Old 11-07-2012, 01:29 AM   #1
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Aftermarket lug nuts with trunk spare?
Today I saw someone driving around on a donut, and it occurred to me that I might be in trouble if I got a flat tire. I'm currently running aftermarket wheels with McGard cone seat lug nuts. Will these lug nuts work with the stock trunk spare wheel? If not, I should probably throw 5 of the stock nuts in the trunk.
This thread (http://www.ft86club.com/forums/showthread.php?t=19919) is suggesting you can use aftermarket conical lug nuts with the stock wheels, but I wanted to check on the spare.
However, I also found this in another thread:
Originally Posted by cnk View Post
Stock lug nuts are known as acorn nuts and aftermarket lugs do not have the same taper as acorn nuts. I usually only use the OEM lugs on OEM rims and use aftermarket lugs on aftermarket wheels just to avoid any issues with the lugs not being able to properly secure the wheels to the hub.
Phaedrus29 is offline   Reply With Quote
Old 11-07-2012, 07:26 AM   #2
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
I keep 5 stock lug nuts in a ziplock in the trunk for this purpose
sajonf is offline   Reply With Quote
Old 11-07-2012, 08:27 AM   #3
TuxedoCartman
Drives: '13 86
On Subarus (and the FR-S, but I repeat myself... HA!!!) the lug-nuts are conical, which makes them identical to any of the aftermarket lug-nuts you could buy. Subaru wheels are probably the only stock wheels in the world you could use Rays, Project Kics, or Mutegi on just fine.
So it seems to follow that if you can use stock lug-nuts on the spare tire, then you can use aftermarket ones as well.
TuxedoCartman is offline   Reply With Quote
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk No Limit Motorsport Exterior Parts (Aero, Lighting, Etc.) 5 10-03-2012 09:03 PM
WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk No Limit Motorsport NY / NJ / CT / PA 6 09-27-2012 10:14 AM
Factory wheels with aftermarket lug nuts. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-21-2012 08:40 PM
