View Poll Results: Oil cooler for base FI kits
no oil cooler, I don't need one 16 14.68%
no oil cooler, I plan to get one 28 25.69%
I got an oil cooler kit 51 46.79%
I use a "home brewed" kit 14 12.84%
Voters: 109. You may not vote on this poll
Old 07-22-2013, 10:36 PM   #1
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Post Poll: FI with/without an oil cooler
A question for those running FI, base kits
1. no oil cooler because I don't need it
2. no oil cooler but I'll have one installed
3. I have one
a. I bought a kit, what brand
b. Home brew, what brands were used
4. How would you rate/comment on your oil cooler?
a. build quality
b. ease of install and modifications needed
c. value for money
Last edited by andrewFT86; 07-22-2013 at 10:39 PM. Reason: limited poll to stage one or base kits
andrewFT86 is offline   Reply With Quote
Old 07-24-2013, 11:11 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
3. I have one
a. I bought a kit, Full Blown
a. build quality - Excellent. Possible extra hose depending on routing under driver side headlight based on BRZ or FR-S model
b. ease of install and modifications needed - Came with instructions and install is fairly simple as long as you know how to remove the bumper. Possible extra hose depending on routing under driver side headlight based on BRZ or FR-S model
c. value for money - Slightly lower price than some of the other kits out there.
The Following User Says Thank You to King Tut For This Useful Post:
andrewFT86 (05-23-2015)
Old 07-24-2013, 11:19 AM   #3
Synack
Boosted
Synack's Avatar
Drives: Sideways
Still deciding. Gonna run my oil temps through Torque after running the car kinda hard and see what they're at. If it approaches 240+ on a moderate run then I'll definitely get one.
The Following User Says Thank You to Synack For This Useful Post:
Old 03-15-2015, 10:06 AM   #4
Astroboy
Astroboy's Avatar
Drives: None
I am running an avo kit without an oil cooler at the moment... Still debating on wether I should get one or not.
Astroboy is offline   Reply With Quote
The Following User Says Thank You to Astroboy For This Useful Post:
Old 03-15-2015, 07:02 PM   #5
2013GTRNate
2013GTRNate's Avatar
I got the Kite Oil cooler kit. It runs lower temps with the Turbo kit than the BRZ did stock. No brainer IMHO.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
The Following 2 Users Say Thank You to 2013GTRNate For This Useful Post:
andrewFT86 (05-23-2015), Astroboy (03-15-2015)
Old 03-15-2015, 07:44 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
You should really include something about the style of driving and the location of the people voting.
The Following User Says Thank You to Calum For This Useful Post:
Old 03-15-2015, 11:27 PM   #7
Illuminaughty
Drives: 2013 Subaru BRZ Limited 6MT
I have a 40 minute commute every day to work and back. Max temps I've seen on this drive were 226F. Granted it was a pretty relaxed drive, that seems pretty safe for now. No oil cooler and running the SBD kit (with fully wrapped headers and downpipe). I think if I were to track it I would need the oil cooler, but realistically I could probably just run slightly thicker oil (0W-30). I've been strongly considering the Forester OEM solution.
Illuminaughty is offline   Reply With Quote
The Following 2 Users Say Thank You to Illuminaughty For This Useful Post:
andrewFT86 (05-23-2015), Astroboy (03-16-2015)
Old 03-16-2015, 08:12 PM   #8
Astroboy
Astroboy's Avatar
Drives: None
How many miles on the turbo? Which oil were you currently running? What's the weather like where you drive? Sorry for all the questions
Old 03-16-2015, 10:22 PM   #9
Illuminaughty
Ask away I love people that go out of their way to do research. ~500 miles on the turbo, currently running 5W-20 Penzoil Platinum Pure Plus. Not my endgame choice of oil but I figured I'll change it after about 1.5k to get any particulates out of the new oil lines. Not too much hotter than where I live here in sunny south Florida, but the brutal summer hasnt even started.
andrewFT86 (05-23-2015), Astroboy (03-17-2015)
Old 03-16-2015, 10:51 PM   #10
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
FMB kit, No oil cooler. FBM upgraded radiator and dual slim fans.
67-70 degrees sunny outside and the max I see is around 236*F when I beat on it on my 40min ride home from work. Which is 20min traffic, floor it on an on-ramp onto a 75mph highway and then last 6 min are slow neighborhood roads. While cruising on the highway it seems to hold steady around 220*.
Will for sure be getting an oil cooler come summer. Had a perrin oil cooler and sold it to add to the turbo funds campaign when they first released. This time around I'll get the FBM oil cooler... simply due to location and compatibility with my kit. Or may go with DIY forester route... pending how well it works on a few local guy's builds. The only poor thing about the side mounted oil cooler's I've heard is that they heat soak quickly. I'm sure my new front end will fix that with a fresh air draw (ARP brake duct) right to the core.
The Following 3 Users Say Thank You to Kiske For This Useful Post:
andrewFT86 (05-23-2015), Astroboy (03-17-2015), Boofneenee (03-16-2015)
Old 03-17-2015, 11:15 AM   #11
Astroboy
Astroboy's Avatar
Drives: None
How many miles driving with the turbo on? Nice spoiler btw! I'm not a fan of big spoilers but yours looks extremely good.
Old 05-23-2015, 10:42 PM   #12
Astroboy
Astroboy's Avatar
Drives: None
3. I have one
a. build quality
c. value for money
Which oil type are you using
Old 05-23-2015, 11:25 PM   #13
andrewFT86
andrewFT86's Avatar
Finally got one, the AVO kit. Very happy with it.
Old 05-23-2015, 11:55 PM   #14
scarfo
Drives: gts 86
I'm running a treadstone performance kit along with a skunk2 alpha radiator with liquid cooler built into the end tank, currently getting some custom lines fab to run it as an oil cooler as well .
I will report back once up and running
scarfo is offline   Reply With Quote
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
Poll: Racing/HPDE with/without Oil Cooler sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-01-2013 08:42 AM
