Old 05-23-2015, 12:09 AM   #85
brz408
Manny
brz408's Avatar
Drives: 13 WRB Brz
It also looks like you have some grime or rust built up in there.
brz408 is offline   Reply With Quote
Old 05-23-2015, 12:17 AM   #86
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
I have the allen wrench being held as well with no luck. I'll use the WD and see what happens. I even tried an impact wrench and didnt do a think. lol
adrixe is offline   Reply With Quote
The Following User Says Thank You to adrixe For This Useful Post:
brz408 (05-23-2015)
Old 05-23-2015, 06:32 AM   #87
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Shouldn't be that hard to break loose. Are you turning the correct way? Put a breaker pipe/bar on the socket wrench to get more leverage and have someone else hold the allen key. Rust shouldnt get in there if the dust cover is on... should take some force, but nothing close to loosening lug nutz per say.
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 05-23-2015, 06:40 AM   #88
adrixe
adrixe's Avatar
Yeah i thought it's going to be easy to loosen the nut. I'll put some wd40 to see if it helps. No rust in the bolt.. yeah I'm turning the correct way. Counterclockwise.
Old 05-23-2015, 07:00 PM   #89
Agent 86
Drives: 2017 Cayman S
Have you tried to remove the rear nuts yet? Just wondering if you experience the same thing there. There was no lactate on mine. As the other guy said, not much force is needed at all. WD-40 might work (blue can), but if it does not get a "true" penetrating spray. WD-40 does make a penetrating spray that comes in a silver can.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 05-23-2015, 09:56 PM   #90
adrixe
adrixe's Avatar
Thanks guys! Wd40 worked for me! Took me 7 hrs to finish installing my prokits. Those abs sensors drove me nuts!! Thanks again for the advices.
brz408 (05-23-2015)
Old 05-24-2015, 11:10 AM   #91
Agent 86
Congratulations!!! It's a good feeling once you are done. I was left with a tremendous since of satisfaction.
Took me about 4.5 hours if i remember correctly. I was able to swap out the front springs without removing the strut from the wheel hub. I was able to lean the assembly outward and mount the spring per some other posted recommendations.
Old 06-06-2015, 11:22 AM   #92
MAX
Drives: WRB Subaru BRZ Limited MT
What would happen if you spun the strut? would that cause damage for sure? of just a small risk of leak?
MAX is offline   Reply With Quote
Old 07-10-2015, 01:34 PM   #93
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by bryan767 View Post
Don't you need to preload the top mount onto the strut?
Meaning either A) use a jack under the lca to lift the shock and compress the springs or B) use some coil compressors?
I heard that not doing either of those could result in failure and clunking
I just saw this months later, but I'm not sure I understand.
If you use a jack under the LCA, it would compress the springs and let you get the bolts through the LCA easier.
I did this, except I didn't have a second jack and my existing one was holding the car up. My "jack" was my own arms and chest pushing like an SOB on the LCA until I could get the bolts through.
But I'm not sure I understand how you could not compress them anyway even if it is just by letting the car back down onto the ground. As long as the shaft pokes through the right hole to get the nut back on, there's nothing that can go differently that I can tell.
I have noticed recently my right front will sometimes make a single clunk noise at very low speeds such as parking. I'm going to mess around with it a little when I get a moment.
cycleboy is offline   Reply With Quote
Old 07-11-2015, 12:10 PM   #94
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Yes it could cause a leak. Depending on how many times it spun you could lose pressure in the shock which will eventually cause it to bleed out and be useless.
You would have to compress it off the car. The method you chose was easier, using the weight of the car to set the top nut, but it can cause the chunking noise. This is because you have probably hit a few hard bumps causing the shock to compress much harder then from where you set the top nut using the weight of the car. I would check your top nuts tq rating to make sure it's not loose.
To preload you would need to use a coilover compressor (different from a spring compressor.. But you can reverse the tangs to make a spring compressor work) on the springs, install the shocks onto the lca then the top nut, then remove the compressors..
OR
Use another jack under the lca when installing to ensure you are taking all and any rebound out of the shock so you have a fully seated top nut.
bryan767 is offline   Reply With Quote
Old 07-12-2015, 11:51 AM   #95
Chad_W
Drives: 2013 BRZ DGM
That's awesome, I've wanted to do this, ever since I say it being done for rally service. It's good to know we can do it with our rides and just to echo to OPs warning, it is very vehicle specific!
Chad_W is offline   Reply With Quote
Old 07-12-2015, 09:18 PM   #96
cycleboy
OR
Well, I only get a clunk from the front passenger side and only once in awhile at parking speed. So it can't be from the LCA install since those were in the rear. I do tend to check torque on anything replaced from time to time just to be sure.
Old 08-06-2015, 10:12 AM   #97
klearfade
klearfade's Avatar
Drives: Scion FRS
Brother you are a saint, thanks for this write up
Just here to learn.......and laugh
klearfade is offline   Reply With Quote
Old 08-13-2015, 05:51 AM   #98
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Thanks for this! Very helpful.
EDIT:
After reading this thread late last night....and thinking about how I'm fifty and this may not be possible too much longer! Ha ha!! (No really!..not kidding..)
I changed my stock top hats to Whitelines today by myself in a parking lot with the car jack, some wood pieces and some hand tools!
Since I was only changing the top hat, all I had to undo was the top hat nuts, top strut nut, sway bar nut and wheel.
Couldn't have done it without you guys!
PAX
MGPAX is offline   Reply With Quote
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Exhaust MP/FP (flange/spring bolts) install help! rbizzle004 Engine, Exhaust, Transmission 9 03-04-2013 11:34 AM
East bay shops for spring install? WillBRZ Northern California 9 02-21-2013 02:03 AM
Selling stock strut/spring assembly SleekMachine Brakes, Suspension, Chassis 16 12-13-2012 08:03 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
