#15 |
Junior
Drives: a car
you can scientifically prove that the brunt of the torque force vector is shifted from the driveshaft to the axles? please show me.
#16 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Easily. First the ratio of mechanical advantage the axle has turning the wheel is set by the size of the tire diameter. Second, the ratio of the Final Drive, (FD), sets the mechanical advantage the driveline has over the axles. Changing the FD from 4:10 to 5:10 gives the driveline more of a mechanical advantage over the axles, since the driveline turns more revolutions for the same number of axle revolutions, and since the tire size hasn't changed, the axle still has the same mechanical advantage.
#17 |
Drives: Raven FR-S 6M
Nope
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 05-26-2015 at 09:23 AM. |
| The Following User Says Thank You to Apoc For This Useful Post: | Ultramaroon (05-26-2015) |
#18 | |
Drives: Red Toaster(Dodge Nitro)
Sent from my toaster
I mostly lurk, still don't own an 86...
#19 | ||
Off Topic
A close ratio transmission is called a close ratio transmission because the ratios are, hint hint, closer together. Has nothing to do with anything outside the transmission. Not the ring and pinion, not the tire size, not the engine speed, not the ground speed, not what color socks you wear that day. The ratios in the transmission. Only. You physically change 6th gear from 0.767 to 0.850 and leave 5th at 1.000? Guess what? They're closer together. Quote:
The facts you back yourself up with are wrong and only make sense to you. You've changed a whole lot of stuff that makes absolutely no sense at all to anyone. Anywhere. If you'd have only thought first before actually making changes you could have saved yourself a whole lot of money. |
| The Following 4 Users Say Thank You to gramicci101 For This Useful Post: |
#20 |
Well whatever you decide just remember that increasing the horsepower which essentially raises torque it does so with a drivetrain that was designed to be most effective with the stock HP and torque values. These cars were also developed to be easily modded (Scion PR) but modded within reason. It's easy to throw FI or nitrous on there but fail to understand that the parts connected to the engine just are not within over modded specs. Then there are threads asking why I keep breaking axles or grinding up rear gears with a 600 HP engine. These are the consequences of not researching enough. I would find out what DS, U-Joints, Gear Set, Axles, brakes, tires etc. to take the extra torque. Looking forward to seeing your decision!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | Tcoat (05-28-2015) |
#21 | |
Close ratio gearboxes are just that, the ratios between gears are very close to each other. You can have a close ratio gearbox with a very tall final drive, just like you can have a wide ratio gearbox with a very short final drive. You want a close ratio for narrow powerbands because it lets you keep the RPM in the meat of the powerband. You want wide ratio for huge flat wide powerbands because you'll be shifting less but still keeping the engine in the meat of the powerband.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#22 |
Read before you reply, you ASSumer. I said it doesn't change the gears themselves. If you would take your blinders off, you would see what I mean. I'm talking about the change in ratios between the engine, the source of power, and the destination, the tires on the road. I clearly spelled out the change in redline peaks per gear when changing FD's. You just ignored that and spewed idiotic insults because you thought I was just talking about the gears in the transmission itself. If I was just talking about gear ratios in the transmission itself, why show engine RPM's? I've been talking about the overall ratios between the engine and the tires.
The OP who started this thread clearly said the trans could come with different ratios, so, unless he does some calculations he isn't going to know where his redline peaks are without mounting it in the car. With a 500 HP engine he clearly isn't concerned with MPG, but, he is concerned with drivetrain reliability. The existing parts are balanced for a 200 HP engine, a 6 speed close ratio manual transmission, a 4:10 FD, and a 27.25" diameter tire. Change any one of those and the balance changes. More pressure will be put on some components, and less pressure on others. That is what the OP wants to learn about. This is the kind of secret information drag racers know about, but don't talk about with the competition. Here are some links that can help the OP with the decision he's going to have to be making. http://www.ek9.org/index.php?threads...-friend.10883/ http://www.csgnetwork.com/multirpmcalc.html and of course, http://weirperformance.com/finaldrivegears.html |
#23 |
I think this all went downhill when someone asked about gear spacing...
#24 | |||
At least we the community consistently push back against your misguided poke-and-hope approach. Hopefully you will realize the danger of your hubris before someone gets hurt.
#25 |
Who said I was talking about gear ratios? I'm talking about the ratios between the engine and the tires. I'm also not talking about torque, but about mechanical advantage between components. Check out the links I posted before you assume I'm providing misinformation. Your negative assumptions only hurt yourself. What help are you with your criticisms? I provided helpful links. While you can only criticize in a vain attempt to make yourself look better. The OP wants help, not critical, self-serving, negative crap.
#26 | |
Junior
Drives: a car
![]() To be fair that post said yes, then you unknowingly explained why the gears (actually) dont change, slightly confusing.
#27 |
How about this... You're all speshal snow flakes. But this arguing is kind of annoying.
#28 | ||
Junior
Drives: a car
Usually people like it when the help is mathmatically (you got that stuff down) and physically correct (you need to do some more learnin and a readin). Why is it if you correct someone a few times on the internet they get all pouty and call you negative and get their jimmies in a bunch? Sheesh. A man must be big enough to admit his mistakes, smart enough to profit from them, and strong enough to correct them.
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | HUNTERANGEL121 (05-26-2015), wparsons (05-26-2015) |
| 4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 12:49 PM |
| 4.875 final drive review | drift86 | Engine, Exhaust, Transmission | 98 | 02-12-2018 06:13 PM |
| Final Drive 4.67 | Bongertz | Engine, Exhaust, Transmission | 33 | 09-02-2015 03:11 PM |
| 3.3 Final drive? | Manji | Engine, Exhaust, Transmission | 18 | 01-01-2015 02:51 PM |
| Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
