Old 05-18-2015, 09:07 PM   #1
sufu05
Drives: Scion FR-S
Radio receptions cut when headlights turn on
So i installed HID's and ever since then when I turn them on I notice that my radio clarity sucks. When I turn them off I can hear the radio fine. Any ideas?
sufu05 is offline   Reply With Quote
Old 05-19-2015, 12:46 AM   #2
Poodles
Drives: 2015 Series.Blue
Cheap POS ballasts that are emitting a ton of RF. This isn't good for the electronics of the car either.
Old 05-19-2015, 10:44 AM   #3
Chimera
Drives: FRS
yup,
where did you mount the ballasts?
Old 05-21-2015, 09:20 PM   #4
sufu05
Drives: Scion FR-S
honestly i didn't. i Just tucked them in next to the headlights. Where should i mount them?
Old 05-22-2015, 10:46 AM   #5
Chimera
Drives: FRS
I mounted mine on the sides of the supports for the front crash bar under the bumper, kinda far away from anything else, but you have to drop the bumper to get at that spot.
Old 05-22-2015, 10:50 AM   #6
HunterGreene
Hail Magnet
HunterGreene's Avatar
Mine are mounted to the top of those supports, you can get in there if you get slim ballasts and have a decent amount of dexterity.
As far as the cause, where did you get your HID kit from? I agree that RF interference is a likely culprit, though it wont affect your electronics as strongly as the radio signal. First time I have ever heard of this problem, though.
As a fix, find some copper mesh and wrap the ballasts. Turn on your headlights and see if the interference is still there.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Chimera (05-22-2015)
Old 05-22-2015, 04:12 PM   #7
Chimera
Drives: FRS
a faraday mesh?
I thought about suggesting that but didn't know how effective it might be
also have never looked for an appropriate mesh, only ever seen it in square enclosures.
Old 05-22-2015, 04:36 PM   #8
HunterGreene
Hail Magnet
a faraday mesh?
Yeah, same idea. Copper is ideal, but any metal mesh will provide at least some dampening. The mesh keeps the signals in as well as out, and I believe there are fabrics out there that have copper woven into them that can work as well.
I wonder if window screen material would work--it would look ugly as hell and likely rust (at least in a wet climate), but it might work.
Old 05-22-2015, 06:56 PM   #9
Poodles
Would be better to just fix the issue...
Old 05-24-2015, 08:14 AM   #10
FirestormFRS
Had the same issue with very expensive Morimoto ballasts. I asked the vendor for some help and they replied the following way.
I'm sorry to hear of the troubles here. It sounds like the grounds for the harness may be 'looping' to other grounds. I recommend perhaps trying a different metal panel to ground to, or using ferrite rings to reduce the conflict
FirestormFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to FirestormFRS For This Useful Post:
Chimera (05-24-2015), HunterGreene (05-24-2015)
Acree's LED Headlights - Modded Lenses, Boomerangs, Turn Signals, and more Acree Exterior Parts (Aero, Lighting, Etc.) 5 05-26-2015 09:28 PM
BRZ Limited NAV/Audio: Any way to keep the radio on when you turn the car off? DoomsdayJesus Electronics | Audio | NAV | Infotainment 13 04-16-2014 09:55 AM
Keyless lock not turn off headlights bleakhand Issues | Warranty | Recalls / TSB 4 12-18-2013 05:04 AM
Radio Flickers on Turn Signals taimysho0 Electronics | Audio | NAV | Infotainment 5 09-17-2013 08:32 PM
Help! Headlights/turn signals don't work and I can't get my car out of park Cajun Cosmetic Modification (Interior/Exterior/Lighting) 27 01-11-2013 11:02 AM
