Old 07-18-2014, 02:19 PM   #1
srtblake
Chrysler/jeep/dodge tech
srtblake's Avatar
Drives: FR-S driver
OEM lug nuts with aftermarket wheels?
I recently picked up a set of BBS wheels for my BRZ, I put them on and fitment is good, I'm curious if I run the oem lug nuts with these rims or if I need a more "specific" conical lug nut to use? IIRC 90%+ of lug nuts are conical design and this should be fine. Just wanted to ask anyone who could help me out!
these rims
http://www.bbs-usa.com/road-wheels-d...fm?CLID=7&WF=6
False start member
srtblake is offline   Reply With Quote
Old 07-18-2014, 03:26 PM   #2
Ubersuber
Drives: BRZ Pearl White
Usually, wheels have type specific lug nuts. If you bought from a reputable wheel supplier they should have included the new hardware IF it is required. Some aftermarket wheels no doubt use the same spec lug as the OEM, just on the odds.
The conical shape is critical to safety, it need to match the conical recesses in each bolthole for safety. If the face of the nut doesn't match the face of the hole in the wheel then point loading can damage the wheel or have it work loose.
To check you could remove one nut, coat it with powder and carefully screw it back on until the faces just touch, then remove and see if there is a ring of contact or an area. If the slopes don't match you will see a ring of contact revealed in the powder, not good. If there is an area of contact then the slope of the two surfaces is the same and you're good to go.
Carefully clean off any powder you choose to use as lubricating a lug nut is a no no, it'll work loose for sure.
Ubersuber is offline   Reply With Quote
Old 07-18-2014, 03:48 PM   #3
jvincent
jvincent's Avatar
The OEM nuts are conical.
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Subie Lug Nuts on Work wheels? Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-20-2013 05:50 PM
Aftermarket lug nuts with trunk spare? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-07-2012 08:27 AM
Factory wheels with aftermarket lug nuts. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-21-2012 08:40 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 02:04 PM
