View Poll Results: Oil cooler for base FI kits
no oil cooler, I don't need one 16 14.68%
no oil cooler, I plan to get one 28 25.69%
I got an oil cooler kit 51 46.79%
I use a "home brewed" kit 14 12.84%
Voters: 109. You may not vote on this poll
Old 05-24-2015, 02:43 AM   #15
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
I tracked my car twice and noticed my oil temp go up to 256. and thats without vortech SC. So im putting oil cooler on mine along with it.
I THINK we start burning oil when oil temp go up higher than 230.
Weapon86 is offline   Reply With Quote
Old 05-24-2015, 04:31 PM   #16
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm installing my Perrin Oil Cooler soon simply for the reassurance. From what I've read, it's good enough for government work.
MS, CSCS, TSAC-F, CPT
Old 05-25-2015, 07:09 AM   #17
onzippy
Drives: 2014 FRS
No oil cooler installed. AVO stage 1'ish turbo @ 10psi.
After dyno-tuning the oil temp was at 226F and on the street the normal operating temp is around 215F.
The highest temp I've seen in my logs is 230F. I haven't tracked the car.
onzippy is offline   Reply With Quote
Old 05-25-2015, 07:47 AM   #18
aagun
Drives: 86
dump drive frs / brz / ft86 without oil cooler
aagun is offline   Reply With Quote
Old 05-25-2015, 09:02 AM   #19
Astroboy
Astroboy's Avatar
Drives: None
Which oil type are you using
Shut, sometimes I reach 104c(219f) on a daily basis. I'm using 5w30 motul x clean, which I heard is on the thicker side. I'm also pushing 255whp and 200lbs on 5 psi
Astroboy is offline   Reply With Quote
Old 05-25-2015, 09:29 AM   #20
onzippy
Drives: 2014 FRS
0w-20 from the dealer. Two more free dealer oil/filter changes and I might go to a 30.
Old 05-25-2015, 09:33 AM   #21
Astroboy
Astroboy's Avatar
Drives: None
I was using that before ever finding out about some forum members mentioning which oil is right for your car, so I did not measure the temps at the time; I wish I did. Do you mind me asking where you are from and the weather you are having?
Old 05-25-2015, 09:47 AM   #22
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
8 qt oil pan. E85. 21 row oil cooler, amsoil dominator 10w30. Hit 236* on the track in 80+* weather. Coolant never topped 200*
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Astroboy (05-25-2015), Mooseknuckle44 (06-12-2015)
Old 05-26-2015, 01:18 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I was surprised to see I hit over 260F this weekend at NOLA with my S2000.
Astroboy (05-26-2015)
Old 05-26-2015, 09:27 PM   #24
Reaper
Reaper's Avatar
Drives: violent
Many rpms.
Old 05-26-2015, 11:42 PM   #25
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
OVER 9000.
crazyfrenchbiker is offline   Reply With Quote
Old 08-29-2015, 09:23 PM   #26
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I still have many free oil changes left under warranty, but I am installing my FI kit soon. I'm not sure if I should just continue using the dealer 0W20 or if I will run into trouble not switching to 5W30
Chad86 is offline   Reply With Quote
Old 11-11-2015, 01:46 PM   #27
Chad86
Chad86's Avatar
Drives: Toyota GT86
Lightbulb
I have decided to run an oil cooler until the free oil changes run out. After this I will switch things up.
Old 11-15-2015, 03:54 PM   #28
Jonde875
Drives: GT86
Hi!
I have question about this oil cooler thing. What you think is best solution for me because here is not very warm in summer? I think I would need something to cool down the oil even little bit for the hot days.
Im not gonna track this car but sometimes driving can be pretty sporty!
I think small cooler would be the right thing but what kind of....
I have AVO kit installed with AVO 3" catted full exhaust and 8psi actuator
Jonde875 is offline   Reply With Quote
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 05:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 06:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-22-2013 12:36 AM
Poll: Racing/HPDE with/without Oil Cooler sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-01-2013 09:42 AM
