In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
I have the BRZ Limited with the push-button start and nav system. When I stop the car, I'm often listening to talk radio or a song I want to finish without burning gas.
Normally with a key, you can just turn it down a notch to cut the engine, with the push button it just goes completely off. Is there any way to keep the radio running without re-wiring it to a different power source (which could be a really stupid idea considering potential power draw)? I was hoping there might be a way to have the push button step down to ACC instead of just shutting off. |
Drives: Black BRZ
If yours is a standard then press the start button twice in a row without pressing in the clutch and that should put it into acc mode.
Sent from my HTC One using Tapatalk 2 |
I meant going from engine running directly to ACC. The second I touch the button it cuts the radio, which takes time to reboot when I go to ACC. I know it's a minor annoyance, but I'm used to just turning off the engine and not the radio.
Drives: 2014 Widebody Cosworth FR-S
I responded in a different thread, but now I see what you are talking about in going backwards with it, instead of tuning it off and back to ACC again. I would be interested in this too, I might go play around with mine tonight to see if I can get it to work.
Thanks, Rick |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I saw someone explain once about being able to do it by turning the car off while it's still rolling or something. I had it happen once by accident, but haven't been able to repeat it.
I wish it would stay on until you open the door, just like the window switches stay active. You could always stall it.
Drives: Dark Grey Metallic 2013 BRZ
check your owners manual, there's info in it about how to do that
Drives: Galaxy Blue BRZ
Not sure about manual but with auto you can turn the engine off with the transmission in "D" before shifting to "P" and it will go to accessories rather than off.
Drives: BRZ Limited DGM Automatic
I can confirm, manual says hitting the push button start while the engine is on and the shifter is in any position other than "P" the car will switch to accessory on mode and turn the engine off.
I tried this today, and I can confirm it works while in Neutral, I have an automatic tranny. Didn't see a reason to try anything else. |
What page? Did you see anything about with a manual transmission?
#10 |
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
#11 |
Drives: BRZ Sport-tech
Sorry to bring a thread back from the dead. But still looking for an answer to this for a MT.
I guess you could just stall the engine....
#12 |
Drives: '05 Acura TSX, '14 FRS (Asphalt)
*bump*.
I'm looking for the answer to this question, too.
#13 | |
#14 |
For manual transmission.
simply just put it in a gear when the car is stationary, release the clutch without giving any gas. Car will store, but audio still on
| Static audio with radio reception? FRS stock stereo | encity5 | Electronics | Audio | NAV | Infotainment | 14 | 10-02-2013 09:58 PM |
| Radio Flickers on Turn Signals | taimysho0 | Electronics | Audio | NAV | Infotainment | 5 | 09-17-2013 08:32 PM |
| WTB: Pioneer Premium Audio radio/head unit | tech4pdx | Canada Classifieds | 2 | 04-14-2013 07:31 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 10:11 AM |
| BRZ limited audio - does it have the ability to use a remote? | Fugazi | Electronics | Audio | NAV | Infotainment | 0 | 07-09-2012 12:42 PM |
