Old 07-22-2012, 11:38 AM   #1
CB762
CB762's Avatar
Drives: Scion FR-S
Flywheel Rattle?
Under very light braking, or just coasting down the hill in neutral, there is a quite loud rattle coming somewhere from the transmission area and it continues for 2-3 seconds. If clutch pedal goes down then rattling stops instantly. It sounds to me like the flywheel rattle I've had on Mini few years back (it did rattle at idle tho).
Car is doing it from the very beginning and I have around 500 miles on odo now.
Anyone experience it?
CB762 is offline   Reply With Quote
Old 07-22-2012, 11:41 AM   #2
#87
I usually post drunk
#87's Avatar
I have a different rattle, if I push in the clutch quickly when cold it makes an awful chatter. Weird though, it only happens when cold and goes away quick.
I only notice because my parking space is in the middle of the block so I start the car, drive to the corner in first gear getting up to 15 mph max, then clutch in and brake for stop sign. Chatters everyday in this spot but not in stop go driving, weird.
#87 is offline   Reply With Quote
Old 07-22-2012, 12:47 PM   #3
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
i was just going to post something about a rattle i hear when im breaking in neutral i took a video of it its around 27 seconds in when the speed gets right below 30 MPH
http://s421.photobucket.com/albums/p...t=IMG_1331.mp4
Lee358 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lee358 For This Useful Post:
kehvynh (05-24-2016), theseloaded86hips (01-23-2014)
Old 07-22-2012, 05:01 PM   #4
Lee358
Lee358's Avatar
Is that the noise your hearing?
The Following User Says Thank You to Lee358 For This Useful Post:
Old 07-22-2012, 05:13 PM   #5
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Lee I hear that noise all the time!
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-22-2012, 07:49 PM   #6
Lee358
Lee358's Avatar
Laika any idea what it is?
Old 07-22-2012, 08:26 PM   #7
vobla6.0
Resident Douchebag
Drives: balla'
Would this rattle be speed specific (at a certain speed), or does it go on-off at any speed when the car is in neutral?
vobla6.0 is offline   Reply With Quote
Old 07-22-2012, 08:48 PM   #8
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
That's a normal noise of direct injection.
Sigh-on-Rice is offline   Reply With Quote
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Lee358 (07-22-2012)
Old 07-22-2012, 10:47 PM   #9
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Very interesting! Would you be able to elaborate more? I'm very new to DI and curious to know.
Lee: I had no idea what it could be, I totally thought it was a flywheel/driveshaft noise
The Following User Says Thank You to Laika For This Useful Post:
karma003 (08-05-2012)
Old 07-22-2012, 11:52 PM   #10
Sigh-on-Rice
When I picked the car up from the dealer, they gave me a piece of paper explaining certain things and DI noise was one of them. I threw away the paper, so I don't know how it explained. But the noise in the vid is the noise that paper talked about saying its normal noise.
Old 07-23-2012, 09:16 PM   #11
CB762
CB762's Avatar
Drives: Scion FR-S
Yes, sounds pretty much like what I got.
If that is due to DI then why: it happens only while in neutral; it stops instantly with clutch in?
Old 07-23-2012, 10:49 PM   #12
3essess
Drives: frs
First off, love the way the car drives except for this one "grinding" or "rattling - gear grinding type" sound that happens exactly as you described and in your vid.
It sort of sound like the sound made when you're trying to put your car into gear without using the clutch. After driving for over 1000 miles, I can usually make this sound happen under the following conditions:
1) When slowing down for a stop or turn, put your car into neutral - so your coasting down.
2) When slowing down in neutral, the revs will usually settle in around 1000 rpm or so until you get down to below 25mph or slower. Then the revs will finally settle in to 700 or so...then the revs will bounce down lower to 550 to or 650 rpm and that is when I hear the rattling sound.
3) Like you, I also can make the rattling stop if I push in the clutch, or, if I bring the revs up via the throttle - the sound goes away. Or, if I do nothing, it will slowly stop in about 2 or 3 or 4 seconds - once the engine revs recovers.
4) No matter how hard I try to duplicate the sound with the car NOT moving, it will not happen. The car needs to be moving in neutral to make the sound come out.
5) To me, it sounds like something in the transmission is rattling, whether gears or rods or whatever. Could it be the motor knocking at that low rpm - I hope not.
We gotta get this resolved...
Thanks.
3essess is offline   Reply With Quote
The Following 2 Users Say Thank You to 3essess For This Useful Post:
pLaydEad86 (07-10-2015), theseloaded86hips (01-23-2014)
Old 07-23-2012, 11:35 PM   #13
CB762
CB762's Avatar
Drives: Scion FR-S
Well, I think I'll take it back to the dealership for the answer.
Old 07-24-2012, 12:11 AM   #14
3essess
Drives: frs
I'm also thinking it could be some sort of harmonic vibration due to the low engine revs and the clutch being out and the transmission still spinning while moving at certain speed. I think ultimately, if the revs never bounce that low, it would not make the sound. IOW, fix the low idle issue, you don't get this rattle?
flywheel, rattle, transmission
Interior rattle frsinpa Issues | Warranty | Recalls / TSB 132 03-23-2015 04:09 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
