Old 05-11-2015, 08:21 PM   #323
steve99
Drives: FT86
Originally Posted by drift86 View Post
I have a Takeda intake and I tried to do MAF scaling using the CSV file from the first post.
My LTFT was way off after doing this. (-16%)
http://www.datazap.me/u/drift86/maf-...log=0&data=1-6
LTFT was much more stable when using the standard stage 1 OTS v2.06 tune. (-4%)
http://www.datazap.me/u/drift86/stag...log=0&data=1-5
Maybe there are different versions of the Takeda intake and they scale differently? Mine is the newer version with the longer snout and I was running without the snorkel.
Old version:
http://www.tr3performance.com/wp-con...afe-intake.jpg
Newer version:
http://cdn.shopify.com/s/files/1/019...x1024.jpg?1279
that scaling was definitely from the old version, wich appeared to suffer from some turbulant air flow , suspect they have fixed this in newer version of the intake hence scaling is much different.
you will have to scale the new one from scratch with VGI utility its not hard.
Old 05-21-2015, 04:02 AM   #324
Skorov
Skorov's Avatar
Drives: 86 GTS White
After a bunch of fiddling around with the MAF scale, I get a result like this...
http://www.datazap.me/u/skorov/maf-scaling-1
My LTFT is good, about +/- 3.9%. But my STFT are still out by quite a lot. Up to +/- 29%
I want to make sure this part is right before I go on to scale OL portion.
Is this a decent result? If not, what can I do to bring the STFT closer to the 0 point.
Thanks!
Skorov is offline   Reply With Quote
Old 05-21-2015, 06:16 AM   #325
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks!
STFT will always fluctuate, however what you're looking to do is ensure that the fluctuations are similarly equal over/below 0%. Yours are. There's not much you can do to reduce fuel trims and that's why they are there.
To further reduce them you could work on PI/DI differences and fine tune your engine load compensation table. You have no need to do it though.
.: Stealth 86 :.
Kodename 47 DJ:
Skorov (05-21-2015)
Old 05-21-2015, 06:19 AM   #326
Skorov
Skorov's Avatar
Cool! Thanks a lot. Very helpful a always. :-)
I'll work on the OL part now.
Old 06-11-2015, 08:23 PM   #327
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You can minimise the dip by taking advantage of the Engine Load Limit tables.
This is absolutely required on AT, but these values should also help on MT. On AT you still end up with -6% to -8% dip at 3.2V, MT you might not end up with any dip in the MAF scale there at all doing this.
Note - you have to rescale the axis so you can hit the load limit up to 4000, then not hit the limit at 4000.
Originally Posted by DocWalt View Post
So after going through that work suggested by Kodename and Steve I got a couple of nice WOT logs. Some minor knock correction, but no IAM drops and I'm still on mediocre 91 octane gas.
http://datazap.me/u/docwalt/04-11-15...zoom=1249-1338
http://datazap.me/u/docwalt/04-11-15...zoom=2370-2504
The MAF changes I came up with based on those logs gives me a curve like this:
I guess I'll still have the little bit of a rich spot with the slightly lean spike. Unsure what's going on there, but based on my virtual dyno results from earlier it's not causing a loss of power.
Thank you for the help guys!
The Following User Says Thank You to Wayno For This Useful Post:
DocWalt (06-12-2015)
Old 06-12-2015, 02:38 PM   #328
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Neat, thanks! I've noticed a tiny bit of a bump in power delivery going from closed to open loop at low-ish throttle. Likely because of that dip in the MAF scale. Thanks for the post!
Old 06-12-2015, 02:54 PM   #329
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Wayno can you explain what the point in capping the engine load in those tables? I have a tendency to set them high as to not hit them and don't really understand what benefit it has to do otherwise.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-12-2015, 03:34 PM   #330
Wayno
Wayno's Avatar
On FI that might make sense. On my car, you can see it goes lean when it hits the load limit, correct? Then at 3k it goes super rich. You can throw a tonne of maf correction at it, but there's a problem with that because the car will run lean at other loads in the same maf cell. Example say 5k rpm, 20pc throttle might be a whole 1 AFR leaner than target. So i took advantage of the load limit functionality to lean that area up for me.
Another solution i thought of as a workaround would be edit the target throttle plate table so it's just not possible to over load. Using the load limits is better though i think as that 3k-4k region isn't over loaded, really don't know why it's so rich on AT.
I still have -8% in that 3.2V cell compared to OTS
The Following 2 Users Say Thank You to Wayno For This Useful Post:
DocWalt (06-12-2015), Kodename47 (06-12-2015)
Old 06-17-2015, 06:47 AM   #331
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Question Messed up OFT A00C/A01C Scaling
Hey all,
A friend just got a 3" Perrin intake. Luckily, Perrin gives you their base MAF scaling on their website, which makes updating him pretty easy. While playing around with the OFT files, though, I noticed the MAF scaling seems very different from stock.
Attached pics are of stock vs OpenFlash scaling. The OF scaling is identical on all A00C and A01C roms. Did Shiv do this on purpose? Would imagine this would make your car run like shit.
Stock:
OFT:
xxBrun0xx is offline   Reply With Quote
Old 06-17-2015, 07:20 AM   #332
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by xxBrun0xx View Post
Hey all,
Stock:
OFT:
That's not correct, be wary using ECUFlash as the definition is wrong for the OFT files and you could brick your ECU. That would explain the completely wrong values.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-17-2015, 07:22 AM   #333
steve99
Drives: FT86
Hey all,
Stock:
OFT:
I think your using the wrong definitions for the oft files.
It appears your using ecuflash, the oft roms your using have had the calid adjusted and are actually B01C roms internally
Use the B01C romsand def that should work.
please read the tactrixecuflash link below specially the warning in red, else as @Kodename47 saays it will be a new ecu for you.
Old 06-17-2015, 11:54 AM   #334
xxBrun0xx
xxBrun0xx's Avatar
So you can just take the B01C definition and name it A01C.xml? Won't you then have issues reading/writing the stock A01C file?
Or do you mean I should be flashing the B01C rom to his car, not A01C because the A01C definition is still incomplete?
Old 06-17-2015, 06:29 PM   #335
Wayno
Wayno's Avatar
Steve just said, and you even quoted him if you're not using openflash then flash B01C and use the B01C def.
xxBrun0xx (06-18-2015)
Old 06-17-2015, 08:35 PM   #336
steve99
Drives: FT86
At the start of the tactrix ecuflash post link below is a rom comatbiliy list
Cars which came with A01C are compatable with the updated B01C roms.
read this info here on OFT roms
http://www.ft86club.com/forums/showthread.php?t=79152
use the B01C rom and B01C def with ecuflash, check some tables to make sure everything matches and tables look good. you can flash B01C roms to A01C cars
if you unsure what is going on with oft roms and ecuflash then stop else you may brick your ecu. do some more reading.
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
