Old 05-29-2015, 11:53 PM   #15
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by philooo View Post
may be I can try to add a switch on the dash to trigger the radiator fan
I'll have to look into it, I bet something has that done somewhere already
Fans are controlled by the ecu and are variable speed, so unless you really know what you're doing, i wouldn't just go chopping into the wiring.
Old 05-30-2015, 02:13 PM   #16
philooo
Drives: 13' Scion FRS Track car
may be a cool hack for the open flash tablet guys
philooo is offline   Reply With Quote
Old 06-01-2015, 02:53 AM   #17
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Jesse@JDLAutodesign View Post
You could also fab some heat shields to deflect radiant heat for the coilpacks and other vital sensors in that area.
It's in the works at some point...not enough time in the day or days in the week!
That is a product i would be interested in.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
KalbiCool88 (12-22-2016)
Old 06-01-2015, 03:18 AM   #18
troek
troek's Avatar
Drives: 2012 Toyota 86
That heat shield doesn't prevent the coil pack problem from happening. In fact, it's worse because the OEM header also has a cat, which retains heat pretty hardcore...
My stock header would glow bright enough to light up the ground slightly under my front right tire on night time Touge runs....
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
CSG Mike (06-01-2015)
ZN Performance - Stay Away boucher User/Vendor/Sponsor Reviews, Feedback, Comments 21 09-14-2014 08:40 PM
Keep Calm and Stay Cool With FR Sport's Summer Maintenance Special FRSport.com Miscellaneous 0 06-20-2014 12:24 PM
Stay Cool This Summer With Perrin and Koyo @ RallySportDirect.com RallySport Direct Engine, Exhaust, Bolt-Ons 12 09-11-2013 03:55 PM
*NEW* Scion FR-S Front and Rear Carrier/Stay Bushings | TWM Performance TWMPerformance Transmission and Driveline 0 02-25-2013 05:31 PM
Warm vs cool Weather performance EsoBOFH Scion FR-S / Toyota 86 GT86 General Forum 22 07-10-2012 11:45 AM
