Old 05-27-2015, 09:37 AM   #1
Synkronicity
Drives: Ford Escape to BRZ
Strange Rapid Fire Sound?
Hi guys, recently bought the car and discussed the issue here on this thread
http://www.ft86club.com/forums/showthread.php?t=88854
But would like to post it again here for different people to see as I believe it's an "issue". Car is a 2015 series.blue 2900 miles
First problem is this sound in this video, around the 7 second mark (you have to listen closely and turn your volume up), it will sound like a quick rapid fire sound, that's the only way I can describe it. It happens when I'm driving and throw it into neutral to coast to a stop, when my brother drives the car, he downshifts and the sound never happens.
[ame="https://www.youtube.com/watch?v=HPDcfyipCbA"]BRZ Strange Sound - YouTube[/ame]
[ame]http://youtu.be/i0Cwr0DaHHc[/ame] - This is edited to make the sound louder.
Second is an issue while driving around, yesterday, I heard a random ass screech, like my tire or something, freaked me out, but there was no loss of control of the car, I can't replicate the issue and it was out of the blue.
Synkronicity is offline   Reply With Quote
Old 05-27-2015, 10:01 AM   #2
nivek111070
Drives: 2014 GB Scoobie BRZ
sounds like the valves chattering, which should not be happening
nivek111070 is offline   Reply With Quote
Old 05-27-2015, 10:39 AM   #3
Synkronicity
I might just bring it into a dealer and see. How bad are chattering valves
Old 05-27-2015, 11:38 AM   #4
humfrz
Well, Synkronicity, first off, I see no reason to be putting your car in neutral when slowing down.
I suggest you drive it like your brother does.
Now, when you come to a stop, it would good to slip it into nuetral and let out the clutch (saves wear on the throw-out bearing).
Back in the day, we would NEVER slip a car into neutral when slowing ..... because, one never know when the mechanical brakes may be frozen ..... thus, we could lessen the impact of the crash ......
humfrz
Tcoat (05-28-2015)
Old 05-27-2015, 11:49 AM   #5
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Does the shifter shake when that happens? Probably the AC dragging on the engine as the revs fall making it almost stall out.
post_break is offline   Reply With Quote
Old 05-27-2015, 12:14 PM   #6
stevesnj
stevesnj's Avatar
Could be something with the TC activating. Not under power but still moving maybe the TC thinks its lost traction? Dunno, just guessing wildly
My 2016 Build thread
Old 05-27-2015, 12:15 PM   #7
Synkronicity
humfrz
I try not to coast in neutral like that for long. I'm so afraid of damaging my car since I downshift so poorly.
Shifter does not shake no (as far as I know at least)
Old 05-27-2015, 02:28 PM   #8
humfrz
I suggest you work on your downshifting technique, by practicing rev matching (bliping the throttle).
Don't bother with double clutching ...... that's just for very old trucks .....
humfrz
nivek111070 (05-27-2015), Tcoat (05-28-2015)
Old 05-27-2015, 02:50 PM   #9
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
The first sound seems too slow to be TCS/ABS, but that could be just how it comes across in the video. Are you using the clutch to pull out of gear? If not, you should be. If your brother can't identify a difference in how you're shifting, yet you can reliably produce the sound, take it to a dealer and ask to ride with a tech. If it is an issue with technique they will most likely say so. If not, they will know exactly what to look for when diagnosing it.
As for the tire screech: no where near enough information to even guess. Were you turning? Driving straight? Around traffic? Working all night? On a back road? Driving over a road imperfection? Conquering Alexandria? Sleeping all day?
humfrz (05-27-2015)
Old 05-27-2015, 06:20 PM   #10
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
Turn off your AC and it won't do it. This is a common problem with a lot of the vehicles. There was an ECU flash to fix it, I think. Its just the RPMs dipping because of the A/C being on when you put it in neutral. Happens often pulling up to red lights.
Don't overthink a problem
Freetime is offline   Reply With Quote
Old 05-28-2015, 07:22 AM   #11
Synkronicity
Yep, took it to a dealer, I'm completely overthinking and overly anxious. They said it was nothing and I should stop worrying about all the small sounds LOL.
I will be practicing my downshifting, I'm taught to always clutch whenever I touch the shifting knob so that's already wired into my brain.
The Following User Says Thank You to Synkronicity For This Useful Post:
Tcoat (05-28-2015)
Old 05-28-2015, 08:46 AM   #12
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
humfrz
I do a lot of neutral cruising up to stoplights. Easy way to up the MPG's. I have Winmax W2's, fluid, and SS lines for the jackasses that brake check me like the Veloster I ran into yesterday purposely making me angry to get a reaction.
2016 Camaro SS is offline   Reply With Quote
Old 05-28-2015, 08:50 AM   #13
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
You actually save more gas leaving it in gear when slowing down. In neutral, the injectors are firing to keep engine idle up. Deceleration Fuel Cutoff will happen if you are in gear, meaning that the engine is turning based on being connected to the drivetrain that is still moving, but no fuel is being used.
malave7567 is offline   Reply With Quote
The Following 3 Users Say Thank You to malave7567 For This Useful Post:
2016 Camaro SS (05-28-2015), ScoobsMcGee (05-28-2015), Tcoat (05-28-2015)
Old 05-28-2015, 08:53 AM   #14
2016 Camaro SS
Drives: Fast
Interesting, I'll give this a try on this gas tank. I've always heard people talk about "neutral cruising" when going down a hill up to a stoplight like it's the greatest thing, but that does make sense.
Strange sound when shifting into first or second Jfheisenberg Engine, Exhaust, Transmission 35 06-23-2015 02:13 PM
strange fluttering sound at high rpm for SC JoonPrime Forced Induction 4 10-10-2014 02:17 PM
Yet another strange interior sound. DCStorm Issues | Warranty | Recalls / TSB 5 10-25-2013 11:05 AM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 06:16 PM
Strange sound coming from gas tank? nocurfew Engine, Exhaust, Transmission 6 07-31-2012 02:37 PM
