#309 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | DocWalt (04-12-2015) |
#310 | |
Drives: '22 BRZ
#311 |
Drives: Ultramarine GT86 (Scion)
Probably a dumb question, but I cant seem to find the answer in this thread. once I download the Takeda Scale file, how do you open/use it to edit your rom in Romraider?
Example: running the Greddy momentum/takeda intake with a OFT trying to make a MAF scaled 91 Octane tune as well as a MAF scaled stock tune PS- First time working on an engine without a carburetor... |
#312 | |
Drives: FT86
have a read of romraider tip link below , romraider site has info on howxto install and use romraider. romraider allows you to edit your rom using a definition file, which is an index into the hundreds of tables in the rom. you need to edit the MAF scale table. |
#313 | |
Thanks. I've read up on romraider, installed it, familiarized myself with it somewhat, loaded the correct OFT definition for their v1.59 91 octane tune for the US 6MT, loaded the stated rom, and am just trying to use the scaling for the takeda afe intake that your provided earlier in the thread, I just dont know how to open the scaling file or use it to edit the MAF scale in romraider. I plan on doing some data logging and further fine tuning due to being at sea level after I get the initial scaling (using steve99's file) done as a good starting point. Any help is appreciated, as I'm stumped on what program to even open the scaling file with. |
#314 | |
Drives: FT86
your using old oft tunes the latest tunes V2.06 have many good updates base takeda scale here. Volts Flow [Table2D] 0.90 0.85 0.94 1.14 0.98 1.32 1.02 1.63 1.05 1.81 1.09 2.07 1.13 2.30 1.17 2.59 1.21 2.91 1.25 3.28 1.29 3.57 1.33 3.92 1.37 4.25 1.41 4.60 1.45 5.02 1.48 5.53 1.52 6.22 1.56 6.56 1.60 7.30 1.64 8.04 1.68 8.46 1.72 9.21 1.76 9.96 1.80 10.67 1.84 11.53 1.88 12.51 1.91 13.43 1.95 14.28 1.99 15.19 2.03 16.34 2.07 17.13 2.11 18.03 2.15 19.25 2.19 20.99 2.23 21.96 2.27 23.61 2.30 25.00 2.34 26.01 2.38 27.77 2.42 29.28 2.46 30.51 2.50 32.44 2.58 35.83 2.77 44.93 2.97 52.63 3.20 67.31 3.44 84.04 3.71 107.81 3.91 129.06 4.06 141.59 4.30 169.31 4.49 197.00 4.73 234.25 5.00 290.26 |
#315 |
#316 |
Drives: FT86
#317 |
#318 |
APEXHNTR
Drives: 10 Series FR-S #1867
this thread is TL;DR so if someone can answer this quick question for me...
Using Grimmspeed intake, have the GS Stage 1 93oct tune. I'm assuming I can't just copy the MAF table to my Stage 2 e85 tune correct? Would I have to do the scaling manually for e85?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#319 | |
Use the stock Stage 2 E85 tune with your G/S intake. The maf position and scale is 1:1. I can send you my Grimmspeed Intake + OFH e85 tune, which addresses a little bit of tip in and fuel trim variance to PNW E85. Use this at your own risk, however, as E85 can be wildly varied between regions, carriers, even same-carrier different-day environments. This precipitates the want for a flexfuel setup if one is running corn juice competitively or with any long-term, high spirited driving use. GL |
#320 | |
APEXHNTR
I will use the GS tune for 93 and the OTS Stage 2 e85 for e85.
#321 | |
#322 |
Drives: GT86, 22 BRZ
I have a Takeda intake and I tried to do MAF scaling using the CSV file from the first post.
My LTFT was way off after doing this. (-16%) http://www.datazap.me/u/drift86/maf-...log=0&data=1-6 LTFT was much more stable when using the standard stage 1 OTS v2.06 tune. (-4%) http://www.datazap.me/u/drift86/stag...log=0&data=1-5 Maybe there are different versions of the Takeda intake and they scale differently? Mine is the newer version with the longer snout and I was running without the snorkel. Old version: http://www.tr3performance.com/wp-con...afe-intake.jpg Newer version: http://cdn.shopify.com/s/files/1/019...x1024.jpg?1279 |
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
