Old 05-28-2015, 09:57 AM   #15
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Originally Posted by 2016 Camaro SS View Post
Interesting, I'll give this a try on this gas tank. I've always heard people talk about "neutral cruising" when going down a hill up to a stoplight like it's the greatest thing, but that does make sense.
All OBD-II equipped vehicles are supposed to do this. I clutch in and go to neutral right before I'm about to finish stopping (usually sub-15mph, and I'm normally still in 3rd). If you are used to cruising in neutral for a considerable distance, you may notice a slight difference in mpg, nothing huge. Neutral cruising down a hill though... that just is dangerous. Usually leads to people riding their brakes and overheating them.
Edit: If you ever see anyone's datalogs on the forum, linked to datazap website, notice that when they let off the throttle completely, the AFR's jump sky-high to max (like 20), because there is no fuel being injected anymore.
malave7567 is offline   Reply With Quote
The Following 2 Users Say Thank You to malave7567 For This Useful Post:
2016 Camaro SS (05-28-2015), ScoobsMcGee (05-28-2015)
Old 05-28-2015, 10:00 AM   #16
Vroomin86
Drives: 2015 Fire
Very surprised no one has mentioned the known and common flywheel noise on these cars. There's nothing wrong with your brz, my FRS and every other twin out there will do this when coming to a slow stop out of gear.
http://www.ft86club.com/forums/showthread.php?t=12429
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
The Following User Says Thank You to Vroomin86 For This Useful Post:
Itzed (06-03-2015)
Old 05-28-2015, 10:09 AM   #17
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I get that occasionally. It's done it ever since I got the car back in November of 2012. Not very consistent though, just occasionally.
2016 Camaro SS is offline   Reply With Quote
Old 05-28-2015, 10:28 AM   #18
Vroomin86
Drives: 2015 Fire
You might not hear it all the time because it's a specific mechanical situation but it's done it and it will continue to. Just as OPs and mine and everyone else in this thread. Follow the directions on the thread I posted to replicate the noise and I bet you'll get the noise every time.
2015 FireStorm FRS
Old 05-28-2015, 10:34 AM   #19
steve99
Drives: FT86
Looks like you guys have have ability to adjust tune (OFT)
You idle will already be 750
but go to the PI/DI tables and make it run 100% DI at load 0.2 for manual and 0.2/0.3 for auto
worked for me no rattly sound in neutral, no A/C idle dips and smoother takeoff (manual trans)
set all 3 PI/DI ratio tables cold/warm/hot to have full DI up to 0.3 g/rev load (see figure)
If you have manual trans probably just up to 0.2g/rev will do.
ztan put me onto this
Old 05-28-2015, 10:55 AM   #20
Vroomin86
Drives: 2015 Fire
I am actually on the stage 1 93 octane flash. To make these adjustments you mention do they have to be done in RomRaider?
Could you perhaps post a screen shot of what the table is supposed to look like once it's done.
2015 FireStorm FRS
Old 05-28-2015, 10:55 AM   #21
On the subject of neutral cruising, coasting down hills in neutral (or even with clutch in) or anytime you do not have a MT car in gear while moving I will summarize the effects in words of my Army driving instructor instructor from many years ago:
"What the fuck are you doing you stupid mother fucker you fucking well just turned a fucking ten fucking ton truck into a fucking uncontrolled fucking soap fucking box racer. You dumb fuck" (Ya, the guy was a blast to be around in restaurants and other public places)
2016 Camaro SS (05-28-2015), Fastbrew (05-28-2015), gramicci101 (05-28-2015), ScoobsMcGee (05-28-2015), Vroomin86 (05-28-2015)
Old 05-28-2015, 10:56 AM   #22
2016 Camaro SS
Drives: Fast
The things you learn after years of doing it wrong.... lol. It's all clicking now.
Old 05-28-2015, 11:01 AM   #23
steve99
Drives: FT86
Yes you will need romraider
see links below
I'm pretty sure the di/pi tables are same in the stage1/2 petrol tunes.
As the above table shows just zero out the 0.2 column in all three di/pi tables
the above table shows 0.2 and 0.3 load columns zeroed , pretty sure that was the OFT pi/di table.
post up you table from your tune and I will have a look
Old 05-28-2015, 11:10 AM   #24
The problem with driving MT is that depending on what you are doing and your particular style there are probably 100 way of doing it "right". I bet we would have a very tough time getting 6 people to agree on a the "proper" way to clutch and shift on our cars alone much less agree to a general rules that appy across the board.
Old 05-28-2015, 11:36 AM   #25
2016 Camaro SS
Drives: Fast
Next thread topic: "When parked, should I put the car in neutral or in gear? E-brake or no E-brake?"
Old 05-28-2015, 11:46 AM   #26
Again lucky if can have 6 guys agree but there are less options so just maybe...
I am of the in gear, brake on crowd but I grew up in the era where e/p brakes were untrustworthy things that were foot operated and general seized up solid within the first year anyway.
Old 05-28-2015, 11:51 AM   #27
2016 Camaro SS
Drives: Fast
Yeah, I pretty much just stick with this:
If hill, gear: yes e-brake: yes
If no hill, gear: no e-brake: yes
But then there's also
If no hill, gear: yes e-brake: no
Last two options I don't think matters either way on transmission stress. We're way off topic now.
Old 05-28-2015, 12:01 PM   #28
Originally Posted by Synkronicity View Post
Yep, took it to a dealer, I'm completely overthinking and overly anxious. They said it was nothing and I should stop worrying about all the small sounds LOL.
I will be practicing my downshifting, I'm taught to always clutch whenever I touch the shifting knob so that's already wired into my brain.
Original issue resolved. Still sort of on topic anyway.
Strange sound when shifting into first or second Jfheisenberg Engine, Exhaust, Transmission 35 06-23-2015 03:13 PM
strange fluttering sound at high rpm for SC JoonPrime Forced Induction 4 10-10-2014 03:17 PM
Yet another strange interior sound. DCStorm Issues | Warranty | Recalls / TSB 5 10-25-2013 12:05 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 07:16 PM
Strange sound coming from gas tank? nocurfew Engine, Exhaust, Transmission 6 07-31-2012 03:37 PM
