Old 06-02-2015, 04:25 AM   #1
alex6219
alex6219's Avatar
Drives: 2013 scion frs (white)
ECUTEK for automatic FRS problems
Hey everyone,
I'm new to the forums and I'm having trouble understanding how to do this ECU flash. I have a 2013 Automatic FRS, I bought the stage 2 NA tune from Delicious Tuning and just received it today. I will be taking my car to delicious tuning for them to correctly adjust the tune in about 2 weeks...but I was told to go ahead and flash the ECU myself before taking it in.
I downloaded the drivers from ecutek (app downloader and ProECU), I followed a video on how to do it and heres the steps I did (please correct me if I did something wrong)
1. Open ProECU and download all ROM updates.
2. Click "File" then "Open ROM file..."
3. Open folder "ProECUromfiles>Subaru>BRZ"
4. I wasnt sure which of the 18 files I should pick.
5. Plugged in the cable from my ECU to my computer
6. Clicked "Tools" then "Detect Vehicle..."
7. I detected my "Subaru BRZ/Toyota FT-86"
8. Selected "Program engine ECU"
9. Under the "Compatible ROM files" screen, the compatible on that was listed that appeared under my "ROM files" was "ZA1JD00D"
10. Selected "ZA1JD00D" from Rom list
11. Select "Query ECU"
12. Program ECU, then let it download, turned off the car, turned it back on after complete.
After installing the tune, I drove the car around a bit but I noticed SIGNIFICANT lag in the acceleration.
-When in "Drive", I will floor the gas pedal but the car accelerates extremely slow and will make it to 4k RPM and then just rev until I let off the gas a bit.
-When switching to "Manual", I will try to accelerate but its still extremely slow.
Is there a reason that its so extremely slow or will I have to give it time to "re-learn"? I also tried the "turn to on, fully press and depress gas 20 times, turn off, press 20 times again, then turn off again, then drive" method but it still is slow.
I have Injen CIA, PPE EL headers and Invidia N1 exhaust.
Any help would be appreciated, as I am not experienced with tuning.
Thank you.
alex6219 is offline   Reply With Quote
Old 06-02-2015, 05:11 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
You have just flashed anther stock map to the car. It is well documented about accelerator sensitivity after a flash as the ECU learns the TPS and pedal sensor. You can remove this by:
Turn car to accessory
Depress the pedal fully 5-10 times
Start the car. If you haven't already, let the car idle for ~1 min. If the car is already warm (preferred) then just wait until you see the exhaust AVCS start to change values in the log view.
If you do the above after any flash then you wn't have this issue.
.: Stealth 86 :.
Kodename 47 DJ:
theanswer3 (06-03-2015)
Old 06-02-2015, 06:03 AM   #3
steve99
Drives: FT86
If it wont rev past 4000rpm then it likely in limp home mode.
is the CEL light on ? check for cel codes
note any cel code numbers then clear any codes
what year is your car ?
D Series
ZA1JA700D, 900D,A00D,A01D,B00D all compatible with ZA1JB01D
ZA1JD00D for late 2014/2015 cars only
I got same issue ie limp home mode only rev to 4000 when i tried flashing a late2014/15 rom to my older vehicle their appears to have been some changes to dash cluster/alternator in the late model cars which make the new roms incompatible with older cars.
also as kodename47 said let the car idle for a minute after a flash to let ecu sort out its cam calibration.
Old 06-03-2015, 04:49 AM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Sounds more like they've given you an incompatible rom as Steve has said.
Using handbrake with automatic gt86 and other issues with the automatic version Tommygt86 Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 05:42 AM
EcuTek SD problems in the cold zkv476 Software Tuning 16 02-12-2015 05:26 PM
Ecutek on an automatic Okieman Software Tuning 7 09-14-2014 05:09 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
ECUTek Launch Control in Automatic 01s0uljah Software Tuning 2 08-12-2013 09:45 PM
