lug nuts on my aftermarket wheels with no issues.
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 06-07-2015, 03:04 PM   #11
TooFRSh
Ok thanks. I'll let you all know if they work out tomorrow haha
Old 06-08-2015, 10:11 PM   #12
TooFRSh
Ok so after I bought the wrong set of lugs (12x1.50) I returned them and found out the lugs are actually 12x1.25. Everything was smooth sailing after lol. I wanna thank everyone who posted in this thread and helped me. Thank you! You guys da real MVPs haha
Old 06-10-2015, 11:53 AM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Stock 86 lug nuts are conical and can be used with most aftermarket wheels.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
avishenoy1 (12-28-2015)
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
OEM lug nuts with aftermarket wheels? srtblake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-18-2014 03:48 PM
Aftermarket lug nuts with trunk spare? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-07-2012 08:27 AM
Factory wheels with aftermarket lug nuts. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-21-2012 08:40 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 02:04 PM
