Old 05-28-2015, 08:15 PM   #1
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
Spacer Thread
What size wheel spacers do you have on your car? Front/Back
How does it affect the feel of your drive?
"Listen, smile, agree and then do whatever the fuck you were going to do anyway." -Robert Downey Jr.
Eski is offline   Reply With Quote
Old 05-28-2015, 08:17 PM   #2
gramicci101
Off Topic
I have @Corner3garage 20mm front/25mm rear spacers. They have a great deal on them, or did when I bought them. Now that I've had them for a while I think I probably could have done 25f/30r with no issues, but nobody was offering that. Or not at a decent price.
They don't affect the feel of my drive at all. I took the rear track width from 60.6" to 62.6". Not a significant change.
edit: pics: http://www.ft86club.com/forums/showp...postcount=8344
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Corner3garage (05-29-2015), Eski (05-28-2015)
Old 05-28-2015, 09:35 PM   #3
kberkel
kberkel's Avatar
Same. Never noticed a change in driving. Completely changes the look IMO, I won't run without them.
kberkel is offline   Reply With Quote
Old 05-28-2015, 10:22 PM   #4
sirsol66
Drives: 2013 FRS- Hot Lava
Anybody run the 25/30 setup on stock wheels? I plan to order a set for the rocket bunny setup as temporary but I am thinking of ordering them earlier and running them on my stock wheels. Curious to see photos and feedback for clearance; all I've ever read are people running the 20/25 setup.
sirsol66 is offline   Reply With Quote
Old 05-29-2015, 01:35 PM   #5
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I ran 25/30 on my car for a while with the stock wheels and it was fine. My car is lowered on H&R Sport springs, which lowers it about .75" front and back. I noticed it made it understeer a little more than it did with 25mm all around, but it wasn't huge. There's a few pictures on our page here.
PERRIN_Chris is offline   Reply With Quote
Old 05-29-2015, 08:48 PM   #6
Ragua007
Ragua007's Avatar
Drives: 86
I used the H&R 20mm/25mm on my stock wheels for a few months. I didn't see much of a difference in how it drives, just looks so much better. I also have the H&R Sport Springs, so it sits about 3/4" lower.
Ragua007 is offline   Reply With Quote
Old 05-30-2015, 12:25 PM   #7
sirsol66
Thanks Chris! No rubbing at all?
Old 05-30-2015, 02:15 PM   #8
Eski
Eski's Avatar
Thanks for the link, I wanted to go with 25/30 to give it more of an aggressive look. I really don't like how sunken in the wheels are at stock. I plan on ordering some of these soon!
Old 06-01-2015, 12:39 PM   #9
PERRIN_Chris
That's right, no rubbing at all. The fenders on these cars are surprisingly huge!
Old 06-01-2015, 09:24 PM   #10
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
What'd be the best square setup if i'm looking for a nice flush look on stock suspension?
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 06-01-2015, 09:43 PM   #11
gramicci101
Off Topic
Are you on stock wheels as well?
The 20f/25r is probably the most cost effective, and it looks very nice as well. Refer to my previous post for pictures.
http://www.corner3garage.com/V3-Spac...WRX_p_482.html
Note that it says with any purchase, which is great if you're already buying something else. If you're not, then throw a pair of camber bolts on there as your purchase and call it a day.
http://www.corner3garage.com/Whiteli...RZ-_p_479.html
I think 25f/30r would be closer to flush, but now you're looking at $160 just for the rear pair vs. $140 for all four.
http://www.ft86speedfactory.com/eiba...acer-1124.html
Old 06-01-2015, 09:54 PM   #12
x1UP
One & Done (AOZORA)
x1UP's Avatar
I'm on the stock STI 17" wheels that come with the Series.Blue.
However, i'll be getting new wheels in that are 18x8.5 with a +42 offset.
Any help is appreciated!
Old 06-01-2015, 10:01 PM   #13
gramicci101
Off Topic
In that case, don't even worry about spacers for your OEM wheels. 18x8.5 +42 is pretty damn flush up front to begin with. To achieve the same flushness in the rear you would need a 10mm spacer. You can't do a bolt-on 10mm spacer because there won't be enough thread contact to hold everything together, which means you'll need longer wheel studs. Mach V's spacers come with ARP studs, which are the proven solution for wheel studs.
http://www.fastwrx.com/collections/w...rp-wheel-studs
Dave-ROR did a DIY thread for wheel stud replacement, if you want to go that route.
Old 06-15-2015, 06:40 PM   #14
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
Hey x1UP, did you end up getting the spacers? I am about to pull the trigger on some 25/30 for my series blue on stock suspension. Only concern is that they are silver and think they will be too noticeable/look bad when looking closely at the wheels.
Aozora.BRZ is offline   Reply With Quote
UEL 02 spacer Project N64 Engine, Exhaust, Transmission 0 03-26-2015 11:24 PM
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 01:53 PM
3mm wheel spacer vroom4 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-16-2014 01:36 AM
Spacer HELP?! Husker BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-22-2014 11:25 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 12:59 PM
