Old 05-15-2014, 07:00 PM   #1
vroom4
3mm wheel spacer
Has anyone found a 3mm spacer that they prefer? A lot of wheels come in 35 or 45 offset and I think a 42 is probably perfect.
Is there even any interest in a hubcentric 3 or does everyone just go to a 5?
vroom4 is offline   Reply With Quote
Old 05-15-2014, 07:24 PM   #2
gramicci101
Off Topic
Two seconds.
[ame="http://www.amazon.com/5x100-Hubcentric-Spacers-Subaru-Impreza/dp/B00DNND8G4/ref=sr_1_1?ie=UTF8&qid=1400196249&sr=8-1&keywords=5x100+56.1+3mm+spacer"]Amazon.com: (2) 3mm 5x100 Hubcentric Wheel Spacers for Scion FRS FR-S Subaru WRX Impreza (56.1 bore): Automotive[/ame]
Old 05-15-2014, 07:28 PM   #3
vroom4
I was curious what people were actually using. That style, the cheaper style (linked below), or the universal ones with the hubcenter lip on them. I guess I phrased my question wrong.
[ame="http://www.amazon.com/Gorilla-SP601S-Thick-5-Hole-Spacer/dp/B001O06I3S/ref=pd_sim_sbs_auto_4?ie=UTF8&refRID=186YD64BMMHEA 5798TXJ"]Amazon.com: Gorilla SP601S 3mm Thick 4/5-Hole Wheel Spacer: Automotive[/ame]
Old 05-16-2014, 12:36 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
As a minimum you should be using flat hubcentric ones (56.1mm). Being 3mm thick you're still left with approx 4mm of hub lip protruding past the spacer. IIRC the factory hub has a 7mm lip.
Personally I'd go with hub + wheel centric spacers, which has a 10mm lip that mates nicely into your wheel bore. Custom made ones aren't that expensive anyway. Check out these guys: http://www.motorsport-tech.com/wheel_spacers.html
Fizz is offline   Reply With Quote
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
Wheel spacer question, please help AceNiNe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-23-2013 03:52 AM
Wheel Spacer tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-06-2013 01:44 AM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
